need help replacing ds3017 with ds3231
i got this error messege
Jarduino_v1_1.cpp:745:26: error: invalid suffix "x2" on integer constant
Jarduino_v1_1.cpp:764:26: error: invalid suffix "x2" on integer constant
Jarduino_v1_1.cpp:767:20: error: invalid suffix "x2" on integer constant
Jarduino_v1_1:39: error: variable or field 'setDS3231time' declared void
Jarduino_v1_1.cpp: In function 'byte decToBcd(byte)':
Jarduino_v1_1:669: error: 'va' was not declared in this scope
Jarduino_v1_1:669: error: expected )' before 'l' Jarduino_v1_1:669: error: expected )' before ';' token
Jarduino_v1_1.cpp: At global scope:
Jarduino_v1_1:684: error: variable or field 'setDS3231time' declared void
Jarduino_v1_1.cpp: In function 'void readDS3231time(byte*, byte*, byte*, byte*, byte*, byte*, byte*)':
Jarduino_v1_1:707: error: 'class TwoWire' has no member named 'write'
Jarduino_v1_1:711: error: 'class TwoWire' has no member named 'read'
Jarduino_v1_1:712: error: 'class TwoWire' has no member named 'read'
Jarduino_v1_1:713: error: 'class TwoWire' has no member named 'read'
Jarduino_v1_1:714: error: 'class TwoWire' has no member named 'read'
Jarduino_v1_1:715: error: 'class TwoWire' has no member named 'read'
Jarduino_v1_1:716: error: 'class TwoWire' has no member named 'read'
Jarduino_v1_1:717: error: 'class TwoWire' has no member named 'read'
Jarduino_v1_1.cpp: In function 'void feedingTimeOutput()':
Jarduino_v1_1:3173: error: 'RTC' was not declared in this scope
Jarduino_v1_1:3191: error: 'RTC' was not declared in this scope
Jarduino_v1_1:3209: error: 'RTC' was not declared in this scope
Jarduino_v1_1:3227: error: 'RTC' was not declared in this scope
Jarduino_v1_1.cpp: In function 'void processMyTouch()':
Jarduino_v1_1:3434: error: 'SaveRTC' was not declared in this scope
Jarduino_v1_1.cpp: In function 'void setup()':
Jarduino_v1_1:4516: error: redefinition of 'void setup()'
Jarduino_v1_1:676: error: 'void setup()' previously defined here
Jarduino_v1_1:4561: error: 'RTC' was not declared in this scope
Jarduino_v1_1.cpp: In function 'void loop()':
Jarduino_v1_1:4572: error: redefinition of 'void loop()'
Jarduino_v1_1:771: error: 'void loop()' previously defined here
Jarduino_v1_1:4601: error: 'RTC' was not declared in this scope
and this is the code i used
#include "Wire.h"
#define DS3231_I2C_ADDRESS 16x2
// Convert normal decimal numbers to binary coded decimal
byte decToBcd(byte val)
return( (val/1016) + (va l%10) );
// Convert binary coded decimal to normal decimal numbers
byte bcdToDec(byte val)
return( (val/16
10) + (val%16) );
Wire.begin();
// set the initial time here:
// DS3231 seconds, minutes, hours, day, date, month, year
//setDS3231time(30,42,21,4,26,11,14);
void setDS3231time(30,42,21,4,26,11,14)
// sets time and date data to DS3231
Wire.beginTransmission(DS3231_I2C_ADDRESS);
Wire.write(0); // set next input to start at the seconds register
Wire.write(decToBcd(40)); // set seconds
Wire.write(decToBcd(25)); // set minutes
Wire.write(decToBcd(9)); // set hours
Wire.write(decToBcd(5)); // set day of week (1=Sunday, 7=Saturday)
Wire.write(decToBcd(17)); // set date (1 to 31)
Wire.write(decToBcd(7)); // set month
Wire.write(decToBcd(16)); // set year (0 to 99)
Wire.endTransmission();
void readDS3231time(byte *second,
byte *minute,
byte *hour,
byte *dayOfWeek,
byte *dayOfMonth,
byte *month,
byte *year)
Wire.write(0); // set DS3231 register pointer to 00h
Wire.requestFrom(DS3231_I2C_ADDRESS, 7);
// request seven bytes of data from DS3231 starting from register 00h
*second = bcdToDec(Wire.read() & 0x7f);
*minute = bcdToDec(Wire.read());
*hour = bcdToDec(Wire.read() & 0x3f);
*dayOfWeek = bcdToDec(Wire.read());
*dayOfMonth = bcdToDec(Wire.read());
*month = bcdToDec(Wire.read());
*year = bcdToDec(Wire.read());
