Arduino Alarm Clock using Ds3231 and I2C Lcd Display
Hello, this is my first post in this forum, any forum actually, so I am very sorry If I make mistakes. I have a code for a school project but no matter how many times I modify the code, error messages still come up and I do not know how to fix them. Can someone please help me?
THE CODE IS:
#include <Wire.h>
#include <DS3231.h>
// Set the LCD address to 0x3F for a 16 chars and 2 line display
LiquidCrystal_I2C lcd(0x3F, 16, 2);
DS3231 rtc; // Initialize DS3231 instance
int Hour;
int Min;
int pset = 8; // Pushbutton for setting alarm
int phour = 9; // Pushbutton for hour
int pmin = 10; // Pushbutton for minutes
int pexit = 11; // Pushbutton for exit of set alarm
int buzzer = 6;
int h = 0; // Initialize alarm hour
int m = 0; // Initialize alarm minute
int buttonforset = 0; // Pushbutton state for setting alarm
int buttonforhour = 0; // Pushbutton state for hour
int buttonformin = 0; // Pushbutton state for minutes
int buttonforexit = 0; // Pushbutton for exit of set alarm
int activate = 0;
  pinMode(pset, INPUT);
  pinMode(phour, INPUT);
  pinMode(pmin, INPUT);
  pinMode(pexit, INPUT);
  pinMode(buzzer, OUTPUT);
  // Initialize LCD
  lcd.begin();
  lcd.backlight();
  // Set the RTC date and time if necessary
  rtc.setClockMode(false); // Use 24-hour mode
  if (rtc.getYear() == 0) {
    rtc.setYear(25);      // Year (last two digits)
    rtc.setMonth(1);      // Month
    rtc.setDate(17);      // Day
    rtc.setHour(4);       // Hour
    rtc.setMinute(51);    // Minute
    rtc.setSecond(30);    // Second
  bool h12, PM_time, Century;
  Hour = rtc.getHour(h12, PM_time); // Retrieve hour
  Min = rtc.getMinute();           // Retrieve minute
  if (activate == 0) {
    lcd.setCursor(0, 0);
    lcd.print("Time: ");
    lcd.setCursor(6, 0);
    if (Hour < 10) lcd.print('0'); // Add leading zero
    lcd.print(Hour);
    lcd.print(":");
    if (Min < 10) lcd.print('0'); // Add leading zero
    lcd.print(Min);
    lcd.setCursor(0, 1);
    lcd.print("Date: ");
    lcd.setCursor(6, 1);
    lcd.print(2000 + rtc.getYear()); // Add 2000 to get the full year
    lcd.print("-");
    if (rtc.getMonth(Century) < 10) lcd.print('0'); // Add leading zero
    lcd.print(rtc.getMonth(Century));
    lcd.print("-");
    if (rtc.getDate() < 10) lcd.print('0'); // Add leading zero
    lcd.print(rtc.getDate());
    buttonforset = digitalRead(pset);
  // Setting button pressed
  if (buttonforset == HIGH) {
    activate = 1;
    lcd.clear();
    delay(200);
  while (activate == 1) {
    lcd.print("Set Alarm");
    lcd.print("Hour= ");
    lcd.setCursor(9, 1);
    lcd.print("Min= ");
    buttonforhour = digitalRead(phour); // Set hour for alarm
    if (buttonforhour == HIGH) {
      h++;
      if (h > 23) h = 0;
      lcd.setCursor(5, 1);
      lcd.print(h < 10 ? "0" : ""); // Add leading zero
      lcd.print(h);
      delay(200);
    buttonformin = digitalRead(pmin); // Set minutes for alarm
    if (buttonformin == HIGH) {
      m++;
      if (m > 59) m = 0;
      lcd.setCursor(13, 1);
      lcd.print(m < 10 ? "0" : ""); // Add leading zero
      lcd.print(m);
      delay(200);
    buttonforexit = digitalRead(pexit); // Exit from set alarm mode
    if (buttonforexit == HIGH) {
      activate = 0;
      lcd.clear();
      delay(200);
    lcd.print(h);
    lcd.print(m);
  // Check if it's time to trigger the alarm
  if (Hour == h && Min == m) {
    tone(buzzer, 400, 300); // Trigger buzzer for 300 ms
    delay(500); // Wait before checking again
THE ERROR MESSAGES ARE:
C:\Users\romhe\AppData\Local\Temp\ccbs8WzA.ltrans0.ltrans.o: In function `global constructors keyed to 65535_0_sketch_jan17a.ino.cpp.o.1990':
