Yes, i can read from serial port the ir signal.
The motor works with the example code i used.
I don't know how to combine the codes to control the stepper.
I used this for the ir remote reading:
#include <IRremote.h>
int RECV_PIN = 9;
IRrecv irrecv(RECV_PIN);
decode_results results;
irrecv.enableIRIn(); // Start the receiver
if (irrecv.decode(&results))
Serial.println(results.value, HEX);
irrecv.resume(); // Receive the next value
and this one to test the stepper with a4899:
/* Simple Stepper Motor Control Exaple Code
// defines pins numbers
const int stepPin = 3;
const int dirPin = 4;
// Sets the two pins as Outputs
pinMode(stepPin,OUTPUT);
pinMode(dirPin,OUTPUT);
digitalWrite(dirPin,HIGH); // Enables the motor to move in a particular direction
// Makes 200 pulses for making one full cycle rotation
for(int x = 0; x < 200; x++) {
digitalWrite(stepPin,HIGH);
delayMicroseconds(500);
digitalWrite(stepPin,LOW);
delay(1000); // One second delay
digitalWrite(dirPin,LOW); //Changes the rotations direction
// Makes 400 pulses for making two full cycle rotation
for(int x = 0; x < 400; x++) {
delayMicroseconds(1000);
How am i suppose to merge the for just simply move it forward with one button and reverse with another one?