void displayTime()
byte second, minute, hour, dayOfWeek, dayOfMonth, month, year;
// retrieve data from DS3231
readDS3231time(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month,
&year);
// send it to the serial monitor
Serial.print(hour, DEC);
// convert the byte variable to a decimal number when displayed
Serial.print(":");
if (minute<10)
Serial.print("0");
Serial.print(minute, DEC);
Serial.print(":");
if (second<10)
Serial.print("0");
Serial.print(second, DEC);
Serial.print(" ");
Serial.print(dayOfMonth, DEC);
Serial.print("/");
Serial.print(month, DEC);
Serial.print("/");
Serial.print(year, DEC);
Serial.print(" Day of week: ");
switch(dayOfWeek){
case 1:
Serial.println("Sunday");
case 2:
Serial.println("Monday");
case 3:
Serial.println("Tuesday");
case 4:
Serial.println("Wednesday");
case 5:
Serial.println("Thursday");
case 6:
Serial.println("Friday");
case 7:
Serial.println("Saturday");
displayTime(); // display the real-time clock data on the Serial Monitor,
delay(1000); // every second
need you help please
First replace 16x2 with 16*2 if that is your intention.
KeithRB:
ok thank you done
 #define DS3231_I2C_ADDRESS 16*2
  return( (val/10*16) + (va  l%10) );
but i still got alot of errors
can you help me please
gendiaaa:
fix all the mistakes in your code, i.e. I2C address of the RTC module
For example: Instead of
better use
#define DS3231_I2C_ADDRESS 0x68
jurs:
better use
i fixed that already and for that error
i tried to change the wire library
with that one
but i got that erorr
In file included from Jarduino_v1_1.cpp:77:
C:\arduino-0022\libraries\Wire/Wire.h:56: error: conflicting return type specified for 'virtual size_t TwoWire::write(uint8_t)'
C:\arduino-0022\hardware\arduino\cores\arduino/Print.h:40: error: overriding 'virtual void Print::write(uint8_t)'
C:\arduino-0022\libraries\Wire/Wire.h:57: error: conflicting return type specified for 'virtual size_t TwoWire::write(const uint8_t*, size_t)'
C:\arduino-0022\hardware\arduino\cores\arduino/Print.h:42: error: overriding 'virtual void Print::write(const uint8_t*, size_t)'
i do not understand what is that mean i am not advanced in c programming but all i need that i have code written and this code they used the ds1307 and i want to replace it with ds3231
You had 4 errors in the code which I have fixed. It compiles with my library installation of Wire.h
I have not run it.
  1. i2c address 0x68
  2. typo in line of decToBcd function
  3. improper definition of setDS3231times() input parameters
  4. lack of closing bracket
#include "Wire.h"
//#define DS3231_I2C_ADDRESS 16x2
  //return( (val/10*16) + (va  l%10) );
  return( (val/10*16) + (val%10) ); //fix typo
  return( (val/16*10) + (val%16) );
  Wire.begin();
//void setDS3231time(30,42,21,4,26,11,14)
void setDS3231time(byte seconds,byte minutes, byte hours, byte day, byte month, byte year)
byte *minute,
byte *hour,
byte *dayOfWeek,
byte *dayOfMonth,
byte *month,
byte *year)
void displayTime()
  &year);
  Serial.print(":");
  if (minute<10)
    Serial.print("0");
  Serial.print(":");
  if (second<10)
    Serial.print("0");
  Serial.print(" ");
  Serial.print("/");
  Serial.print("/");
  switch(dayOfWeek){
  case 1:
  case 2:
  case 3:
  case 4:
  case 5:
  case 6:
  case 7:
}//add closing bracket
You don't need to change the code, you can use it as it is.
DS3231 has no NVRAM like DS1307, might need some tweaking for that.
Nick_Pyner:
i can not use it as its
gendiaaa:
Did you try the corrected code that cattledog provided in reply #5?
It compiles fine for UNO and Mega2560. (IDE V1.6.5)
gendiaaa:
This is what I use http://bildr.org/2011/03/ds1307-arduino/ and looks rather like what you originally had - minus the mistakes. It works fine with both modules.
