Whyy can't our location tracker send a message to the phone number registered?
hi there everyone! we are new to coding and decided to have a project with arduino pro mini and a gprs where just by texting a number we can get the location of the arduino and gprs. can someone help us point out the problem?
#include <TinyGPSPlus.h>
#include <SoftwareSerial.h>
static const int RXPin = 6, TXPin = 5;
String s = "www.google.com/maps/dir/";
unsigned long interval = 10000;
static const uint32_t GPSBaud = 9600;
unsigned long previousMillis = 0;
int data_counter;
const size_t BUFSIZE = 300;
char f_buffer[BUFSIZE];
float *f_buf = (float*)f_buffer;
TinyGPSPlus gps;// The TinyGPSPlus object
SoftwareSerial ss(RXPin, TXPin);// The serial connection to the GPS device
  ss.begin(GPSBaud);
  Serial.println("Starting...");
  ss.println("\r");
  ss.println("AT\r");
  delay(10);
  ss.println("\r");
  ss.println("AT+GPS=1\r");
  delay(100);
  ss.println("AT+CREG=2\r");
  delay(6000);
  //ss.print("AT+CREG?\r");
  ss.println("AT+CGATT=1\r");
  delay(6000);
  ss.println("AT+CGDCONT=1,\"IP\",\"WWW\"\r");
  delay(6000);
  // ss.println("AT+LOCATION=1\r");
  ss.println("AT+CGACT=1,1\r");
  delay(6000);
  //Initialize ends
  //Initialize GPS
  ss.println("\r");
  //ss.println("AT+GPSMD=1\r");   // Change to only GPS mode from GPS+BDS, set to 2 to revert to default.
  ss.println("AT+GPSRD=10\r");
  delay(100);
  // set SMS mode to text mode
  ss.println("AT+CMGF=1\r");
  //ss.println("AT+LOCATION=2\r");
  Serial.println("Setup Executed");
//    if (Serial.available()) {      // If anything comes in Serial (USB),
//      ss.write(Serial.read());   // read it and send it out ss (pins 0 & 1)
//    if (ss.available()) {     // If anything comes in ss (pins 0 & 1)
//      Serial.write(ss.read());   // read it and send it out Serial (USB)
  smartDelay(2000);
  if (millis() > 5000 && gps.charsProcessed() < 10)
    Serial.println(F("No GPS data received: check wiring"));
  if ((unsigned long)(currentMillis - previousMillis) >= interval) {
    send_gps_data();
static void smartDelay(unsigned long ms)
  unsigned long start = millis();
  do
    while (ss.available())
      gps.encode(ss.read());
  } while (millis() - start < ms);
void send_gps_data()
  if (gps.location.lat() == 0 || gps.location.lng() == 0)
    Serial.println("Return Executed");
    return;
  data_counter++;
  Serial.print("Latitude (deg): ");
  f_buf[data_counter] = gps.location.lat();
  Serial.println(f_buf[data_counter]);
  Serial.print("Longitude (deg): ");
  f_buf[data_counter + 1] = gps.location.lng();
  Serial.println(f_buf[data_counter + 1]);
  Serial.println(data_counter);
  s += String(gps.location.lat(), 6);
  s += ",";
  s += String(gps.location.lng(), 6);
  s += "/";
  Serial.println(s);
  if (data_counter >= 10)
    data_counter = 0;
    Serial.println("Sending Message");
    ss.println("AT+CNMI=2,2,0,0,0\r");
    ss.print("AT+CMGS=\"+639568667219\"\r");//Replace this with your mobile number
    ss.print(s);
    ss.write(0x1A);
Hi, @reseasters
Welcome to the forum.
What is the problem?
Have you written your code in stages to;
Test the GPRS on its own and get it working?
What is ALL your hardware, how are you texting a "number"
Why decide on such an involved project as your first?
Tom.. :smiley: :+1: :coffee: :australia:
You are sort of at the point of a kid given a screwdriver so a jet airplane can be build. You need to follow the same process you did when you started to walk. Baby steps all the way. Start with simple things like lighting LEDs etc and progress from there.
