Hello everyone, I'm Mick and I managed to turn my Arduino UNO rev3 in a USB HID joystick with 4 axes and 32 buttons, which maps input from two N64 controllers to these axes and buttons; it is composed of two parts, a .ino sketch for the ATmega328p which sends a command to two N64 controllers and reads 4 bytes from each controller; the first two bytes represent the x and y axes value, which range from -128 to 127; the other two bytes represent the status for each button in each bit (0 means no pressure, 1 means button pressed); there are actually 14 buttons on a N64 controller, which means that 2 bits are unused; after reading the status of the two controllers, the sketch writes on the serial port the two statuses; the other part is an .hex file for the ATmega16u2 which let the Arduino enumerate as an HID USB joystick with 4 axes and 32 buttons , named "Arduino Joystick"; all I did was actually taking some code from this Instructable for the sketch, and from this page for the USB HID firmware; on the sketch, I just removed the unused code (it was originally meant to be also used on a GCN controller, which is a pain in the a** to connect with unless you want to tear apart a standard GCN connector from your GCN), and turned it to probe two controllers instead of only one (cos I happen to have 2 N64 controllers, and playing with a friend is much more fun!)... on the firmware code, I modified the USB descriptor part in Descriptor.c or .h , don't remember, to my specs (which is, I repeat, 4 axes and 32 buttons). So all the original credit goes to these two guys ![]()
Btw, the cool thing of this is that, not only you could use your spare N64 controllers to play with your favourite game/emulator/whateveryouwant on your PC, which is super cool by itself, but also, you could easily make your own sketch for the ATmega328p that converts some input (say 2 arcade joysticks and 32 buttons...) into two N64-like statutes (2x8 bit values, 16x1 bit values) and use it to control something on your PC! Of course, you should be aware that this sketch first writes 2 axes and 16 buttons values on the serial port, then writes 2 other axes and 16 more buttons, so don't mess up the order of the things to write on the serial port.
Here I'm also adding a Github repository I use for this code with some brief explanation of what to do to get the whole thing up and running: MickMad N64-To-USB
For future reference, I also added this github repository link in the "Interfacing with Hardware / Gamepads" section of the Arduino Playground page.
Cheers and go get your N64 controllers NOW!!
-Mick-
Ps: this is my first ever post on this forum, yay!
