My 16x2 LCD 8 bit Mario animation
I recently got my first arduino and this is my first project (so you can guess am pretty new to this stuff). It's a 8 bit Mario running from the left to the right end of the display. I used the real 8 bit Super Mario run animation as reference. My LCD is meant to be a digits display but i thought it would still be pretty funny to get a animation working. I had to draw every pixel-state for the animation in bit code to make it work. (pretty time killing)
Maybe someone has an idea how to do this part with less code? :sweat_smile:
Here is the code feel free to test it or to give suggestions for improvements :slight_smile:
#include  <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2); //my lcd pin setup, change it to yours
int backLight = 43;
int f=4;                  //set frames per second (fps)
int s;
// the following frams of the 8-bit Mario are made from a orginal 8-bit Mario as reference
// left number is the frame right number is the position (mario xy)
// (1 = top left 2 = bottem left 3 = top right 4 = bottem right)
byte mario11[8] = {
 B00000,
 B00000,
 B00000,
 B00000,
 B00001,
 B00001,
 B00001,
 B00000,
byte mario12[8] = {
 B00001,
 B00001,
 B00001,
 B00001,
 B00000,
 B00000,
 B00000,
 B00000
byte mario13[8] = {
  B00000,
 B11111,
 B11111,
 B11111,
 B11111,
 B11111,
 B11111,
 B11111,
byte mario14[8] = {
 B11111,
 B11111,
 B11111,
 B11111,
 B11111,
 B11111,
 B11111,
 B11110
byte mario15[8] = {
   B00000,
 B00000,
 B11000,
 B00000,
 B11000,
 B11100,
 B11000,
 B10000,
byte mario16[8] = {
 B00000,
 B10000,
 B10000,
 B10000,
 B00000,
 B00000,
 B10000,
 B00000
byte mario21[8] = {
   B00000,
 B00000,
 B00000,
 B00000,
 B00000,
 B00000,
 B00000,
 B00000,
byte mario22[8] = {
 B00111,
 B00111,
 B00111,
 B00000,
 B00001,
 B00011,
 B00011,
 B00001
byte mario23[8] = {
   B00000,
 B01111,
 B11111,
 B11111,
 B11111,
 B11111,
 B11111,
 B01111,
byte mario24[8] = {
 B11111,
 B11111,
 B11111,
 B11111,
 B11111,
 B11001,
 B00000,
 B10000
byte mario25[8] = {
 B00000,
 B00000,
 B11100,
 B10000,
 B11100,
 B11110,
 B11100,
 B11000,
byte mario26[8] = {
 B11111,
 B11111,
 B10110,
 B11110,
 B11110,
 B11110,
 B00000,
 B00000,
byte mario31[8] = {
 B00000,
 B00000,
 B00000,
 B00000,
 B00000,
 B00000,
 B00000,
 B00000,
byte mario32[8] = {
 B00000,
 B00000,
 B00000,
 B00000,
 B00011,
 B00011,
 B00111,
 B00000
byte mario33[8] = {
 B00000,
 B00000,
 B00111,
 B01111,
 B01111,
 B11111,
 B11111,
 B11111,
byte mario34[8] = {
 B01111,
 B11111,
 B11111,
 B11111,
 B11111,
 B11111,
 B00111,
 B00111
byte mario35[8] = {
 B00000,
 B00000,
 B10000,
 B11110,
 B11000,
 B11110,
 B11111,
 B11110,
byte mario36[8] = {
 B11100,
 B11110,
 B11100,
 B11000,
 B11000,
 B10000,
 B00000,
 B10000,
byte mario41[8] = {