<artificial>:(.text.startup+0x32): undefined reference to `LiquidCrystal_I2C::LiquidCrystal_I2C(unsigned char, unsigned char, unsigned char, unsigned char)'
C:\Users\romhe\AppData\Local\Temp\ccbs8WzA.ltrans0.ltrans.o: In function `setup':
C:\Users\romhe\AppData\Local\Temp\.arduinoIDE-unsaved2025017-13656-1o6e972.u2zu\sketch_jan17a/sketch_jan17a.ino:33: undefined reference to `LiquidCrystal_I2C::begin()'
C:\Users\romhe\AppData\Local\Temp\.arduinoIDE-unsaved2025017-13656-1o6e972.u2zu\sketch_jan17a/sketch_jan17a.ino:34: undefined reference to `LiquidCrystal_I2C::backlight()'
C:\Users\romhe\AppData\Local\Temp\ccbs8WzA.ltrans0.ltrans.o: In function `loop':
C:\Users\romhe\AppData\Local\Temp\.arduinoIDE-unsaved2025017-13656-1o6e972.u2zu\sketch_jan17a/sketch_jan17a.ino:54: undefined reference to `LiquidCrystal_I2C::setCursor(unsigned char, unsigned char)'
C:\Users\romhe\AppData\Local\Temp\.arduinoIDE-unsaved2025017-13656-1o6e972.u2zu\sketch_jan17a/sketch_jan17a.ino:56: undefined reference to `LiquidCrystal_I2C::setCursor(unsigned char, unsigned char)'
C:\Users\romhe\AppData\Local\Temp\.arduinoIDE-unsaved2025017-13656-1o6e972.u2zu\sketch_jan17a/sketch_jan17a.ino:63: undefined reference to `LiquidCrystal_I2C::setCursor(unsigned char, unsigned char)'
C:\Users\romhe\AppData\Local\Temp\.arduinoIDE-unsaved2025017-13656-1o6e972.u2zu\sketch_jan17a/sketch_jan17a.ino:65: undefined reference to `LiquidCrystal_I2C::setCursor(unsigned char, unsigned char)'
C:\Users\romhe\AppData\Local\Temp\.arduinoIDE-unsaved2025017-13656-1o6e972.u2zu\sketch_jan17a/sketch_jan17a.ino:80: undefined reference to `LiquidCrystal_I2C::clear()'
C:\Users\romhe\AppData\Local\Temp\.arduinoIDE-unsaved2025017-13656-1o6e972.u2zu\sketch_jan17a/sketch_jan17a.ino:85: undefined reference to `LiquidCrystal_I2C::setCursor(unsigned char, unsigned char)'
C:\Users\romhe\AppData\Local\Temp\.arduinoIDE-unsaved2025017-13656-1o6e972.u2zu\sketch_jan17a/sketch_jan17a.ino:87: undefined reference to `LiquidCrystal_I2C::setCursor(unsigned char, unsigned char)'
C:\Users\romhe\AppData\Local\Temp\.arduinoIDE-unsaved2025017-13656-1o6e972.u2zu\sketch_jan17a/sketch_jan17a.ino:89: undefined reference to `LiquidCrystal_I2C::setCursor(unsigned char, unsigned char)'
C:\Users\romhe\AppData\Local\Temp\.arduinoIDE-unsaved2025017-13656-1o6e972.u2zu\sketch_jan17a/sketch_jan17a.ino:96: undefined reference to `LiquidCrystal_I2C::setCursor(unsigned char, unsigned char)'
C:\Users\romhe\AppData\Local\Temp\.arduinoIDE-unsaved2025017-13656-1o6e972.u2zu\sketch_jan17a/sketch_jan17a.ino:106: undefined reference to `LiquidCrystal_I2C::setCursor(unsigned char, unsigned char)'
C:\Users\romhe\AppData\Local\Temp\.arduinoIDE-unsaved2025017-13656-1o6e972.u2zu\sketch_jan17a/sketch_jan17a.ino:115: undefined reference to `LiquidCrystal_I2C::clear()'
C:\Users\romhe\AppData\Local\Temp\.arduinoIDE-unsaved2025017-13656-1o6e972.u2zu\sketch_jan17a/sketch_jan17a.ino:119: undefined reference to `LiquidCrystal_I2C::setCursor(unsigned char, unsigned char)'
C:\Users\romhe\AppData\Local\Temp\.arduinoIDE-unsaved2025017-13656-1o6e972.u2zu\sketch_jan17a/sketch_jan17a.ino:122: undefined reference to `LiquidCrystal_I2C::setCursor(unsigned char, unsigned char)'
collect2.exe: error: ld returned 1 exit status
exit status 1
Compilation error: exit status 1
How did you install the LiquidCrystal_I2C library? It would appear at first glance from those error messages that you've simply downloaded the header file rather than install the library in the usual fashion.
Maybe this is the problem, I went to a Github page and instead of downloading the whole zip I instead downloaded one file. Thanks! I will try this now.
No maybe about it. That is the problem.
Learn how to install additional libraries in the Arduino IDE 1.
Thanks for the help.
