Need more gnd pins
I have a problem i made a Steering wheel using unojoy but i want to add more buttons (for nitros etc) but my arduino board contains only 3 GND pins i want extra 6 GND pins for my project i am not finding any way to solve this problem pls help if you know the solution.
For prototyping use a breadboard
For a more permanent installation use stripboard and solder connections to it
For a real solution use a PCB and no plug and socket connections
i tried using a breadboard i searched everywhere on the internet its not working can you pls tell the connections for breadboard connection.
Note how all the breadboard connections joined by a solid line (red, blue or green) are connected together electrically either along the breadboard or shorter 5 hole connections across the breadboard
Connect a GND pin from your Arduino to one of the long blue series of sockets in the picture then connect all other GND connections to that same blue series of sockets
you can use something like this
Or better still these
Note that some full size solderless breadboards have the power rails spit in the middle. To make the rails continuous, jumpers are required.
thank you very much guys this was helpfull.
