Me and my teammate are going to make a alarm clock with DS3231, LCD 1602-I2C, buzzer with arduino uno.
Individually, we have make 2 part of code work. The first one is the lcd showing the real time clock. The second one is the buzzer beep every 1 minute. However, when we combine 2 codes together, there are error "'clock' was not declared in this scope" starting from
a2 = clock.getAlarm2();
We dont know whether we can combine the code like this.
Can anyone help or any suggestion?Thanks!
#include <Wire.h>
#include <RTClib.h>
#include <LiquidCrystal_I2C.h> // Include the LiquidCrystal_I2C library
#define alarm1Pin 2
RTC_DS3231 rtc; // Create an instance of the RTC_DS3231 class
LiquidCrystal_I2C lcd(0x27, 16, 2); // Initialize the I2C LCD with its address (0x27 for most displays) and dimensions (16x2)
pinMode(alarm1Pin, OUTPUT);
lcd.begin(); // Initialize the LCD
lcd.backlight(); // Turn on the backlight (if available on your display)
lcd.clear(); // Clear the LCD
lcd.setCursor(0, 0); // Set the cursor to the top-left corner
lcd.print("Initializing...");
Wire.begin();
if (!rtc.begin()) {
Serial.println("Couldn't find RTC");
while (1);
// Uncomment the following lines to set the initial date and time if needed
rtc.adjust(DateTime(__DATE__, __TIME__));
clock.armAlarm1(false);
clock.armAlarm2(false);
clock.clearAlarm1();
clock.clearAlarm2();
clock.setAlarm2(0, 0, 1, 0, DS3231_EVERY_MINUTE);
clock.setAlarm2(0, 0, 1, DS3231_MATCH_M);
checkAlarms();
void checkAlarms()
RTCAlarmTime a1;
RTCAlarmTime a2;
if (clock.isArmed1())
a1 = clock.getAlarm1();
Serial.print("Alarm1 is triggered ");
switch (clock.getAlarmType1())
case DS3231_EVERY_SECOND:
Serial.println("every second");
case DS3231_MATCH_S:
Serial.print("when seconds match: ");
Serial.println(clock.dateFormat("__ __:__:s", a1));
case DS3231_MATCH_M_S:
Serial.print("when minutes and sencods match: ");
Serial.println(clock.dateFormat("__ __:i:s", a1));
case DS3231_MATCH_H_M_S:
Serial.print("when hours, minutes and seconds match: ");
Serial.println(clock.dateFormat("__ H:i:s", a1));
case DS3231_MATCH_DT_H_M_S:
Serial.print("when date, hours, minutes and seconds match: ");
Serial.println(clock.dateFormat("d H:i:s", a1));
case DS3231_MATCH_DY_H_M_S:
Serial.print("when day of week, hours, minutes and seconds match: ");
Serial.println(clock.dateFormat("l H:i:s", a1));
default:
Serial.println("UNKNOWN RULE");
} else
Serial.println("Alarm1 is disarmed.");
if (clock.isArmed2())
Serial.print("Alarm2 is triggered ");
switch (clock.getAlarmType2())
case DS3231_EVERY_MINUTE:
Serial.println("every minute");
case DS3231_MATCH_M:
Serial.print("when minutes match: ");
Serial.println(clock.dateFormat("__ __:i:s", a2));
case DS3231_MATCH_H_M:
Serial.print("when hours and minutes match:");
Serial.println(clock.dateFormat("__ H:i:s", a2));
case DS3231_MATCH_DT_H_M:
Serial.print("when date, hours and minutes match: ");
Serial.println(clock.dateFormat("d H:i:s", a2));
case DS3231_MATCH_DY_H_M:
Serial.println("when day of week, hours and minutes match: ");
Serial.print(clock.dateFormat("l H:i:s", a2));
default:
} else
Serial.println("Alarm2 is disarmed.");
// Read the current date and time from the DS3231
DateTime now = rtc.now();
// Clear the LCD
lcd.clear();
// Print the date and time on the LCD
lcd.print("Date: ");
lcd.print(now.year(), DEC);
lcd.print("/");
printTwoDigits(now.month());
lcd.print("/");
printTwoDigits(now.day());
lcd.setCursor(0, 1); // Set the cursor to the second row
lcd.print("Time: ");
printTwoDigits(now.hour());
lcd.print(":");
printTwoDigits(now.minute());
lcd.print(":");
printTwoDigits(now.second());
lcd.print(" ");
// Print the same information to Serial
Serial.print("Current Date: ");
Serial.print(now.year(), DEC);
Serial.print("/");
Serial.print("/");
Serial.print(" Current Time: ");
Serial.print(":");
Serial.print(":");
delay(1000); // Update every 1 second
void printTwoDigits(int number) {
if (number < 10) {
lcd.print("0"); // Print a leading zero for single-digit numbers
lcd.print(number);
