system
December 2, 2011, 11:15pm
1
I need to know what the voltages are coming out of the TTL Converter.
I'm attempting to figure it out with the Nano, but I really don't have a clue what I'm doing.
I'm using HyperTerminal to send data to a piece of hardware that is particular to the voltage levels.
How can I set up a makeshift o-scope? I've seen various Arduino Oscilloscopes but none of them were detailed enough for me to get them to work.
Any help is appreciated.
system
December 4, 2011, 12:14am
2
TTL levels are 5V, usually. As that is a red board, I'm going to guess that you got it (directly or indirectly) from Sparkfun. They usually publish detailed specs on all their products. Have you looked at the sparkfun site for that product and read the materials there?
system
December 4, 2011, 12:12pm
3
I got it off eBay.
The CP2102 Data Sheet shows that the output is 3.3v.
Page 14 / Section 8. Power Regulator / Table 10.
After some discussion on another forum, I also need to know what sort of waveform it produces as well, thus my need to create some form of o'scope to visualize the output.
Thanks for your input.
Note: Link corrected.
You posted a bad link.
I think you miss read it, try again.
It is bog standard TTL communications code, no need to look at it.
Are you on a Mac? If so note that the auto reset function will not work with this chip / mac driver.
system
December 4, 2011, 2:03pm
5
Corrected the link, and I'm using Windows 7 (Intel PC).
Can you provide a link to the "bog standard" that explains in detail why the waveform doesn't matter?
Asynchronous serial communication is a form of serial communication in which the communicating endpoints' interfaces are not continuously synchronized by a common clock signal. Instead of a common synchronization signal, the data stream contains synchronization information in form of start and stop signals, before and after each unit of transmission, respectively. The start signal prepares the receiver for arrival of data and the stop signal resets its state to enable triggering of a new sequ...
Hard to find a link that says why you have no need to look at it but what do you expect to see by looking at it?
Corrected the link,
Well a link that involves you creating an account to just look at it is worst than useless.
system
December 4, 2011, 7:29pm
7
The link is a Google link, no account required.
It is a link to google Docs, it is inviting me to type in my password. I do not have a google docs account nor do I want one.
