Vibration motor won't work
Hi, I need help in making this vibration motor work for a school project. I can't see what's wrong since I follow YouTube vids and some articles. Here's my code and circuit:
// declare HC-SSR04 sensor
const int trigPin = 3;
const int echoPin = 2;
// declare LED pins
const int LED1 = 12;
const int LED2 = 9;
const int LED3 = 7;
const int LED4 = 4;
// declare vibration motor components
const int button_pin = 5;
const int motor_pin = 13;
int button_state = 0;
// variables for HC-SR04 sensor
int duration = 0;
int distance = 5;
float duration_us, distance_cm;
  pinMode(button_pin, INPUT);
  pinMode(motor_pin, OUTPUT);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  pinMode(LED1, OUTPUT);
  pinMode(LED2, OUTPUT);
  pinMode(LED3, OUTPUT);
  pinMode(LED4, OUTPUT);
  long duration, inches, cm;
  // Trigger the sensor
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echoPin, HIGH);
  cm = microsecondsToCentimeters(duration);
  distance_cm = cm; // Store calculated distance
  // Print the measured distance
  Serial.print("Distance: ");
  Serial.print(distance_cm);
  Serial.println(" cm");
  // Control the button
  if(digitalRead(button_pin) == HIGH){ // if the button is pressed
    digitalWrite(motor_pin, HIGH); // turn the vibration motor on
  else if (digitalRead(button_pin) == LOW){ // if the button is not pressed
    digitalWrite(motor_pin, LOW); // turn the LED off
  // vibration motor
  button_state = digitalRead(button_pin);
  if (button_state == HIGH){ // turn the motor on when button is on
    Serial.println("Motor ON");
  } else if (button_state == LOW){ // if button is off
    digitalWrite(motor_pin, LOW); // turn motor off
    Serial.println("Motor OFF");
  // Control LEDs based on distance
  if (distance_cm >= 15 && distance_cm < 40) {
    digitalWrite(LED1, HIGH);
    digitalWrite(LED2, HIGH);
    digitalWrite(LED3, HIGH);
    digitalWrite(LED4, HIGH);
  } else if (distance_cm < 15) {
    digitalWrite(LED1, LOW);
    digitalWrite(LED2, LOW);
    digitalWrite(LED3, LOW);
    digitalWrite(LED4, LOW);
    delay(100);
// Function to convert microseconds to centimeters
long microsecondsToCentimeters(long microseconds) {
  return microseconds / 29 / 2;
From your picture it appears you have a TO220 device driving your motor? What is it and draw its circuit in schematic form.
There is no vibration motor in your schematic.
You're feeding 4.5V into the Arduino's 5V pin. That's borderline possible. At least until that USB connector is inserted at which point your circuit try to feed 5V into the 3 AAs. That won't end well.
Your HC-SR04 isn't hooked up to anything. Except possibly the 4.5/5V line. All the pins.
There's no gate resistor between your Arduino's output and the N channel MOSFET's gate.
  • Also, motors require a kickback diode.
