Need some help combining RTC values into single int
I am trying to concatenate the year month and day from the RTC values of now.year(), now.month(), and now.day().
I want combine the now.year(), now.month(),now.day() to end up with "20180717"
 * Arduino Clock with Coloer SPI oled
 * Tempature reading that changes color based on tempature
 * Battery level that changes color based on capasity
 * ToDo: Add Menu, Add alarm saved to eprom
 * BY: C4PT41ND34DP00L
 * sclk = 13
 * data = 11
 * cd =    8
 * cs =   10
 * reset = 9
 * Bat = A1 (if 5v arduino must connect + of bat to A1 before any boost converter)
 * TMP36 = A0
 * DS3113
 * GND = GND
 * VCC = 5V
 * SDA = A4
 * SCL = A5
#include <SPI.h>
#include "Ucglib.h"
#include <Wire.h>
#include "RTClib.h"
#include <Battery.h>
//#include <SFE_BMP180.h>
// Setup RTC
RTC_DS1307 RTC;
char monthString[37] = {"JanFebMarAprMayJunJulAugSepOctNovDec"};
int  monthIndex[122] = {0, 3, 6, 9, 12, 15, 18, 21, 24, 27, 30, 33};
//Setup bat mon (Min Voltage, Max Voltage, Sinsor pin)
Battery battery(3000, 4200, A1);
Ucglib_SSD1331_18x96x64_UNIVISION_SWSPI ucg(/*sclk=*/ 13, /*data=*/ 11, /*cd=*/ 8, /*cs=*/ 10, /*reset=*/ 9);
//TMP36 Pin Variables
boolean useTMP36 = true;  // set this to false if you don not use TMP36
//boolean useTMP36 = false;
#define aref_voltage 1.1 // we tie to teh internal ref (1.1 V)
int tempPin = 0; //the analog pin that the TMP36's Vout (sense) pin is connected to
//the resolution is 10 mV / degree centigrade with a
//500 mV offset to allow for negative temperatures
int tempReading; // the analog reading from the sensor
void setup(void)
  analogReference(INTERNAL);
  Wire.begin();
  RTC.begin();
  if (! RTC.isrunning()) {
    Serial.println("RTC is NOT running!");
    // following line sets the RTC to the date & time this sketch was compiled
    RTC.adjust(DateTime(__DATE__, __TIME__));
  ucg.begin(UCG_FONT_MODE_TRANSPARENT);
  battery.begin(3700, 1.0); //Set first number to batteries mV
  // init done
  ucg.clearScreen();
void loop(void)
  DateTime now = RTC.now();
  ucg.setFontMode(UCG_FONT_MODE_SOLID);
  ucg.setColor(0, 204, 0, 204);
  ucg.setColor(1, 0, 0, 0);
  ucg.setFont(ucg_font_04b_03b_hf);
  ucg.setPrintPos(25, 60);
  for (int i = 0; i <= 2; i++) {
    ucg.print(monthString[monthIndex[now.month() - 1] + i]);
  ucg.print('/');
  ucg.print(now.day(), DEC);
  ucg.print('/');
  ucg.print(now.year(), DEC);
  // display time in digital format
  ucg.setColor(0, 255, 255, 255);
  ucg.setFont(ucg_font_helvB24_hf);
  ucg.setPrintPos(3, 45);
  const uint8_t h = now.hour();
  const uint8_t hr_12 = h % 12;
  // Functions to move the cursor to second line fisrt position
  if (hr_12 < 10) {              // Zero padding if value less than 10 ie."09" instead of "9"
    ucg.print(" ");
    ucg.print((h > 12) ? h - 12 : ((h == 0) ? 12 : h), DEC); // Conversion to AM/PM
  else {
  printDigits(now.minute());
  if (h < 12) {                // Adding the AM/PM sufffix
    ucg.setPrintPos(86, 35);
    ucg.print("AM");
  else {
    ucg.setPrintPos(86, 25);
    ucg.print("PM");
    ucg.setPrintPos(0, 60);
    ucg.print(now.year() + now.month() + now.day()); //Adds them together
    ucg.print(now.year() && now.month() && now.day()); //gives me a |
If only there was some sort of math that would change 2018 to 20180000. If we had that then you could use that same math to change 7 to 700.
Of course you would also need some sort of math to merge those values. If only there was a way to merge three numbers like 20180000, 700, and 17 into 20180717.
If you could do all that then you could just print the final number.
When I use math like 10000 * now.year() I end up with -5088 which makes no sense at all as it should return 20180000
If only there was a way to get the normally 16 bit math to instead be done using 32 bit math.
Right after i replied I figured out that I need to use long and not int. Thank you for your help.
You are welcome.
(I apologize for the sarcasm. It is solely a reflection of my current mood.)
