Need Code Help please
Hey Everyone....I need a little help on this code I'm a newbie but using AI to help me. I'v noticed that the AI's arent always the smartest. What i am needing this code to do is to use a dht22 temp sensor to measure temp and display (st7789 display) it in a gauge that fills the middle of the screen, with an arrow that is animated moving every 1 sec and creating a long tick mark in the color of green for unchanged, red for rise and blue for drop. Then I am using an ultrasonic sensor to measure distance starting at 12 inchs until touching the sensor. I want it in 1 inch increments and i am using timerfreetone to give me a low tone at 12 and increasing in pitch the lower it goes. I also having it display the distance on the screen. The problem is that i want the tones to be smooth and steady as they go up or down and continue to play as long as there is a reading in my parameters. Can anyone help me and please dont judge me for using AI :slight_smile:
here is the full code:
multiple
lines
#include <Adafruit_GFX.h>
#include <Adafruit_ST7789.h>
#include <DHT.h>
#include <NewPing.h>
#include <TimerFreeTone.h>
#define TFT_CS 10
#define TFT_RST 9
#define TFT_DC 8
#define DHTPIN 2
#define DHTTYPE DHT22
#define TRIGGER_PIN 6
#define ECHO_PIN 7
#define PIEZO_PIN 5
#define MAX_DISTANCE 72
DHT dht(DHTPIN, DHTTYPE);
Adafruit_ST7789 tft = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_RST);
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
float lastTemperature = 0;
float smoothedDistance = 0.0;
float smoothingFactor = 0.85;
int lastDistance = -1;  // Track previous distance
#define COLOR_INCREASING ST77XX_RED
#define COLOR_DECREASING ST77XX_BLUE
#define COLOR_STEADY ST77XX_GREEN
  dht.begin();
  tft.init(240, 320);
  tft.setRotation(2);
  tft.fillScreen(ST77XX_BLACK);
  displayTitle();
  float temperature = dht.readTemperature(true);
  uint16_t trendColor = getTrendColor(temperature);
  if (!isnan(temperature)) {
    displayTemperatureGauge(temperature, trendColor);
    displayTemperatureValue(temperature, trendColor);
  updateDistanceAndTone();
void displayTitle() {
  tft.setTextSize(2);
  tft.setTextColor(ST77XX_GREEN);
  int16_t x1, y1;
  uint16_t w, h;
  tft.getTextBounds("Ghost Temp Detector", 0, 0, &x1, &y1, &w, &h);
  tft.setCursor((240 - w) / 2, 10);
  tft.print("Ghost Temp Detector");
  tft.getTextBounds("and RemPod", 0, 0, &x1, &y1, &w, &h);
  tft.setCursor((240 - w) / 2, 40);
  tft.print("and RemPod");
uint16_t getTrendColor(float temperature) {
  uint16_t trendColor = COLOR_STEADY;
    if (temperature > lastTemperature) {
      trendColor = COLOR_INCREASING;
    } else if (temperature < lastTemperature) {
      trendColor = COLOR_DECREASING;
    lastTemperature = temperature;
  return trendColor;
void displayTemperatureGauge(float temperature, uint16_t trendColor) {
  int centerX = 120;
  int centerY = 200;
  int radius = 60;
  int angleStart = 0;
  int angleEnd = 180;
  int needleAngle = map(temperature, 50, 90, angleStart, angleEnd);
  needleAngle = (needleAngle + 180) % 360;
  for (int angle = angleStart; angle <= angleEnd; angle += 10) {
    int rotatedAngle = (angle + 180) % 360;
    int tickColor = (rotatedAngle < needleAngle) ? COLOR_INCREASING : COLOR_DECREASING;
    int xStart = centerX + (radius - 10) * cos(radians(rotatedAngle));
    int yStart = centerY + (radius - 10) * sin(radians(rotatedAngle));
    int xEnd = centerX + radius * cos(radians(rotatedAngle));
    int yEnd = centerY + radius * sin(radians(rotatedAngle));
    tft.drawLine(xStart, yStart, xEnd, yEnd, tickColor);
  int needleX = centerX + (radius - 15) * cos(radians(needleAngle));
  int needleY = centerY + (radius - 15) * sin(radians(needleAngle));
  tft.drawLine(centerX, centerY, needleX, needleY, trendColor);
  tft.fillCircle(centerX, centerY, 3, ST77XX_BLACK);
  tft.drawCircle(centerX, centerY, 4, trendColor);
void displayTemperatureValue(float temperature, uint16_t trendColor) {
  tft.fillRect(80, 105, 80, 20, ST77XX_BLACK);
  tft.setTextColor(trendColor);
  tft.setTextSize(3);
  tft.setCursor(90, 105);
  tft.print(temperature, 1);
  tft.print("F");
void updateDistanceAndTone() {
  int rawDistance = sonar.ping_in();
  if (rawDistance > 0 && rawDistance <= 12) {
    smoothedDistance = (smoothingFactor * smoothedDistance) + ((1 - smoothingFactor) * rawDistance);
  int roundedDistance = (int)smoothedDistance;
  if (roundedDistance != lastDistance) {
    tft.fillRect(10, 280, 220, 20, ST77XX_BLACK);
    tft.setTextColor(ST77XX_YELLOW);
    tft.setTextSize(2);
    tft.setCursor(10, 280);
    if (roundedDistance == 0 || roundedDistance > 12) {
      tft.print("Out of Range");
      TimerFreeTone(PIEZO_PIN, 0, 0);
      tft.print("Distance: ");
      tft.print(roundedDistance);
      tft.print(" in");
      int toneFreq = map(roundedDistance, 12, 1, 300, 1200);
      TimerFreeTone(PIEZO_PIN, toneFreq, 1000);
    lastDistance = roundedDistance;
  delay(5);
ok, We will only judge that have not given a clue as to what the code currently does that you want to change. Does it compile with no errors? Why not tell us which Arduino you are trying to use?
Why bring machine generated stuff to humans to fix when machines can churn endless amounts of stuff, but humans have limited time... and have a life? Do you see the problem?
Format your machine's code. Paste it into a code block.
sorry i was trying to figure out how to edit my post with the code in the right place. The code compiles and works but the AI cant seem to get the tones to work right. I would like it to be a smooth transition from tone to tone and be continuous until the measurements are out of range.
  1. Edit your message
  2. Select and cut your code
  3. Open your IDE (or any online coding tool)
  4. Paste your unformatted code
  5. Format your code (IDE = CTRL-T)
  6. Select and cut your code
  7. In the message, click the <CODE> button
  8. Between the set of ticks```, select the words ```type or paste code here```
  9. Paste your formatted code over the words, between the ticks
Hi, @robman991
Can you tell us what model Ardino are you using?
Tom.... :smiley: :+1: :coffee: :australia:
Yeah sorry....i forgot....its the mega
Thanks!!!
So would it be better to take out the distance display on the display to achieve a smooth tone transition?
@upir_upir on YouTube does good work with displays... here he is making a dial...
