My LoRa Receiver can only receive data from 1 Lora transmitter, doesn't work with the other Lora
Currently i have a project to read data from a node (using ESP32) and then send it to a master node using ESP32 too and RA-02 SX1278 LoRa 433MHz, which then will be uploaded to the database. T
he Master Node works fine with Node A only, even though the connection between nodes are the same. I had switch the LoRa Module with other ESP32 (LoRa A with ESP32B, LoRa D with ESP32 C, etc) and I have concluded that all ESP32 works with LoRa A but No ESP32 works with the other LoRa.
Receiver
#include <SPI.h>
#include <LoRa.h>
#include <WiFi.h>
#include <string.h>
#include <WiFiClient.h>
#include <HTTPClient.h>
WiFiClient client;
const char* ssid = "Redmi Note 9 Pro";
const char* pass = "Yaitudah";
// const char* ssid = "Bruh Guy";
// const char* pass = "Bruh Guy";
#define mosi 23
#define miso 19
#define sck 18
#define ss 5
#define rst 16
#define dio0 17
const char* serverName = "https://somethingsomething.com/databaseexample";
//json format = "{\"rawData\":\"LoraID(2 digits) + Data(2 digits)\"}";
  String loraID = "01"; // Example LoraID
  String data = "23";   // Example Data
  String LoraTempt;
void connectToWifi(){
  Serial.print("Connecting to WiFi");
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, pass);
  //unsigned long startAttemotTime = millis();
  while(WiFi.status() != WL_CONNECTED){
    Serial.println(".");
    delay(100);
  if(WiFi.status() != WL_CONNECTED){
    Serial.println("Failed");
  }else{
    Serial.print("Connected to ");
  SPI.begin(sck, miso, mosi, ss);
  LoRa.setPins(ss, rst, dio0);
  connectToWifi();
  while (!Serial);
  //Serial.println("LoRa Receiver");
  if (!LoRa.begin(433E6)) {
    Serial.println("Starting LoRa failed!");
    while (1);
  LoRa.setSpreadingFactor(12); //12 Max Range
  LoRa.setSignalBandwidth(15.6E3); //The higher the higher the bandwidth
  LoRa.setSyncWord(0x12); //LoRa Sync Word
  Serial.println("Running code");
  // try to parse packet
  int packetSize = LoRa.parsePacket();
  if (packetSize) {
    // received a packet
    Serial.print("Received packet ");
    // read packet
    while (LoRa.available()) {
      LoraTempt = LoRa.readString();
      Serial.print(LoraTempt);
    // print RSSI of packet
    Serial.print(" with RSSI ");
    Serial.println(LoRa.packetRssi());
    if(WiFi.status()== WL_CONNECTED){
    HTTPClient http;
    http.begin(serverName);  // Specify the URL
    http.addHeader("Content-Type", "application/json");  // Specify content-type header
    // Construct the JSON formatted string
    String jsonData = "{\"rawData\":\"" + LoraTempt + "\"}";
    int httpResponseCode = http.POST(jsonData);  // Send the request
    if (httpResponseCode > 0) {  // Check for the returning code
      String response = http.getString();  // Get the response to the request
      Serial.println(httpResponseCode);  // Print return code
      Serial.println(response);  // Print request answer
      Serial.println(jsonData);
      delay(2000);
      Serial.print("Error on sending POST: ");
    http.end();  // Free the resources
    Serial.println("Error in WiFi connection");
Node A
//Definition
#include <SPI.h>
#include <LoRa.h>
#include <string.h>
#define Input_low 15
#define Input_medium 4
#define Input_high 2
#define mosi 21 //21
#define miso 19 //19
#define sck 18 //18
#define ss 5 //5
#define rst 32 //34
#define dio0 33 //35
float adcVolt(int input) {
  return input * 3.3 / 4095;
double Input_1;
double Input_2;
double Input_3;
double I1=0, I2=0, I3=0;
double FI1=0, FI2=0, FI3=0;
int n=0; //Counter
//This LoRa ID: 00
//Main ESP32
//Data Format, "(xx)(yy)", xx = LoraID, yy = Data
  pinMode(Input_low, INPUT);
  pinMode(Input_medium, INPUT);
  pinMode(Input_high, INPUT);
  Serial.println("LoRa Sender");
  //LoRa.setSPIFrequency(8E6);
  LoRa.begin(433E6);
  if (!LoRa.begin(433E6)){
    Serial.println("LoRa Failed");
    ESP.restart();
    while(1);
  LoRa.setTxPower(20); //20 Max Power
  if (n == 501) //Reset Value
    n = 0;
    I1=0; I2=0; I3=0;
    FI1=0; FI2=0; FI3=0;
  Input_1 = adcVolt(analogRead(Input_low));
  Input_2 = adcVolt(analogRead(Input_medium));
  Input_3 = adcVolt(analogRead(Input_high));
  I1 += Input_1; //Adding Input
  I2 += Input_2;
  I3 += Input_3;
  if (n==500){ //Average value
    FI1 = I1/n;
    FI2 = I2/n;
    FI3 = I3/n;
    Serial.print("1 = ");
    Serial.println(FI1);
    Serial.print("2 = ");
    Serial.println(FI2);
    Serial.print("3 = ");
    Serial.println(FI3);
    if (FI1 < 3){
      if (FI2 <= 3){
        if (FI3 <= 3){
          LoRa.beginPacket();
          LoRa.print("0011");
          Serial.println("Air Tinggi ");
          LoRa.endPacket();
        else{
          LoRa.beginPacket();
          LoRa.print("0010");
          Serial.println("Air Sedang ");
          LoRa.endPacket();
      else{
        LoRa.beginPacket();
        LoRa.print("0001");
        Serial.println("Air Rendah ");
        LoRa.endPacket();
    else{
      LoRa.beginPacket();
      LoRa.print("0000");
      Serial.println("Tidak ada air ");
      LoRa.endPacket();
  n++; //Increment Counter
That will be the likely reason.
