Hi!
I have a question regarding stepper motors and drivers for my project. I am considering to purchase the 125oz.in stepper motor from Sparkfun (Stepper Motor - 125 oz.in (200 steps/rev, 600mm Wire) - ROB-13656 - SparkFun Electronics) and power it using the Big Easy-driver.
It is rated 3V at 2A/phase and have a suitable holding torque for my application. The rated values correspond to 1.5ohm/phase. Based on what I have learned from other threads, it is the current rating that is key, and the voltage rating is not all that important. According to the data sheet, the BED can feed a maximum of 1.4amp/phase, which is well below the 2A/phase motor rating. If I power the BED with 12V and the stepper phase resistance is 1.5ohm, this should correspond to 2,4amp/phase - - well above the maximum output of the BED. Then, if I turn the current limiting pot of the BED to max (1.4amp), what wil happen to the torque of the motor? Will it still be able to provide 125oz.in? Would I need a heat sink to cool the BED? Any other implications? I am really unsure, and have tried to figure it out by searching.
I.e. - - will the "weaker" 12V / 0,33a/phase (rated) motor performed better in terms of torque if I power it with a BED at 12v and limited current supply to motor maximum?
Probably not the best question ever asked, but then again I am a beginner ![]()
Thanks in advance!
Best regards,
Aleksander Hansen
