Need some help for auto fan control
me and my teammate try to make a project of greens house system
we debug for several day and there is one more question left
we set fan motor to PIN 10, adding condition when temperature is >=26 ,the fan will be on.
it actually work, however, the fan run only about 5 second, when the void loop repeat, it stop.
i guess it might be the time of whole loop too short,.
can someone help me to fix this problem, let the fan stop, when only the temperature reach the degree we set, here is our code
   #include <Wire.h>
#include "rgb_lcd.h"
#include "DHT.h"
#define DHTPIN   A0
#define DHTTYPE  DHT11
DHT dht11(DHTPIN, DHTTYPE);
rgb_lcd lcd;
int fan = 10;
int pinOut1 = 8;
int pinOut2 = 9;
  Serial.begin(9800);
  pinMode(fan, OUTPUT);
  pinMode(8,OUTPUT);
  pinMode(9,OUTPUT);
  lcd.begin(16, 2);
  dht11.begin();
  int pot = analogRead(A1);
  int fan_speed = pot * (255 / 1023.0);
  analogWrite(fan,fan_speed);
  Serial.println(fan_speed);
  delay(101 );
  char _buffer[14];
  int humi = dht11.readHumidity() * 10;
  int temp = dht11.readTemperature() * 10;
  int humidity = dht11.readHumidity() ;
  int temperature = dht11.readTemperature() ;
  if(temp < 0)
    sprintf(_buffer, "TEMP =-%02u.%1u%cC", abs(temp)/10, abs(temp) % 10, 223);
    sprintf(_buffer, "TEMP = %02u.%1u%cC", temp/10, temp % 10, 223);
  lcd.setCursor(0, 0);
  lcd.print(_buffer);
  Serial.println(_buffer);
  sprintf(_buffer, "HUMD = %02u.%1u %%", humi/10, humi % 10);
  lcd.setCursor(0, 1);
  lcd.print(_buffer);
  delay(2000);
  if (temperature <= 25 )
  digitalWrite(pinOut1,HIGH);
else{
  digitalWrite(pinOut1,LOW);
   delay( 1000);
   if (humidity <= 70)
  digitalWrite(pinOut2,HIGH);
else{
  digitalWrite(pinOut2,LOW);
   delay( 1000);
if (temperature >= 25 )
  digitalWrite(fan,HIGH);
 else{
  digitalWrite(fan,LOW);
   delay( 1000);
and thanks for your hel[, we really appreciated
seems that you have 2 different pieces of code controlling the fan.
What kind of motor driver do you have between the fan and pin 10?
this one is fan speed measurement, which will show the speed in serial monior
and the temperature in that one , comes from DHT11 temp and Humidity sensor
it just a fan come with motor,
## Fan Motor Module
OSEPP - Fan Motor Module
So, no motor driver?
this is a write! did you intend this to be a read?
