Hey all!
I have been using an Adafruit OLED display to display data from a bmp180 sensor and I want to display a custom splashscreen for a few seconds when the unit is powered up. In the example sketch for the SSD1305 library there is a default "ADAFRUIT INDUSTRIES" splashscreen but I want to design my own.
I am using the SSD1305 library and Adafruit GFX libraries.
This is the part of the example code that displays the default adafruit splashscreen:
Serial.println("SSD1305 OLED test");
// by default, we'll generate the high voltage from the 3.3v line internally! (neat!)
display.begin();
// init done
display.display(); // show splashscreen
display.clearDisplay(); // clears the screen and buffer
What would the code in the setup() function look like if I wanted to replace the adafruit logo with my own? I am pretty sure I would have to define a bitmap array before the setup and somehow reference it in the setup to display the image but I need help creating the bitmap array for my own image and I am also not sure on how the code should be written to do so.
I am also confused by the example sketch because there is no array in the sketcg that creates the adafruit logo, only this line of code in the setup()
display.display // show splashscreen
Adafruit logo that I want to change to my own:
Condensed Question:
How do I create a bitmap array of an image and how do I integrate it into the code to display its image.
Any help would be very much appreciated
-Skyler