 B00000,
 B00011,
 B00111,
 B00111,
 B01111,
 B01111,
 B01111,
 B00011,
byte mario42[8] = {
 B01111,
 B01111,
 B01111,
 B01111,
 B00111,
 B00011,
 B00011,
 B00011
byte mario43[8] = {
 B00000,
 B11000,
 B11111,
 B11100,
 B11111,
 B11111,
 B11111,
 B11110,
byte mario44[8] = {
 B11100,
 B11110,
 B11110,
 B11110,
 B11100,
 B11100,
 B11110,
 B10000
byte mario51[8] = {
 B00000,
 B00001,
 B00011,
 B00011,
 B00111,
 B00111,
 B00111,
 B00001,
byte mario52[8] = {
 B11111,
 B11111,
 B11011,
 B00111,
 B01111,
 B11111,
 B11100,
 B01110,
byte mario53[8] = {
 B00000,
 B11100,
 B11111,
 B11110,
 B11111,
 B11111,
 B11111,
 B11111,
byte mario54[8] = {
 B11111,
 B11111,
 B11110,
 B11111,
 B11111,
 B01111,
 B00000,
 B00000,
byte mario55[8] = {
 B00000,
 B00000,
 B10000,
 B00000,
 B00000,
 B10000,
 B00000,
 B00000,
byte mario56[8] = {
 B11000,
 B11000,
 B10000,
 B10000,
 B10000,
 B10000,
 B00000,
 B00000,
byte mario61[8] = {
 B00000,
 B00000,
 B00000,
 B00001,
 B00001,
 B00011,
 B00011,
 B00011,
byte mario62[8] = {
 B00001,
 B00011,
 B00111,
 B01111,
 B01111,
 B11111,
 B11000,
 B00000,
byte mario63[8] = {
 B00000,
 B00000,
 B11110,
 B11111,
 B11111,
 B11111,
 B11111,
 B11111,
byte mario64[8] = {
 B11111,
 B11111,
 B11111,
 B11111,
 B11111,
 B11110,
 B11100,
 B11110,
byte mario65[8] = {
 B00000,
 B00000,
 B00000,
 B10000,
 B00000,
 B10000,
 B11000,
 B10000,
byte mario66[8] = {
 B00000,
 B10000,
 B00000,
 B00000,
 B00000,
 B00000,
 B00000,
 B00000,
byte clean[8] = {
 B00000,
 B00000,
 B00000,
 B00000,
 B00000,
 B00000,
 B00000,
 B00000,
byte coin1[8] = {
 B00000,
 B00000,
 B00000,
 B00000,
 B00111,
 B01000,
 B10001,
 B10010,
byte coin2[8] = {
 B10010,
 B10010,
 B10010,
 B10010,
 B10001,
 B01000,
 B00111,
B00000,
byte coin3[8] = {
 B00000,
 B00000,
 B00000,
 B00000,
 B10000,
 B01000,
 B00100,
 B10100,
byte coin4[8] = {
 B10100,
 B10100,
 B10100,
 B00100,
 B00100,
 B01000,
 B10000,
 B00000,
 lcd.begin(16,2);
 pinMode(backLight, OUTPUT);
 digitalWrite(backLight, HIGH);
 lcd.clear();
 s=1000/f;            //fps to ms
 lcd.setCursor(0,0);            //intro
 lcd.print("  8-Bit Mario");
 lcd.setCursor(0,1);
 lcd.print(" Run Animation");
 delay(2000);
 lcd.clear();
 lcd.setCursor(0,0);
 lcd.print("    By");
 lcd.setCursor(0,1);
 lcd.print("Jan Stapler");
 lcd.createChar(1, coin1);       //coin frames for the intro
 lcd.createChar(2, coin2);
 lcd.createChar(3, coin3);
 lcd.createChar(4, coin4);
 lcd.setCursor(11,0);
 lcd.write(1);
 lcd.setCursor(11,1);
 lcd.write(2);
 lcd.setCursor(12,0);
 lcd.write(3);
 lcd.setCursor(12,1);
 lcd.write(4);
  lcd.setCursor(14,0);
 lcd.write(1);
 lcd.setCursor(14,1);
 lcd.write(2);
 lcd.setCursor(15,0);
 lcd.write(3);
 lcd.setCursor(15,1);
 lcd.write(4);
 delay(2000);
 lcd.clear();
