Hi all,
This is my first program to test my new mega, does it look correct for arduino code? how should I improve it?
I have a light dependent resistor, thermistor, buzzer, 16x2 LCD and a 7-segment 4-digit LED display with a 74HC595 8-bit shift register driving it.
It beeps with power on, then flips displays between temperature and light levels.
// LCD
#include <LiquidCrystal.h> // include the library code
LiquidCrystal lcd(53, 52, 51, 50, 49, 48, 47, 46, 45, 44, 43); // initialize the library with the numbers of the interface pins
// DEFINES
int ledPin = 13; // select the pin for the LED
int slow = 0; // slow down sensor readings and flip between
int num = 0; // the number for display
int buzzerPin = 4; //power on beep
// LIGHT DEPENDENT RESISTOR
int LDR = 15; // select the input pin for the LDR
int val = 0; // variable to store the value coming from the sensor
int ldrval =0;
int ldrval2 =0;
// THERMISTER CONTROL + MATH FOR CELCIUS CONVERTION
const float rinfinit = 93.79645; // This you should calculate yours
const float voltage = 5.04; // should change it to 5040 for 5.04V
const float B = 4100;
const float unodivr = 93.79645;
const float resistor = 5900; // use this to set temp via resistor value
int sensorPin = 14; // select the input pin for the thermister
int sensorValue = 0; // variable to store the value coming from the sensor
// 7 SEGMENT 4 DIGIT LED - 8 BIT SHIFT REGISTER
int latchPin = 31; //Pin connected to ST_CP of 74HC595 (aka RCLK)
int clockPin = 32; //Pin connected to SH_CP of 74HC595 (aka SRCLK)
int dataPin = 30; //Pin connected to DS of 74HC595 (aka SER)
int digit1Pin = 33; //4 digits LED to light
int digit2Pin = 34;
int digit3Pin = 35;
int digit4Pin = 36;
int digits[10]={63,6,91,79,102,109,125,7,127,111}; // array to hold 10 bit binary 0-9 to swap for alphanumeric 0-9:
//MAIN SETUP
// SETUP PINMODES
pinMode(buzzerPin, OUTPUT); // power on beep
pinMode(LDR, INPUT); // declare the LDR as an INPUT
pinMode(ledPin, OUTPUT); // declare the ledPin as an OUTPUT
// 7 SEGMENT 4 DIGIT LED - 8 BIT SHIFT REGISTER SETUP
pinMode(digit1Pin, OUTPUT);
pinMode(digit2Pin, OUTPUT);
pinMode(digit3Pin, OUTPUT);
pinMode(digit4Pin, OUTPUT);
pinMode(latchPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
// LCD SETUP
lcd.begin(16, 2); // set up the LCD's number of columns and rows
lcd.print("hello"); // Print a welcome message to the LCD
// SETUP COMPLETE BEEP + PAUSE
tone(4, 2000, 100);
delay(2000);
// MAIN PROGRAM LOOP
void loop(){
// THERMISTER MAIN LOOP
if (slow<500){
// Convert the value to volts
float v2 = (voltage*float(sensorValue))/1024.0f; // calculate volts in an awesome world
float r1a = (voltage*float(resistor))/v2; // sums to convert to temp
float r1 =r1a - resistor;
float T = B/log(r1*unodivr);
T=T-273.15;
num=T; // temp output in oC
lcd.setCursor(0,0);
lcd.print("temperature is c"); // Print a message to the LCD
digitalWrite(ledPin, LOW); // turn the ledPin off
// LDR MAIN LOOP NUMBER REWORK SO SCALE FITS TO 0-9999ISH
if (slow>500){
ldrval2 = (ldrval * 8); //
num = (8150-ldrval2);
lcd.setCursor(0,0);
lcd.print("Light levels are"); // Print a message to the LCD
// SWAP OVER DISPLAY + TAKE READINGS
slow=(slow-1);
if (slow<0){
digitalWrite(ledPin, HIGH); // turn the ledPin on
ldrval = analogRead(LDR); // read the value from the ldr sensor on pin 15
sensorValue = analogRead(sensorPin); //read temp from thermister
slow=1000;
// 7 SEGMENT 4 DIGIT LED - 8 BIT SHIFT REGISTER LOOP
int thousand, hundred, ten, one; // breakdown number into columns
thousand = num/1000;
hundred = (num-(thousand*1000))/100;
ten = (num-((thousand*1000)+(hundred*100)))/10;
one = num-((thousand*1000)+(hundred*100)+(ten*10));
// now drive the LED's via shift register:
digitalWrite(latchPin, LOW); // take the latchPin low so the LEDs don't change while you're sending
shiftOut(dataPin, clockPin, MSBFIRST, digits[one]); // shift out the data bits for digit via array 0-9
digitalWrite(latchPin, HIGH); //take the latch pin high so the LEDs will light up
// select digit to light up:
digitalWrite(digit1Pin, HIGH);
digitalWrite(digit2Pin, HIGH);
digitalWrite(digit3Pin, HIGH);
digitalWrite(digit4Pin, LOW);
delay(1);// and pause before next value so LED gets time to light
// repeat for all digits:
if (hundred>0 || thousand>0 || ten>0){ //only turn on if number is over 1 digit ?MAY ONLY COMPARE 2 AS SHOWS 0 HERE STILL?
shiftOut(dataPin, clockPin, MSBFIRST, digits[ten]);
digitalWrite(digit3Pin, LOW);
digitalWrite(digit4Pin, HIGH);
delay(1);
if (hundred>0 || thousand>0){ // WORKS HERE BUT NOT WITH 3?
shiftOut(dataPin, clockPin, MSBFIRST, digits[hundred]);
digitalWrite(digit2Pin, LOW);
delay(1);
if (thousand>0){ // WORKS HERE BUT NOT WITH 3?
shiftOut(dataPin, clockPin, MSBFIRST, digits[thousand]);
digitalWrite(digit1Pin, LOW);
delay(1);
// UNCOMMENT FOR DEBUGING
Serial.println"DEBUGING";
Serial.println"LDR value";
Serial.println(val);
Serial.println"temperature";
Serial.println(T);
Serial.println"temperature or light levels";
Serial.println(num);
Serial.println"display digits 1000,100,10,1";
Serial.println(thousand);
Serial.println(hundred);
Serial.println(ten);
Serial.println(one);
Serial.println"END";
Serial.println"";
delay(2000);
My problems any help would be cool,
- Mega2560 r2 wont upload my sketch with 1.0 IDE but works with 0023?
- 16x2 screen only works on full 8-bit, 4-bit displays garbage?
- 16x2 screen wont display 2 line or numbers and replaces spaces with tiddle?
- The second digit on the 7 segment LED still illuminates even if it is a 0? Can I use "if (hundred>0 || thousand>0 || ten>0)" with 2 only?
- Is the code correct or bad overall for arduino?
Thanks, Matt
