esojlem
December 20, 2022, 7:42am
1
Good day i cant add another transmitter to my reciever:
this the basic code for my reciever
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <Wire.h>
RF24 radio(9, 10);
const uint64_t pipe1 = 0xF0F0F0F066;
const uint64_t pipe2 = 0xF0F0F0F062;
struct sensor
float temp;
int hum;
byte sensorNum;
sensor sensorData;
struct sensor2
float temp;
float hum;
sensor2 sensordata2;
radio.printDetails();
radio.begin();
radio.openReadingPipe(2, pipe2);
radio.openReadingPipe(1, pipe1);
radio.setPALevel(RF24_PA_LOW);
radio.setDataRate(RF24_250KBPS);
radio.startListening();
if(radio.available()){
radio.read(&sensorData, sizeof(sensorData));
Serial.println("Sector 1 ");
Serial.println("Temperature ");
Serial.println(sensorData.temp);
Serial.println("Humidity ");
Serial.println(sensorData.hum);}
radio.read(&sensordata2, sizeof(sensor2));
Serial.println("Sector 2");
Serial.println(sensordata2.temp);
Serial.println(sensordata2.hum);
delay(2000);
this the code for my second transmitter
#include <SPI.h>
#include <RF24.h>
#include <DHT.h>
RF24 radio(9, 10); //CN and CSN pins of nrf
DHT dht(2, DHT22);
struct sensor2
float temp;
float hum;
dht.begin();
radio.begin();
radio.openWritingPipe(pipe2);
radio.stopListening();
delay(2000);
sensordata2.temp = dht.readTemperature();
sensordata2.hum = dht.readHumidity();
Serial.println("Humidity: ");
Serial.println("Temperature: ");
radio.write(&sensordata2, sizeof(sensor2));
the result i always get is this
15:34:28.031 -> Sector 1
15:34:28.031 -> Temperature
15:34:28.031 -> 27.80
15:34:28.058 -> Humidity
15:34:28.058 -> 48
15:34:28.058 -> Sector 2
15:34:28.058 -> Temperature
15:34:28.101 -> 0.00
15:34:28.101 -> Humidity
I am just starting to learn about coding, your help would be greatly appreciatedPreformatted text
red_car
December 20, 2022, 7:50am
2
Please post your code inline. Use the code tags (this button </> in the editor).
esojlem
December 20, 2022, 7:53am
3
heyyy thanks for the tip. i have edited it already
red_car
December 20, 2022, 7:55am
4
esojlem:
Thanks.. much easier for anyone trying to help.
So what exactly is your problem?
esojlem
December 20, 2022, 8:00am
5
the second transmitter is displaying zero values. I tried to use different format but the result is always the same the value from transmitter 2 is not showing. the second transmitter is the one with sector 2
15:34:28.058 -> 48
each transmitter work individually when connected to receiver but when together 1 fails
red_car
December 20, 2022, 8:11am
6
esojlem:
If you swap the reading of sensor and sensor2 around then what happens?
Why are the data structures for the 2 sensor different?
They strategy "if one packet is available, read two packets" is bound to fail.
Using a fat 2 seconds delay in a receiver, is likewise unclever.
red_car
December 20, 2022, 8:20am
8
I think you need to be using the sensorData structure and populate the sensorNum field. Then you only need the following...
Serial.println("Sensor ");
Serial.println(sensorData.sensorNum);
esojlem
December 20, 2022, 8:21am
9
the result doesnt change even with same structure so i tried to search for a new format hoping the result will change
esojlem
December 20, 2022, 8:23am
10
any suggestion, what should i try to do?
red_car
11
The problem is that you are read 2 sets of data... but there may only be one received.
Try the code in post #8
The format of the data must be the same.. because you don't know which one you will receive first.
esojlem
December 20, 2022, 9:07am
13
I have tried the post number 8
the result is this
Humidity
46
Sensor
1
Temperature
0.00
Humidity
0
Sensor
0
I have also removed the delay, the second sensor is not registering
red_car
December 20, 2022, 9:09am
14
That is not what I suggested in post 8... get rid of the second radio.read() block. You only need this code ONCE.
esojlem
December 20, 2022, 9:12am
15
ok ok sorry
Temperature
26.80
Humidity
46
Sensor
1
this is the result
Only read a packet, when one is available.
Don't use any delays in a receiver.
To identify the source of the packet,
you can use an identifying field in a common data structure,
or use different pipes, and multiplex by receiving pipe,
or use different sized packets and dynamic payloads, and distinguish by size of the packet.
Using long long as a pipe address, is considered deprecated,
and could point to using an outdated library, or outdated sample code.
red_car
December 20, 2022, 9:20am
17
Have you ever sent something from sensor 2?
and get rid of the delay() in the receiver if you haven't already... it serves no purpose.
esojlem
December 20, 2022, 9:23am
19
okay i will research on packets, payloads, and will try use different pipes, thanks for the input
esojlem
December 20, 2022, 9:24am
20
okay okay i will try and follow your instructions, thanks for the input
esojlem
December 23, 2022, 8:54am
21
heyyy bro i just made it work the problem is one of the module is defective and i followed your advice and use same struction also the one of the problem is the second radio.read(&sensorData, sizeof(sensorData));, the youtube video that i was following use it twice so i use it twice. thanks for your patience and help
