Need circuit for DIP switch to turn on 4 LEDs
I have a project where I want a 4 position rotary dip switch (BCD) type to turn on 4 LEDs. The switch will also be connected to 2 Arduino inputs, so I can tell which of the 4 positions is selected.
Switch Switch Pins
Position A B
1 0 0
2 1 0
3 0 1
4 1 1
Pretty simply binary stuff. I want to have 4 LEDs connected to the circuit but I only want one LED to be on at a time. For example, LED1 would come on when switch was in position 1 and the other 3 LEDs would be off. I am not using the Arduino to control the LEDs, I don't have enough I/O available. This is probably pretty easy with some logic circuits but I'm not familiar with designing anything like that. I'd appreciate any help.
And
Are the LEDs to be drive by the switch or the Arduino?
EDIT:
Use a 74HC139 instead of this cct.
Thanks! I can't wait to try out the circuit. The LEDs would be driven by 5v from the Arduino, like you have it in this circuit.
The chip you are after is a (very common) 74HC139. It takes 2 inputs in a binary form and sets one of its outputs low accordingly. Connect each LED between an output and +5V with a suitable resistor each (anode to resistor to 5V, cathode to '139 output), and the switch outputs to th inputs. Connect the /G input to ground, and it should light each LED up for you in sequence.
Yes
74HC139 is 2 to 4, I think he wants 4 to 2.
The switch outputs 2 bit binary according to the truth table he posted. Ergo, he wants 2-to-4 , i.e., 74HC139.
I missed that, yes the 139 is they way to go.
I'll check out that chip. The problem with the circuit above is that in position 4 their would be power to switch pins 2 and 3. There is no pin 4 on the dip switch.
ScottG:
The circuit above looks like it's for converting a standard 4-position switch into a 2-bit BCD switch - not what you're after.
ScottG:
Are you sure? Have you used up the 'analog' pins as well?
So 1 LED for each of the 4 positions, is that right?
If so just use a decoder like the 139 or 138, this is a no-brainer, or have I missed something?
Rob
Graynomad:
Rob
It's a no-brainer if you read the question right in the first place :wink:
I just took a look at the 74HC139 (I never used one), it should do exactly what I need. Thanks.
majenko:
Graynomad:
Rob
2 or 3 more kicks will probably do it :sweat_smile:
@ScottG
Do you have a LINK to the switch you are using?
LarryD:
@ScottG
Digikey 679-1918-ND
Do you need help with the 138/139 wiring?
LarryD:
Nope. I looked at the data sheet, it seems pretty straight forward.
