Hi guys, I'm very new to Arduino and c++ overall. I got a project for school and spent quite a bit of time learning about c++ and Arduino. Basically, I have 4 buttons, each one relates to a different 'goblin class'. No button pressed is 'no goblin detected'. Each class should have its own function, e.g. different colour LED and vibration.
The issue I'm running into is that when a button is pressed, e.g. class 2, the vibration motor just doesn't vibrate at all. I've tried going through my code and am unsure with what the problem is. Below is the code please help.
Joseph Gibson
Goblin Catcher
Oct 2025
//downloads library to control led strip
//define each pin to its corresponding component
#define TEMP_PIN A0
#define VIB_PIN 9
#define LED_PIN 6
//define each button to its specific goblin class
#define gobClass_1 5
#define gobClass_2 4
#define gobClass_3 3
#define gobClass_4 2
//how many LEDs attachted to the aurduino
int LED_COUNT = 8;
//setup for neopixel library
Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800);
//defining what the tempature limits will be
int tempLimit = 35;
int tempWarning = 30;
//creating a variable for goblin class
int goblinClass = 0; //0 = no goblin, 1-4 = different classes
int lastGoblinClass = -1; // stores previous state
Serial.begin(9600); //initialise the serial monitor
strip.begin(); //initialise neo pixel leds
strip.show(); //initialise all pixels to off
//set each button as an input
pinMode(gobClass_1, INPUT_PULLUP);
pinMode(gobClass_2, INPUT_PULLUP);
pinMode(gobClass_3, INPUT_PULLUP);
pinMode(gobClass_4, INPUT_PULLUP);
//sets the vibrating motor as an output
pinMode(VIB_PIN, OUTPUT);
//prints start message
Serial.println(" ");
Serial.println("Goblin Catcher Now Operational");
TempMechanics(); //runs the TempMechanics function over and over again
UpdateGobClass(); //runs the UpdateGobClass function over and over again
//ensures that the "Class" function is only ran if the type of goblin changes
if (goblinClass != lastGoblinClass) {
lastGoblinClass = goblinClass;
HandleClass(goblinClass); //runs the HandleClass function if goblin type changes
void UpdateGobClass() {
/*cycles through all possible buttons if one is detected it changes
the class variables to the detcted class, if no buttons are pressed
then it will stay as 0 (no goblin detected) */
if (digitalRead(gobClass_1) == LOW)
goblinClass = 1;
else if (digitalRead(gobClass_2) == LOW)
goblinClass = 2;
else if (digitalRead(gobClass_3) == LOW)
goblinClass = 3;
else if (digitalRead(gobClass_4) == LOW)
goblinClass = 4;
goblinClass = 0;
void TempMechanics() {
//reading tempature sensor
int TempReading = analogRead(TEMP_PIN); //defining TempReading as the voltage reading from the temp sensor
float TempVolt = TempReading * 5.0 / 1024.0;
float CurTemp = (TempVolt - 0.5) * 100; // TMP36 formula
//overheating condition
if (CurTemp >= tempLimit) {
//prints message if the current tempature exceeds the maximum
Serial.println("Exceeding Safe Tempature");
Serial.print("Current tempature is ");
Serial.print(CurTemp);
Serial.println("deg c");
Serial.println("Shutting down for 10 seconds");
delay(10000); //delays 10 seconds to prevent overheating
//warning condition
else {
if (CurTemp >= tempWarning && CurTemp < tempLimit) {
//prints message warning that it's almost exceeding maximum
Serial.println("Warning almost exceeding tempature limit");
Serial.println("deg C");
void setLEDs(uint8_t r, uint8_t g, uint8_t b) {
//loops through all connect LEDs and sets them to a designated RGB value
for (int i = 0; i < LED_COUNT; i++) {
strip.setPixelColor(i, strip.Color(r, g, b));
strip.show(); //updates all leds
UpdateGobClass();
void blinkLEDs(uint8_t r, uint8_t g, uint8_t b, int onTime, int offTime, int currentClass) {
//allows the rgb values and the time between on and off to be changes
while (goblinClass == currentClass) { //keep blinking till class changes
setLEDs(r, g, b); //turn LEDs on
delay(onTime); //turns on for set time
setLEDs(0, 0, 0); //turn LEDs off
delay(offTime); //turns off for set off time
UpdateGobClass();
void larsonScanner(uint8_t r, uint8_t g, uint8_t b, int delayTime, int currentClass) {
//allows the rgb values to be set and for there to be a larson scanner effect
setLEDs(0, 0, 0); //clear LEDs
strip.setPixelColor(i, strip.Color(r, g, b)); //light one LED
strip.show();
delay(delayTime);
if (goblinClass != currentClass) return; //exit if class changed
for (int i = LED_COUNT - 2; i > 0; i--) {
setLEDs(0, 0, 0);
strip.show();
delay(delayTime);
void vibrateOn() {
digitalWrite(VIB_PIN, HIGH); //turns vibrating motor on
void vibrateOff() {
digitalWrite(VIB_PIN, LOW); //turns vibrating motor off
void vibratePulse(int onTime, int offTime, int repeat, int intensity, int currentClass) {
//allows vibrations to be repeated for set length and set number of times, at a set intensity
for (int i = 0; i < repeat && goblinClass == currentClass; i++) {
analogWrite(VIB_PIN, intensity); //vibrating motor on
delay(onTime); //wait
analogWrite(VIB_PIN, 0); //vibrating motor on
delay(offTime); //wait
void HandleClass(int currentClass) {
//handles actions for when classes are dected
switch (currentClass) {
//searches all cases below and when it finds a match with "current class" runs that code
case 0:
Serial.println("No goblins detected "); //prints message in serial monitor
setLEDs(255, 19, 240); //sets LEDs (pink)
vibrateOff(); //ensures motors turned off
UpdateGobClass();
case 1:
Serial.println("Class 1 goblin detected "); //prints message in serial monitor
blinkLEDs(0, 255, 0, 1500, 1000, 1); //blink (green LEDS, on 1500ms, off 1000ms, class 1)
UpdateGobClass();
case 2:
Serial.println("Class 2 goblin detected "); //prints message in serial monitor
blinkLEDs(255, 255, 0, 1000, 500, 2); //blink (yellow LEDS, on 1000ms, off 500ms, class 2)
vibratePulse(2000, 1000, 2, 64, 2);
UpdateGobClass();
case 3:
Serial.println("Class 3 goblin detected ! "); //prints message in serial monitor
blinkLEDs(255, 92, 0, 500, 300, 3); //blink (orange LEDS, on 500ms, off 300ms, class 3)
vibratePulse(2000, 1000, 3, 128, 3);
UpdateGobClass();
case 4:
Serial.println("CLASS 4 GOBLIN DETECTED ! "); //prints message in serial monitor
larsonScanner(255, 0, 0, 200, 4); //larson scanner (red LEDS, on 200ms, class 4)
vibratePulse(2000, 1000, 4, 255, 4);
UpdateGobClass();
const int motor_pin = 9;
void setup() { // put your setup code here, to run once:
pinMode(motor_pin,OUTPUT);
analogWrite(motor_pin,255);
Serial.println("high");
analogWrite(motor_pin,128);
Serial.println("med");
analogWrite(motor_pin,64);
Serial.println("low");
analogWrite(motor_pin,0);
Serial.println("off");
The last part at the bottom that is between the /* */ is a test code I wrote to test that everything is wired correctly. When I run the test code, the vibrating motor vibrates at different intensities just to confirm it's wired correctly, Ill also attach a picture if the circuit below