The chances of an SX1278 communicating reliably with other SX1278 modules at such a low bandwidth are slim.
Set the bandwidth on all modules to 62.5E3 minimum.
Wow thanks dude, that worked like a charm, I guess I'm too focused on how to make the system work as far as possible.
There are better loRa modules that can be used at the lower bandwidths.
Could you please let me know some?
Currently I can only purchased the SX1278 in my city, but maybe I could get the better one in the future if I will work on another project.
A lot of SX1262 LoRa modules have TCXOs, which allows you to use the lower bandwidths.
You would also need to use a different LoRa library, one that supports SX1262.
After trying a few more times, I noticed that my RX only receive either from only 1 TX or TX with the stronger signal. Therefore I'm planning to delay (or maybe put my ESP to sleep in the future) so my RX could receive signal from other TX.
My RX could send back signal but my TX could not receive the signal.
Receiver
#include <SPI.h>
#include <LoRa.h>
#include <WiFi.h>
#include <string.h>
WiFiClient client;
// const char* ssid = "Redmi Note 9 Pro";
// const char* pass = "Yaitudah";
const char* ssid = "DTKOMP-WIFI";
const char* pass = "";
// const char* ssid = "VillaTK";
// const char* pass = "Anaktekkom21";
#define mosi 23
#define miso 19
#define sck 18
#define ss 5
#define rst 16
#define dio0 17
  //loraID = "01";  Example LoraID
  //data = "23";    Example Data
  byte LoraTX;
  String LoraTempt;
    delay(100);
  }else{
  connectToWifi();
  while (!Serial);
    while (1);
  LoRa.setSignalBandwidth(62.5E3); //The higher the higher the bandwidth
  if (packetSize) {
    // read packet
      LoraTX = LoRa.read();
    HTTPClient http;
      LoRa.beginPacket();
      LoRa.write(LoraTX);
      LoRa.endPacket();
      Serial.println(LoraTX);
      Serial.println("LoRa Response Sent back to Sender");
      delay(2000);
Transmitter
//Definition
#include <SPI.h>
#include <LoRa.h>
#include <string.h>
#define sck 18 //18
#define ss 5 //5
#define rst 32 //34
double Input_1;
double Input_2;
double Input_3;
int n=0; //Counter
//This LoRa ID: 01
//Ardy's ESP32
byte LoRaTX = 0xBB;
byte LoRaTempt;
  Serial.println("LoRa Sender Ardy");
    ESP.restart();
    while(1);
    int packetSize = LoRa.parsePacket(); //Chekcing for response from RX
    if (packetSize)
      Serial.println("Packet detected");
      while (LoRa.available()){
        LoRaTempt = LoRa.read();
      Serial.print("Receive: ");
      Serial.println(LoRaTempt);
      Serial.print("Checking if");
      if (LoRaTempt == LoRaTX)
        Serial.println("Pausing ESP for 10 Seconds");
        delay (10000);
        n = 0;
        I1=0; I2=0; I3=0;
      I2 += Input_2;
      I3 += Input_3;
        FI1 = I1/n;
        FI2 = I2/n;
        FI3 = I3/n;
        if (FI1 < 3){
          if (FI2 <= 3){
            if (FI3 <= 3){
              LoRa.beginPacket();
              LoRa.write(LoRaTX);
              LoRa.print("0111");
              LoRa.endPacket();
            else{
              LoRa.beginPacket();
              LoRa.write(LoRaTX);
              LoRa.print("0110");
              LoRa.endPacket();
          else{
            LoRa.beginPacket();
            LoRa.write(LoRaTX);
            LoRa.print("0101");
            LoRa.endPacket();
        else{
          LoRa.beginPacket();
          LoRa.write(LoRaTX);
          LoRa.print("0100");
          LoRa.endPacket();
