need help, I cant make the code work using serial readstring
int redLed = 9;
int grLed = 10;
int blueLed = 11;
String myColor;
String msg1 = "What color do you want?" ;
pinMode(redLed, OUTPUT);
pinMode(grLed, OUTPUT);
pinMode(blueLed, OUTPUT);
Serial.println(msg1);
while (Serial.available() == 0) {
myColor = Serial.readString();
if (myColor == "green") {
digitalWrite(grLed, HIGH);
digitalWrite(redLed, LOW);
digitalWrite(blueLed, LOW);
if (myColor == "off") {
digitalWrite(grLed, LOW);
if (myColor == "white") {
digitalWrite(redLed, HIGH);
digitalWrite(blueLed, HIGH);
if (myColor == "red") {
if (myColor == "blue") {
if (myColor == "yellow") {
analogWrite(grLed, 255);
analogWrite(redLed, 255);
analogWrite(blueLed, 0);
if (myColor == "orange") {
analogWrite(grLed, 50);
if (myColor == "aqua") {
analogWrite(redLed, 0);
analogWrite(blueLed, 200);
if (myColor == "violet") {
analogWrite(grLed, 0);
analogWrite(redLed, 150);
analogWrite(blueLed, 155);
the Serial.readString() is probably reads the line terminator into the string
try String.startsWith() method, e.g.if (myColor.startsWith("violet"))
The code in this while loop only runs when there is no serial data available
I strongly suspect that you meant
while (Serial.available() != 0)
so that it runs when serial data is available
I think there is a loop waiting for a Serial.available() none zero
Have a look at the examples in Serial Input Basics - simple reliable non-blocking ways to receive data. There is also a parse example to illustrate how to extract numbers from the received text.
...R
I also recommend Robin2's serial input basics. It reads serial data into a null terminated character array and so avoids the potential memory problems when using the String class. Also his methods are not blocking. The readString function is a blocking function.
Read the how to use this forum-please read sticky to see how to properly post code. Remove useless white space and format the code with the IDE autoformat tool (crtl-t or Tools, Auto Format) before posting code.