for (int a=0; a<16;a++)     //for loop to repeat marios animation until the end of the display
 int b=a+1;
 int c=a+2;
 int d=a+3;
 int e=a+4;
 lcd.createChar(1, mario11);
 lcd.createChar(2, mario12);
 lcd.createChar(3, mario13);
 lcd.createChar(4, mario14);
 lcd.createChar(5, mario15);
 lcd.createChar(6, mario16);
 lcd.createChar(7, clean);
 lcd.setCursor(a,0);
 lcd.write(1);
 lcd.setCursor(a,1);
 lcd.write(2);
 lcd.setCursor(b,0);
 lcd.write(3);
 lcd.setCursor(b,1);
 lcd.write(4);
 lcd.setCursor(c,0);
 lcd.write(5);
 lcd.setCursor(c,1);
 lcd.write(6);
 delay(s);
 lcd.createChar(1, mario21);
 lcd.createChar(2, mario22);
 lcd.createChar(3, mario23);
 lcd.createChar(4, mario24);
 lcd.createChar(5, mario25);
 lcd.createChar(6, mario26);
 lcd.setCursor(a,0);
 lcd.write(1);
 lcd.setCursor(a,1);
 lcd.write(2);
 lcd.setCursor(b,0);
 lcd.write(3);
 lcd.setCursor(b,1);
 lcd.write(4);
 lcd.setCursor(c,0);
 lcd.write(5);
 lcd.setCursor(c,1);
 lcd.write(6);
 delay(s);
  lcd.createChar(1, mario31);
 lcd.createChar(2, mario32);
 lcd.createChar(3, mario33);
 lcd.createChar(4, mario34);
 lcd.createChar(5, mario35);
 lcd.createChar(6, mario36);
 lcd.setCursor(a,0);
 lcd.write(1);
 lcd.setCursor(a,1);
 lcd.write(2);
 lcd.setCursor(b,0);
 lcd.write(3);
 lcd.setCursor(b,1);
 lcd.write(4);
 lcd.setCursor(c,0);
 lcd.write(5);
 lcd.setCursor(c,1);
 lcd.write(6);
 delay(s);
 lcd.createChar(1, mario41);
 lcd.createChar(2, mario42);
 lcd.createChar(3, mario43);
 lcd.createChar(4, mario44);
  lcd.setCursor(a,0);
 lcd.write(7);
 lcd.setCursor(a,1);
 lcd.write(7);
 lcd.setCursor(b,0);
 lcd.write(1);
 lcd.setCursor(b,1);
 lcd.write(2);
 lcd.setCursor(c,0);
 lcd.write(3);
 lcd.setCursor(c,1);
 lcd.write(4);
 delay(s);
 lcd.createChar(1, mario51);
 lcd.createChar(2, mario52);
 lcd.createChar(3, mario53);
 lcd.createChar(4, mario54);
 lcd.createChar(5, mario55);
 lcd.createChar(6, mario56);
 lcd.setCursor(a,0);
 lcd.write(7);
 lcd.setCursor(a,1);
 lcd.write(7);
 lcd.setCursor(b,0);
 lcd.write(1);
 lcd.setCursor(b,1);
 lcd.write(2);
 lcd.setCursor(c,0);
 lcd.write(3);
 lcd.setCursor(c,1);
 lcd.write(4);
 lcd.setCursor(d,0);
 lcd.write(5);
 lcd.setCursor(d,1);
 lcd.write(6);
 delay(s);
  lcd.createChar(1, mario61);
 lcd.createChar(2, mario62);
 lcd.createChar(3, mario63);
 lcd.createChar(4, mario64);
 lcd.createChar(5, mario65);
 lcd.createChar(6, mario66);
 lcd.setCursor(b,0);
 lcd.write(1);
 lcd.setCursor(b,1);
 lcd.write(2);
 lcd.setCursor(c,0);
 lcd.write(3);
 lcd.setCursor(c,1);
 lcd.write(4);
 lcd.setCursor(d,0);
 lcd.write(5);
 lcd.setCursor(d,1);
 lcd.write(6);
 delay(s);
video?
Yea, sure good idea i will make one. But i will have to wait until evening to upload it.
Cute!
It works.
Mind you, I had to run it on a display with a serial backpack.
