Hello,
Basically, the first Arduino (Ar1) has the button that sends a control signal to the second Arduino (Ar2) to tell Ar2 to turn on a digital pins. I have that part working.
Now, I want Ar1 to tell Ar2 to turn on the pins, and I want Ar2 to be taking analog data from the analog port (A0) and transmitting that data back to Ar1. So, both Arduino's need to be working as transmitters and receivers at the same time. I can do everything individually; I just have to figure out how to integrate them together.
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
RF24 radio(23, 27); // CE, CSN
const byte addresses [][6] = {"00001", "00002"};
const int chutePin = 2;
int launchState = LOW;
const int analogPin = A0;
pinMode(chutePin, OUTPUT);
radio.begin();
radio.openWritingPipe(addresses[0]); //Setting
radio.openReadingPipe(1, addresses[1]);
radio.setPALevel(RF24_PA_MIN);
radio.startListening();
// delay(5);
// radio.startListening();
if (radio.available()) {
char txt1[5] = "";
radio.read(&txt1, sizeof(txt1));
switch (txt1[1]){
case '1': launchState = !launchState;
digitalWrite(chutePin, launchState); Serial.print("lol");
radio.stopListening();
while(1);
int sensorValue = analogRead(analogPin);
radio.write(&sensorValue, sizeof(sensorValue));
Serial.print("Sent Sensor Value: ");
Serial.println(sensorValue);
//TRANSMITTER CODE (A1)
#include <SPI.h>
#include <RF24.h>
const int B1_Pin = 2;
char txt1[] = "B1", txt2[]="0";
RF24 radio(7, 8); // CE, CSN
int sensorValue = 0;
radio.begin();
pinMode(B1_Pin,INPUT);
radio.openWritingPipe(addresses[1]); //Setting
radio.openReadingPipe(1, addresses[0]);
delay(5);
// Transmitting Light Signal
int B1_State = digitalRead(B1_Pin);
if (B1_State == HIGH){
radio.write(&txt1,sizeof(txt1));Serial.println("Pressed1");Serial.println(" ");
while(!radio.available());
radio.read(&sensorValue, sizeof(sensorValue));
Serial.print("Received Sensor Value: ");
else {
radio.write(&txt2, sizeof(txt2));
