Nano BLE SENSE is not working when on power supply
It is working fine only when Arduino Nano BLE Sense is connected to a PC through usb cable to load the sketh using Arduino Web Editor. So basically it is working when connected to Web Editor and I was able to see the Device( arduino ble sense) published over bluetooth ble and I was able see it using Nordic nRF Connect app and also I was able to connect and get data using my mobile App..
"It is NOT working when Arduino Nano BLE Sense device is not connected to pc/ arduino web editor.. ie in the following cases :
  Nano 33 BLE Sense Getting Started
  A BLE peripheral broadcasting temperatature and humidity readings that can be viewed
  on a mobile phone. On-board LED indicates a BLE connection.
  Adapted from Arduino BatteryMonitor example by Peter Milne
#include <ArduinoBLE.h>
#include <Arduino_HTS221.h>
#include <Arduino_LPS22HB.h>
#include <Arduino_APDS9960.h>
const int UPDATE_FREQUENCY = 1000; // Update frequency in ms
const float CALIBRATION_FACTOR = -4.0; // Temperature calibration factor (celcius)
// Declare the variable for irradiance reading.
float irradiance;
long previousMillis = 0;  // last time readings were checked, in ms
BLEService environmentService("181A");  // Standard Environmental Sensing service,Declare Bluetooth service names, and irradiance characteristics.
// BLE Battery Service
BLEService batteryService("180F");
// BLE Battery Level Characteristic
BLEUnsignedCharCharacteristic batteryLevelChar("2A19",  // standard 16-bit characteristic UUID
    BLERead | BLENotify); // remote clients will be able to get notifications if this characteristic changes
BLEIntCharacteristic tempCharacteristic("2A6E",  // Standard 16-bit Temperature characteristic
  BLERead | BLENotify); // Remote clients can read and get updates
BLEUnsignedIntCharacteristic humidCharacteristic("2A6F", // Unsigned 16-bit Humidity characteristic
BLEUnsignedIntCharacteristic pressureCharacteristic("2A6D", // Unsigned 32-bit Pressure characteristic
BLEUnsignedIntCharacteristic irradianceCharacteristic("2A77", BLERead | BLENotify); // 16-bit unsigned, 1 decimal place.
int oldBatteryLevel = 0;  // last battery level reading from analog input
  Serial.begin(9600);    // Initialize serial communication
  //while (!Serial);
  if (!HTS.begin()) {  // Initialize HTS22 sensor
    Serial.println("Failed to initialize humidity temperature sensor!");
    while (1);
  if (!APDS.begin()) {
    Serial.println("Failed.");
    while (1);
  pinMode(LED_BUILTIN, OUTPUT); // Initialize the built-in LED pin
  if (!BLE.begin()) {   // Initialize BLE
    Serial.println("starting BLE failed!");
    while (1);
  BLE.setLocalName("RichoNano33BLESENSE");  // Set name for connection
  BLE.setAdvertisedService(environmentService); // Advertise environment service
  environmentService.addCharacteristic(tempCharacteristic); // Add temperature characteristic
  environmentService.addCharacteristic(humidCharacteristic); // Add humidity chararacteristic
  environmentService.addCharacteristic(pressureCharacteristic); // Add pressure chararacteristic
  // Add characteristic for irradiance.
  environmentService.addCharacteristic(irradianceCharacteristic);
  BLE.addService(environmentService); // Add environment service
  tempCharacteristic.setValue(0); // Set initial temperature value
  humidCharacteristic.setValue(0); // Set initial humidity value
  pressureCharacteristic.setValue(0); // Set initial humidity value
  irradianceCharacteristic.setValue(0); // Set initial irradiance value
  BLE.setAdvertisedService(batteryService); // add the service UUID
  batteryService.addCharacteristic(batteryLevelChar); // add the battery level characteristic
  BLE.addService(batteryService); // Add the battery service
  batteryLevelChar.setValue(oldBatteryLevel); // set initial value for this characteristic
  BLE.advertise();  // Start advertising
  Serial.print("Peripheral device MAC: ");
  Serial.println(BLE.address());
  Serial.println("Waiting for connections...");
  BLEDevice central = BLE.central();  // Wait for a BLE central to connect
  // If central is connected to peripheral
  if (central) {
    Serial.print("Connected to central MAC: ");
    Serial.println(central.address());    // Central's BT address:
    // Turn on the LED to indicate the connection:
    digitalWrite(LED_BUILTIN, HIGH);
    while (central.connected()) {
      // Get reading from sensor and update the charcteristic value.
