I'm trying to create a project using the A9G GPRS+GPS & an Arduino Nano or Pro Mini. My project is simple. I just want it to SMS reply with a google maps link when I text the word "Location". One reply per request. I'm not very good with the code portion of this, but I'm trying to learn. Usually I can copy code from a similar project & make minor changes to tweak it out to my needs. Most of what I can find online seems to deal with different GPS boards or coded with a lot more bells & whistles. Any help or even just the answer in the form of "the code" will at least help me see what I've been missing. Thanks.
- Are each Arduino (nano/mini) connected to their own A9G? (show your work)
- Can you send an SMS from each Arduino/A9G?
- Can you receive an SMS with each Arduino/A9G?
- Can you send SMS from one Arduino/A9G to the other Arduino/A9G?
- Can you send SMS from "the other" Arduino to "one" Arduino?
(in each step, show code for better assistance)
I'm trying to use either the mini or the nano, not both. I basically started with this guys project,
"Build Low Power SMS Based Vehicle Tracking System with A9G GSM+GPS Module and Arduino", just to see if I could get it to track & because he uses the same module. It did, but now it's not. Hooking up the A9G as a stand alone and giving it "AT" commands, it seems to work, but just not with an Arduino controller. Not sure what I'm missing. Wish I knew more about the code side of this, but as I said, I'm still learning. I can usually pick it up, if I can see the code, but I haven't been able to find a similar project.
What was changed? (his code is displayed in the link, at the bottom)
#include <TinyGPSPlus.h>
#include <SoftwareSerial.h>
static const int RXPin = 6, TXPin = 5;
String s = "www.google.com/maps/dir/";
unsigned long interval = 10000;
static const uint32_t GPSBaud = 9600;
unsigned long previousMillis = 0;
int data_counter;
const size_t BUFSIZE = 300;
char f_buffer[BUFSIZE];
float *f_buf = (float*)f_buffer;
TinyGPSPlus gps;// The TinyGPSPlus object
SoftwareSerial ss(RXPin, TXPin);// The serial connection to the GPS device
ss.begin(GPSBaud);
Serial.println("Starting...");
ss.println("\r");
ss.println("AT\r");
delay(10);
ss.println("\r");
ss.println("AT+GPS=1\r");
delay(100);
ss.println("AT+CREG=2\r");
delay(6000);
//ss.print("AT+CREG?\r");
ss.println("AT+CGATT=1\r");
delay(6000);
ss.println("AT+CGDCONT=1,\"IP\",\"WWW\"\r");
delay(6000);
// ss.println("AT+LOCATION=1\r");
ss.println("AT+CGACT=1,1\r");
delay(6000);
//Initialize ends
//Initialize GPS
ss.println("\r");
//ss.println("AT+GPSMD=1\r"); // Change to only GPS mode from GPS+BDS, set to 2 to revert to default.
ss.println("AT+GPSRD=10\r");
delay(100);
// set SMS mode to text mode
ss.println("AT+CMGF=1\r");
//ss.println("AT+LOCATION=2\r");
Serial.println("Setup Executed");
// if (Serial.available()) { // If anything comes in Serial (USB),
// ss.write(Serial.read()); // read it and send it out ss (pins 0 & 1)
// if (ss.available()) { // If anything comes in ss (pins 0 & 1)
// Serial.write(ss.read()); // read it and send it out Serial (USB)
smartDelay(2000);
if (millis() > 5000 && gps.charsProcessed() < 10)
Serial.println(F("No GPS data received: check wiring"));
if ((unsigned long)(currentMillis - previousMillis) >= interval) {
send_gps_data();
static void smartDelay(unsigned long ms)
unsigned long start = millis();
do
while (ss.available())
gps.encode(ss.read());
} while (millis() - start < ms);
void send_gps_data()
if (gps.location.lat() == 0 || gps.location.lng() == 0)
Serial.println("Return Executed");
return;
data_counter++;
Serial.print("Latitude (deg): ");
f_buf[data_counter] = gps.location.lat();
Serial.println(f_buf[data_counter]);
Serial.print("Longitude (deg): ");
f_buf[data_counter + 1] = gps.location.lng();
Serial.println(f_buf[data_counter + 1]);
Serial.println(data_counter);
s += String(gps.location.lat(), 6);
s += ",";
s += String(gps.location.lng(), 6);
s += "/";
Serial.println(s);
if (data_counter >= 10)
data_counter = 0;
Serial.println("Sending Message");
ss.println("AT+CNMI=2,2,0,0,0\r");
ss.print("AT+CMGS=\"+1xxxxxxxxx\"\r");//Replace this with your mobile number
ss.print(s);
ss.write(0x1A);
