Multiplex two SSD1306 OLED I2C Displays using TCA9548A
Hello - I am trying to understand how multiplexing with TCA9548A works, I2C and how I can send data from different sensors to two OLED displays that have the same fixed address 0x3c. I am using a Feather M4 board as a master and 2 ADAFRUIT 128 x 32 displays and wired them up to a TCA9548A multiplexer (see image attached)
I ran a multiplexer scan to confirm everything is wired up right and printed results in serial monitor
TCAScanner ready!
TCA Port #0
Found I2C 0x3C
TCA Port #1
Found I2C 0x3C
TCA Port #2
TCA Port #3
TCA Port #4
TCA Port #5
TCA Port #6
TCA Port #7
done
Here is the code that I sort of cobbled from different examples but none basic enough to do a simple test. I have seen some with BME sensors and a large number of OLEDs and LCDs - but no success yet
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
#define OLED_RESET     -1 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3C ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32
#define TCAADDR 0x70
Adafruit_SSD1306 display1(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
Adafruit_SSD1306 display2(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
// Helper function for changing TCA output channel
void tcaselect(uint8_t channel) {
  if (channel > 7) return;
  Wire.beginTransmission(TCAADDR);
  Wire.write(1 << channel);
  Wire.endTransmission();
  Serial.println(("Start"));
  Wire.begin();
  tcaselect(0);
  delay(2000);
  display1.clearDisplay();
  display1.setTextSize(1);
  display1.setTextColor(WHITE);
  display1.setCursor(0, 10);
  tcaselect(1);
  delay(2000);
  display2.clearDisplay();
  display2.setTextSize(1);
  display2.setTextColor(WHITE);
  display2.setCursor(0, 10);
  // Display static text
  display1.println("Hello, world!");
  display1.display();
  display2.println("Hello, world!");
  display2.display();
The code compiles and uploads - results below
Sketch uses 22676 bytes (4%) of program storage space. Maximum is 507904 bytes.
Device       : ATSAMD51x19
Version      : v1.1 [Arduino:XYZ] May 17 2020 17:56:23
Address      : 0x0
Pages        : 1024
Page Size    : 512 bytes
Total Size   : 512KB
Planes       : 1
Lock Regions : 32
Locked       : none
Security     : false
BOD          : false
BOR          : true
Write 22948 bytes to flash (45 pages)
[==============================] 100% (45/45 pages)
Done in 0.273 seconds
Verify 22948 bytes of flash
Verify successful
Done in 0.554 seconds
But there is no display (I did test both displays individually using the Arduino examples and they work fine). I suspect my code might need a little help
Thank you!
You need to use the tcaselect call in your loop function too.
I do not see any calls to begin() for the displays.
Thanks for the generous support and tips. While waiting for responses - I continued looking around and found an example code at RandomNerdsTutorials.com. This was almost exactly what I was looking for so I modified it for my setup using 128 x 32 OLEDs instead of 128 x 64 OLEDS
I am providing this here for others who may be looking for this example as well
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
  Serial.print(TCAADDR);
  // Start I2C communication with the Multiplexer
  Wire.begin();
  // Init OLED display on bus number 0
  tcaselect(0);
  if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
    Serial.println(F("SSD1306 allocation failed"));
    for(;;);
   // Clear the buffer
  display.clearDisplay();
  // Init OLED display on bus number 1
   tcaselect(1);
    for(;;);
  // Clear the buffer
  // Write to OLED on bus number 0
  tcaselect(0);
  display.setTextSize(1);
  display.setTextColor(WHITE);
  display.setCursor(0, 8);
  display.println("Hello World Disp 0");
  display.display();
  // Write to OLED on bus number 1
  tcaselect(1);
  display.println("Hello World Disp 1");
  display.display();
Here is the result
One thing I learned is that I only needed to define the display once instead of one for each display and use the MUX address to print individualized messages for each display.
Now I can add different sensors or display different sensor attributes to each display next! I will post next time!
