The problem is function definition is not allowed here before '{' token
asdd.txt (20.5 KB)
asdd.txt (20.5 KB)
If you were giving us the exact compile error, we would have the line number...
but I think the main problem is that your functions are in the
they need to be outside
Kill thisreturn printSeconds;you function is declared void so should not return anything, and why would you want to return a pointer to that function anyway...
Better kill the whole code (this is madness!) and read about for loops, arrays and use a bit of maths etc....
Mazter372:
How did you get to have over 20.51k of code before you discovered this problem?
I suspect you had 20.4k of code that was working and then you made a small change that broke it - what was that change?
Test early and often.
...R
