I am working on an Arducam. I try to use the following code to take image and store in SD card but nothing was found inside after taking image. I don't know where my problem is. Also may I know is it possible to use a smart phone to control the camera to take an image and send the image back to smartphone via bluetooth? Thank you for help.
Hardware:
Arducam shield F
Camera OV 2640
//#include <UTFT.h>
#include <SD.h>
#include <Wire.h>
#include <ArduCAM.h>
#include <avr/pgmspace.h>
#define SD_CS 9
//UTFT(byte model, int RS, int WR, int RD, int CS)
//UTFT myGLCD(ITDB32S,A2,A1,A0,10); // Remember to change the model parameter to suit your display module!
//ArduCAM(byte model,int RS, int WR, int RD, int REG_CS, int FIFO_CS)
ArduCAM myCAM(OV2640,A2,A1,A0,A3,10); // Remember to change the model parameter to suit your canera module!
//Initialize I2C Bus
Wire.begin();
//Switch to FIFO Mode
myCAM.write_reg(ARDUCHIP_TIM, MODE_MASK);
//Set sensor to JPEG mode. Note don't all the camera modules support JPEG mode
myCAM.OV2640_set_format(JPEG);
//Initialize Camera Module
myCAM.InitCAM();
myCAM.OV2640_set_JPEG_size(OV2640_320x240);
//Initialize SD Card
if (!SD.begin(SD_CS))
//while (1); //If failed, stop here
char str[8];
File outFile;
static int k = 0;
uint8_t temp,temp_last;
uint8_t start_capture = 0;
//Wait trigger from shutter buttom
if(myCAM.read_reg(ARDUCHIP_TRIG) & SHUTTER_MASK)
//Wait until buttom released
while(myCAM.read_reg(ARDUCHIP_TRIG) & SHUTTER_MASK);
start_capture = 1;
//Start capture when detect a valid shutter press
if(start_capture)
//Flush the FIFO
myCAM.flush_fifo();
//Start capture
myCAM.start_capture();
if(myCAM.read_reg(ARDUCHIP_TRIG) & CAP_DONE_MASK)
//Construct a file name
k = k + 1;
itoa(k, str, 10);
strcat(str,".jpg");
//Open the new file
outFile = SD.open(str,FILE_WRITE);
if (! outFile)
return;
//Enable FIFO
myCAM.enable_fifo();
//Read the first dummy byte from FIFO
temp = myCAM.read_fifo();
//Read JPEG data from FIFO
while( (temp != 0xD9) | (temp_last != 0xFF) )
temp_last = temp;
//Write image data to file
outFile.write(temp);
//Disable FIFO when all the image data is saved to the file
myCAM.disable_fifo();
//Close the file
outFile.close();
//Clear the capture done flag
myCAM.clear_fifo_flag();
//Clear the start capture flag
start_capture = 0;
A possible issue can always be the power supply, shields as heavy as the Arducam can draw more current than the Arduino can supply.
The comment and code are not in sync, the function continues if there is an error with SD.
you should at least offer some feedback that the code blocks, eg make a loop to blink a LED or so.
if (! outFile)
return;
Similar problem, you provide no feedback there is a failure
so please get your feedback right so you can track the cause of the error.
Thank you for reply. The code posted in fact is the demo from http://www.arducam.com/
I have tried to add Serial.print() to check the error but there is nothing printed out.
I doubt if I need to specify the route of SD card for storage
Try this (not tested) I added some printing to serial. Please set the baud rate to 115200
//#include <UTFT.h>
#include <SD.h>
#include <Wire.h>
#define SD_CS 9
Serial.begin(115200); // <<<<<<<<<<<<<<<<<<<<<<<
Serial.println("Start arducam test");
Wire.begin();
myCAM.InitCAM();
Serial.println("SD.begin");
Serial.println("SD card failed");
Serial.println("SD card success");
Serial.println("End setup");
Serial.print(millis());
Serial.println("\tstart loop");
char str[8];
File outFile;
static int k = 0;
Serial.println("\tWait trigger from shutter buttom");
start_capture = 1;
Serial.println("\tStart capture I");
if(start_capture)
//Flush the FIFO
myCAM.flush_fifo();
//Start capture
k = k + 1;
itoa(k, str, 10);
strcat(str,".jpg");
//Open the new file
if (! outFile)
Serial.println("\tfailure outfile");
return;
Serial.println("\toutfile succes");
//Enable FIFO
uint32_t bytecounter = 0;
bytecounter++;
if (bytecounter % 32 == 0) Serial.print('.');
if (bytecounter % 1024 == 0) Serial.println;
temp_last = temp;
//Close the file
outFile.close();
start_capture = 0;
Thank you for replies.
I feel sorry that I am not sure what the file name is.
I try to create a file "arducam" in SD and declare char str[8]="arducam" but get nothing
coconut:
The file name is built with the variable k, converted to a string, with the string ".jpg"tacked on to it. Thus, your first filename will be "1.jpg". The second will be "2.jpg", and so on.
I tried to create file name "1.jpg" but I still couldn't find captured image.
I tried to add Serial.println(str); but nothing is printed out on serial monitor. I think I need to indicate the SD path in variable str ?
You don'r need to create file name "1.jpg". It's already been generated. Comments in the code
//Construct a file name <---------------- HERE!
k = k + 1; // k was 0, now it's 1
itoa(k, str, 10); // converts k to ASCII
strcat(str,".jpg"); // tavk ".jpg" onto the end of "1"
//Open the new file
Serial.println(outfile); // <----------------- Put this line in to see if you open the file
if (! outFile)
return;
I recommend loading up the "File.ino" sketch in the SD\examples directory, and testing with that . Do not proceed until you get that runnng, and preferably, not until you understand the Files.ino code.
I am trying to capture an image using ArduCam and send it to iPhone.
My method is first capturing an image and then storing in local SD card. After that, send from SD to iPhone.
I try to use the following code to perform the first step. When I press the button to take photo, the output from the Serial Monitor is as below. Also no file is open. Could anyone tell me what the problem is? Thank you.
Start capture I
start loop
#include <UTFT.h>
#include <SD.h>
#include <Wire.h>
#define SD_CS 9
Wire.begin();
myCAM.InitCAM();
while (!SD.begin(SD_CS))
char str[8];
File outFile;
static int k = 0;
start_capture = 1;
if(start_capture)
//Flush the FIFO
myCAM.flush_fifo();
//Start capture
k = k + 1;
itoa(k, str, 10);
strcat(str,".jpg");
//Open the new file
Serial.println(outFile); // <----------------- Put this line in to see if you open the file
if (! outFile)
return;
//Enable FIFO
bytecounter++;
if (bytecounter % 1024 == 0) Serial.println('?');
temp_last = temp;
//Close the file
outFile.close();
start_capture = 0;
The messages on the Serial Monitor are not shown in the order you displayed them. Why should we wade through the code guessing what else you snipped?
Are you really using pins A2, A1, A0 and 10 for two different purposes each?
Thank you for replies. The serial.begin is to set the data rate.
Sorry for the copy and paste comment. I will be careful next time.
"failure outfile" or "outfile succes" are not printed.
Yes, I use pins A2, A1, A0 and 10 for the ArduCAM.
The output :
Start arducam test
SD.begin
SD card success
End setup
405 start loop
405 Wait trigger from shutter buttom
424 Start capture I
446 start loop
463 Wait trigger from shutter buttom
424 Start capture I
446 start loop
504 Start capture I
527 start loop
543 Wait trigger from shutter buttom
585 Start capture I
607 start loop
623 Wait trigger from shutter buttom