      if (APDS.colorAvailable()) {
        int red, green, blue, ambient;
        APDS.readColor(red, green, blue, ambient);
        irradiance = (float) ambient/ 2360; // irradiance is converted to Watts per square meter. See datasheet for typical irradiance responsivity. https://docs.broadcom.com/doc/AV02-4191EN
        //Serial.println("Ambient: ");
        //Serial.println(ambient);
      // Delay between updates. (Don't make too long or connections start to timeout.)
      long currentMillis = millis();
      // After UPDATE_FREQUENCY ms have passed, check temperature & humidity
      if (currentMillis - previousMillis >= UPDATE_FREQUENCY) {
        updateReadings();
    // When the central disconnects, turn off the LED
    digitalWrite(LED_BUILTIN, LOW);
    Serial.print("Disconnected from central MAC: ");
int getTemperature(float calibration) {
  // Get calibrated temperature as signed 16-bit int for BLE characteristic
  return (int) (HTS.readTemperature() * 100) + (int) (calibration * 100);
unsigned int getHumidity() {
  // Get humidity as unsigned 16-bit int for BLE characteristic
  return (unsigned int) (HTS.readHumidity() * 100);
unsigned int getPressure() {
    // Get humidity as unsigned 32-bit int for BLE characteristic
    return (unsigned int) (BARO.readPressure() * 1000 * 10);
void updateReadings() {
  // Read the HTS22 temperature and humidity
  int temperature = getTemperature(CALIBRATION_FACTOR);
  unsigned int humidity = getHumidity();
  unsigned int pressure = getPressure();
  int batterylevel = 0;
  int hallsensor = 0;
  float battery = 0;
  float hallsensor_0 = 0;
  batterylevel = analogRead(A0);
  //int batteryLevel = map(battery, 0, 1023, 0, 2.5);
  hallsensor = analogRead(A1);
  hallsensor_0 =  hallsensor * (1.46/805) * 10;
      //battery=analogRead(0);//This divider module will divide the measured voltage by 5, the maximum voltage it can measure is 25V.
    battery = (batterylevel * (2.52/778) * 5 * 10) + 5;
    //int sensitivity = (5.1 - 4.9)/10; // 0.08
    //int current = (Vout-4.9)/0.08;
    Serial.print("Temperature: ");
    Serial.println(temperature);
    tempCharacteristic.writeValue(temperature);  // Update characteristic
    Serial.print("Humidity: ");
    Serial.println(humidity);
    humidCharacteristic.writeValue(humidity);
    Serial.print("Pressure: ");
    Serial.println(pressure);
    pressureCharacteristic.writeValue(pressure);
    Serial.print("Battery Level is: "); // print it
    Serial.println(battery);
    batteryLevelChar.writeValue(battery);  // and update the battery level characteristic
    //oldBatteryLevel = batteryLevel;           // save the level for next comparison
    Serial.println("Irradiance: ");
    Serial.println(irradiance);
    Serial.println("W/sq. meter");
   // Update Bluetooth characteristic with new value.
   irradianceCharacteristic.writeValue((uint16_t) round(irradiance * 10)); // Shift for one decimal place.
   Serial.print("current is: "); // print it
   Serial.println(hallsensor_0);
   Serial.println(hallsensor);
(1) when connected to only power supply using usb cable
(2) battery using usb cable or
(3) connected to pc using usb cable ( with not connecting/logging on to arduino web editor)
The intent is to make it work remotely, so it should be able to work on a battery or some power supply."
Originally posted by Sree, I am also experiencing the same issue. I have removed "while(!Serial)", but the nano BLE SENSE is still not discoverable.
@Rich-o
Your topic was Moved to it's current location / section as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
