Hi, I am using a Arduino Uno board with a Dynamixel shield to control a dynamixel AX-12A motor. When I upload an example code from the DynamixelShield library, the motor does not operate the code. The motor just rotates indefinitely until I turn off the power. If anyone has experience with using the Dynamixel shield and ax-12a motor, it would be much appreciated.
Hello,
Would you mind sharing which example code you are running? With that information I should be able to help you figure out the root of your issue.
