Hi folks I am trying to connect multiple i2c displays towards arduino mega 2560
I have got following sketch below:
then I wrote following program to scan for devices within the multiplexor:
#include "Wire.h"
#define TCAADDR 0x70
void tcaselect(uint8_t i) {
if (i > 7) return;
Wire.beginTransmission(TCAADDR);
Wire.write(1 << i);
Wire.endTransmission();
// standard Arduino setup()
Wire.begin();
Serial.println("\nTCA9548A Scanner ready!");
for (uint8_t t = 0; t < 8; t++) {
tcaselect(t);
Serial.print("TCA Port #"); Serial.println(t);
for (uint8_t addr = 0; addr <= 127; addr++) {
// Don't report on the TCA9548A itself!
if (addr == TCAADDR) continue;
// See whether a device is on this address
Wire.beginTransmission(addr);
// See if something acknowledged the transmission
int response = Wire.endTransmission();
if (response == 0) {
Serial.print("Found I2C 0x"); Serial.println(addr, HEX);
// Slow the loop scanner down a bit
Serial.println("\nScan completed.");
the output is:
TCA Port #0
TCA Port #1
TCA Port #2
Found I2C 0x27
TCA Port #3
TCA Port #4
TCA Port #5
TCA Port #6
TCA Port #7
its correct that is my display.
(I will connect more displays once I know this one is working)
now I need help with the code part for the multiplexor.
How can I display "Hello World" on this display?
my atempt is:
#include "Wire.h" // For I2C
#include "LCD.h" // For LCD
#include "LiquidCrystal_I2C.h" // Added library*
//Set the pins on the I2C chip used for LCD connections
//ADDR,EN,R/W,RS,D4,D5,D6,D7
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Set the LCD I2C address
lcd.begin(20,4);
lcd.setCursor(3,0);
lcd.print("Hello World!");
lcd.setCursor(8,1);
lcd.print("****");
lcd.setCursor(0,2);
lcd.print("This is a demo text");
lcd.setCursor(8,3);
lcd.print("****");
I believe I need to invoke that
SDA2 and SCL2 somehow but how?
I believe I need to do something similar like
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
// Select I2C BUS
void TCA9548A(uint8_t bus){
Wire.beginTransmission(0x70); // TCA9548A address
Wire.write(1 << bus); // send byte to select bus
Serial.print(bus);
// Start I2C communication with the Multiplexer
Wire.begin();
// Init OLED display on bus number 2
TCA9548A(2);
if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
Serial.println(F("SSD1306 allocation failed"));
for(;;);
// Clear the buffer
display.clearDisplay();
// Init OLED display on bus number 3
TCA9548A(3);
for(;;);
// Clear the buffer
// Init OLED display on bus number 4
TCA9548A(4);
for(;;);
// Clear the buffer
// Init OLED display on bus number 5
TCA9548A(5);
for(;;);
// Clear the buffer
// Write to OLED on bus number 2
TCA9548A(2);
display.setTextSize(8);
display.setTextColor(WHITE);
display.setCursor(45, 10);
// Display static text
display.println("1");
display.display();
// Write to OLED on bus number 3
TCA9548A(3);
display.println("2");
display.display();
// Write to OLED on bus number 4
TCA9548A(4);
display.println("3");
display.display();
// Write to OLED on bus number 5
TCA9548A(5);
display.println("4");
display.display();
I have been looking little bit on this tutorial TCA9548A I2C Multiplexer: ESP32, ESP8266, Arduino | Random Nerd Tutorials
but you people who knows. any suggestions?
Thank you