#include <Wire.h>
#define lcdAddr 0x20 // set the address of the I2C device the LCD is connected to
// create an lcd instance with correct constructor for how the lcd is wired
//  to the I2C chip.  In this case, the www.mjkdz.com module
LiquidCrystal_I2C lcd(lcdAddr, 4, 5, 6, 0, 1, 2, 3, 7, NEGATIVE); // addr, EN, RW, RS, D4, D5, D6, D7, Backlight, POLARITY
int s;
// (1 = top left 2 = bottem left 3 = top right 4 = bottom right)
byte mario11[8] = {
 B00000,
 B00000,
 B00000,
 B00000,
 B00001,
 B00001,
 B00001,
 B00000,
byte mario12[8] = {
 B00001,
 B00001,
 B00001,
 B00001,
 B00000,
 B00000,
 B00000,
 B00000
byte mario13[8] = {
  B00000,
 B11111,
 B11111,
 B11111,
 B11111,
 B11111,
 B11111,
 B11111,
byte mario14[8] = {
 B11111,
 B11111,
 B11111,
 B11111,
 B11111,
 B11111,
 B11111,
 B11110
byte mario15[8] = {
   B00000,
 B00000,
 B11000,
 B00000,
 B11000,
 B11100,
 B11000,
 B10000,
byte mario16[8] = {
 B00000,
 B10000,
 B10000,
 B10000,
 B00000,
 B00000,
 B10000,
 B00000
byte mario21[8] = {
   B00000,
 B00000,
 B00000,
 B00000,
 B00000,
 B00000,
 B00000,
 B00000,
byte mario22[8] = {
 B00111,
 B00111,
 B00111,
 B00000,
 B00001,
 B00011,
 B00011,
 B00001
byte mario23[8] = {
   B00000,
 B01111,
 B11111,
 B11111,
 B11111,
 B11111,
 B11111,
 B01111,
byte mario24[8] = {
 B11111,
 B11111,
 B11111,
 B11111,
 B11111,
 B11001,
 B00000,
 B10000
byte mario25[8] = {
 B00000,
 B00000,
 B11100,
 B10000,
 B11100,
 B11110,
 B11100,
 B11000,
byte mario26[8] = {
 B11111,
 B11111,
 B10110,
 B11110,
 B11110,
 B11110,
 B00000,
 B00000,
byte mario31[8] = {
 B00000,
 B00000,
 B00000,
 B00000,
 B00000,
 B00000,
 B00000,
 B00000,
byte mario32[8] = {
 B00000,
 B00000,
 B00000,
 B00000,
 B00011,
 B00011,
 B00111,
 B00000
byte mario33[8] = {
 B00000,
 B00000,
 B00111,
 B01111,
 B01111,
 B11111,
 B11111,
 B11111,
byte mario34[8] = {
 B01111,
 B11111,
 B11111,
 B11111,
 B11111,
 B11111,
 B00111,
 B00111
byte mario35[8] = {
 B00000,
 B00000,
 B10000,
 B11110,
 B11000,
 B11110,
 B11111,
 B11110,
byte mario36[8] = {
 B11100,
 B11110,
 B11100,
 B11000,
 B11000,
 B10000,
 B00000,
 B10000,
byte mario41[8] = {
 B00000,
 B00011,
 B00111,
 B00111,
 B01111,
 B01111,
 B01111,
 B00011,
byte mario42[8] = {
 B01111,
 B01111,
 B01111,
 B01111,
 B00111,
 B00011,
 B00011,
 B00011
byte mario43[8] = {
 B00000,
 B11000,
 B11111,
 B11100,
 B11111,
 B11111,
 B11111,
 B11110,
byte mario44[8] = {
 B11100,
 B11110,
 B11110,
 B11110,
 B11100,
 B11100,
 B11110,
 B10000
byte mario51[8] = {
 B00000,
 B00001,
 B00011,
 B00011,
 B00111,
 B00111,
 B00111,
 B00001,
byte mario52[8] = {
 B11111,
 B11111,
 B11011,
 B00111,
 B01111,
 B11111,
 B11100,
 B01110,
byte mario53[8] = {
 B00000,
 B11100,
 B11111,
 B11110,
 B11111,
 B11111,
 B11111,
 B11111,
byte mario54[8] = {
 B11111,
 B11111,
 B11110,
 B11111,
 B11111,
 B01111,
 B00000,
 B00000,
byte mario55[8] = {
 B00000,
 B00000,
 B10000,
 B00000,
 B00000,
 B10000,
 B00000,
 B00000,
byte mario56[8] = {
 B11000,
 B11000,
 B10000,
 B10000,
 B10000,
 B10000,
 B00000,
