"E:\Private\Arduino\My Projects\libraries\LCD16x2\LCD16x2.cpp:24:26: fatal error: ../Wire/Wire.h: No such file or directory
#include "../Wire/Wire.h"
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino Uno."
If I install another copy of the wire library to E:\Private\Arduino\My Projects\libraries\
I get the following note:
"Multiple libraries were found for "Wire.h"
Used: E:\Private\Arduino\My Projects\libraries\Wire
Not used: C:\Users\elehto\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.10\libraries\Wire"
This does not make any sense to me. Any advice of the root cause?
The Olimex library is located in E:\Private\Arduino\My Projects\libraries.
The best fix is probably to first delete the second copy of the "Wire" library that you created, (it's not needed), then edit the "E:\Private\Arduino\My Projects\libraries\LCD16x2\LCD16x2.cpp" file and change the line:-#include "../Wire/Wire.h"to#include <Wire.h>
Where did the "LCD16x2" library come from? Do you have a link?
It's OK, I found it. Here:-
Yep, that's the same one that I linked, but in it's original location. The one I linked appears to have been modified in other ways. The comments on the header and *.cpp file say "additional delay and minor fix". Pity they didn't do more of a 'fix'.
You're right, they should know better. I'm an absolute beginner, and I do.
I've seen this a couple of times with the "Wire" library over the last couple of weeks. At least it's easier to fix than some problems.
And I'm pretty ignorant about GitHub - don't even know what a "pull request" is.
Edit: Just did a bit of quick reading - I understand now.
