nano powered by USB is only putting 4.78V on the 5V output. I get a perfect 5V coming in on the usb port. Is it normal? Does USB power go thru the LDO regulator? If so, I know that there will be some drop from that. But my duemilanove board is putting out 4.94V. Much better.
The other weird thing is when using battery power, with USB disconnected, the 3.3V output is working. I thought it was only powered when USB is connected..?
I wonder if I damaged my nano? its possible, I was a bit careless with it.
