Nano fails to receive UDP broadcasted packages
I'm trying to do a send and receive UDP broadcast communication but I'm only successful in sending but not in receiving in the Arduino nano.
Here is the code:
#include <EtherCard.h>
// Test it this way:
//     echo "TEST" | nc -u 192.168.31.255 5005
// Buzzer pin
#define buzzer_pin 3
// Command implementations
void buzz(size_t duration = 5) {
    digitalWrite(buzzer_pin, HIGH);
    delay(duration);
    digitalWrite(buzzer_pin, LOW);
// Network configuration
static byte myMac[]         = { 0x74,0x69,0x69,0x2D,0x30,0x31 };
static byte myIp[]          = { 192,168,31,99 };
static byte netmask[]       = { 255,255,255,0 };
static byte broadcastIP[]   = { 192,168,31,255 }; // Use this instead of 255.255.255.255
#define BUFFER_SIZE 500
byte Ethernet::buffer[BUFFER_SIZE];
const uint16_t UDP_PORT = 5005;
const char* testMessage = "Hello from Nano!";
// Corrected callback
static void udpCallback(uint16_t src_port, uint8_t* src_ip, uint16_t dst_port, const char* data, uint16_t len) {
    Serial.print("UDP from ");
    for (byte i = 0; i < 4; i++) {
        Serial.print(src_ip[i]);
        if (i < 3) Serial.print(".");
    Serial.print(":");
    Serial.print(src_port);
    Serial.print(" -> ");
    Serial.write(data, len);
    buzz(100);
    while (!Serial);
    pinMode(buzzer_pin, OUTPUT);
    buzz();
    if (!ether.begin(BUFFER_SIZE, myMac, 10)) {
        Serial.println("Failed to access ENC28J60");
        while (1);
    if (!ether.staticSetup(myIp, 0, 0, netmask)) {
        Serial.println("Failed to set static IP");
        while (1);
    ether.enableBroadcast();
    ether.udpServerListenOnPort(udpCallback, UDP_PORT);
    Serial.println("Ready. Sending broadcasts...");
    ether.packetLoop(ether.packetReceive());
    static uint32_t lastSend = 0;
    if (millis() - lastSend >= 5000) {
        lastSend = millis();
        ether.sendUdp(testMessage, strlen(testMessage), UDP_PORT, broadcastIP, UDP_PORT);
        Serial.println("Broadcast sent");
        // buzz();
I use a Python code in a PC to send and receive UDP packages that are always received by it, but Arduino nano never receives anything, it is just able to send! Why isn't udpCallback ever being triggered?
Thanks
when using the ethernet-shield-fur-arduino-nano which is based on the ENC28J60 I used the EthernetENC library
Communicated with a Java program on a PC using UDP OK
It was a bad Ethernet cable connection! :upside_down_face:
