Need Help for my project
Hello.
I am currently trying to make a fan that only spins if the temperature un the room is lower than the temperature set by the user. Currently, I have the following code :
#include <Adafruit_LiquidCrystal.h>
int tempRead = 0;
float tempVolt = 0;
float tempReal = 0;
Adafruit_LiquidCrystal lcd_1(0);
  pinMode(A0, INPUT);
  pinMode(A1, INPUT);
  pinMode(2, INPUT);
  pinMode(4, INPUT);
  lcd_1.begin(16, 2);
  lcd_1.setBacklight(1);
  lcd_1.print("Voulue :");
  lcd_1.setCursor(0, 1);
  lcd_1.print("Actuelle :");
  // Temp inputting stuff
  lcd_1.setCursor(9, 0);
  lcd_1.print(); // Print the wanted stuff
  // Temp measuring stuff
  int tempRead = analogRead(A1);
  tempVolt = tempRead * 5.0;
  tempVolt = tempVolt / 1024.0;
  tempReal = (tempVolt - 0.5) * 100;
  lcd_1.setCursor(11, 1);
  lcd_1.print(tempReal);
Now, I need to set up two push buttons. One increases the wanted value by one (named userInput) and the other decreases it. But I really don't know how to do that. I've tested multiple things before, such as using
if (digitalRead(plusButtonPin == HIGH) )
  userInput ++;
and
if (digitalRead(minusButtonPin == HIGH) )
  userInput --;
but it doesn't work. Anyone got other ideas ?
buttons are typically connected between the pin and ground, the pin configured as INPUT_PULLUP to use the internal pullup resistor which pulls the pin HIGH and when pressed, the button pulls the pin LOW.
a button press can be recognized by detecting a change in state and becoming LOW and may need to be debounced (e.g. delay (20); )
i think it should be: (digitalRead(minusButtonPin) == HIGH);
Programming Electronics Academy does good work on their videos. Here is another good one on the pushbutton.
Thanks ! It was the tutorial video that helped me.