 B00000,
byte mario61[8] = {
 B00000,
 B00000,
 B00000,
 B00001,
 B00001,
 B00011,
 B00011,
 B00011,
byte mario62[8] = {
 B00001,
 B00011,
 B00111,
 B01111,
 B01111,
 B11111,
 B11000,
 B00000,
byte mario63[8] = {
 B00000,
 B00000,
 B11110,
 B11111,
 B11111,
 B11111,
 B11111,
 B11111,
byte mario64[8] = {
 B11111,
 B11111,
 B11111,
 B11111,
 B11111,
 B11110,
 B11100,
 B11110,
byte mario65[8] = {
 B00000,
 B00000,
 B00000,
 B10000,
 B00000,
 B10000,
 B11000,
 B10000,
byte mario66[8] = {
 B00000,
 B10000,
 B00000,
 B00000,
 B00000,
 B00000,
 B00000,
 B00000,
byte clean[8] = {
 B00000,
 B00000,
 B00000,
 B00000,
 B00000,
 B00000,
 B00000,
 B00000,
byte coin1[8] = {
 B00000,
 B00000,
 B00000,
 B00000,
 B00111,
 B01000,
 B10001,
 B10010,
byte coin2[8] = {
 B10010,
 B10010,
 B10010,
 B10010,
 B10001,
 B01000,
 B00111,
B00000,
byte coin3[8] = {
 B00000,
 B00000,
 B00000,
 B00000,
 B10000,
 B01000,
 B00100,
 B10100,
byte coin4[8] = {
 B10100,
 B10100,
 B10100,
 B00100,
 B00100,
 B01000,
 B10000,
 B00000,
 lcd.begin(16,2);
 lcd.clear();
 lcd.setCursor(0,1);
 delay(2000);
 lcd.clear();
 lcd.setCursor(0,0);
 lcd.print("    By");
 lcd.setCursor(0,1);
 lcd.write(1);
 lcd.write(2);
 lcd.write(3);
 lcd.write(4);
 lcd.write(1);
 lcd.write(2);
 lcd.write(3);
 lcd.write(4);
 delay(2000);
 lcd.clear();
 int b=a+1;
 int c=a+2;
 int d=a+3;
 int e=a+4;
 lcd.setCursor(a,0);
 lcd.write(1);
 lcd.setCursor(a,1);
 lcd.write(2);
 lcd.setCursor(b,0);
 lcd.write(3);
 lcd.setCursor(b,1);
 lcd.write(4);
 lcd.setCursor(c,0);
 lcd.write(5);
 lcd.setCursor(c,1);
 lcd.write(6);
 delay(s);
 lcd.setCursor(a,0);
 lcd.write(1);
 lcd.setCursor(a,1);
 lcd.write(2);
 lcd.setCursor(b,0);
 lcd.write(3);
 lcd.setCursor(b,1);
 lcd.write(4);
 lcd.setCursor(c,0);
 lcd.write(5);
 lcd.setCursor(c,1);
 lcd.write(6);
 delay(s);
 lcd.setCursor(a,0);
 lcd.write(1);
 lcd.setCursor(a,1);
 lcd.write(2);
 lcd.setCursor(b,0);
 lcd.write(3);
 lcd.setCursor(b,1);
 lcd.write(4);
 lcd.setCursor(c,0);
 lcd.write(5);
 lcd.setCursor(c,1);
 lcd.write(6);
 delay(s);
  lcd.setCursor(a,0);
 lcd.write(7);
 lcd.setCursor(a,1);
 lcd.write(7);
 lcd.setCursor(b,0);
 lcd.write(1);
 lcd.setCursor(b,1);
 lcd.write(2);
 lcd.setCursor(c,0);
 lcd.write(3);
 lcd.setCursor(c,1);
 lcd.write(4);
 delay(s);
 lcd.setCursor(a,0);
 lcd.write(7);
 lcd.setCursor(a,1);
 lcd.write(7);
 lcd.setCursor(b,0);
 lcd.write(1);
 lcd.setCursor(b,1);
 lcd.write(2);
 lcd.setCursor(c,0);
 lcd.write(3);
 lcd.setCursor(c,1);
 lcd.write(4);
 lcd.setCursor(d,0);
 lcd.write(5);
 lcd.setCursor(d,1);
 lcd.write(6);
 delay(s);
 lcd.setCursor(b,0);
 lcd.write(1);
 lcd.setCursor(b,1);
 lcd.write(2);
 lcd.setCursor(c,0);
 lcd.write(3);
 lcd.setCursor(c,1);
 lcd.write(4);
 lcd.setCursor(d,0);
 lcd.write(5);
 lcd.setCursor(d,1);
 lcd.write(6);
 delay(s);
Nice to hear Paul! :smiley:
And here as promised the viedo. Sorry that the slow frame change speed of the display makes it look kinda weird :~
What great fun. Thanks for giving me a grin this morning ! Geoff
