Need Upwork code explained to me, programmer MIA
Hello there,
I really need some help.
I have no idea how to use an Arduino so i went on 'upwork' to hire someone to help me write the code for a project I'm trying to complete. Unfortunately they have gone MIA and I don't know anything about coding. Our agreement was that he would talk me through how to use the code, and modify it as I needed. But all i have is a code I don't understand. I was hoping someone could translate it for me as I'm not sure what he has given me, or if it is at all what i had requested.
The project was a box which opens when a button is pressed by 'servo motors'. Once open 6 RFID readers are exposed which communicate through the 'arduino' to an RPi which would play a short video linked to the different cards.
Thank is advance
/*************************     Libraries      *********************************/
#include <MFRC522.h>  //https://github.com/miguelbalboa/rfid
#include <Servo.h>
/************************* Constants *********************************/
#define SS_PIN 5
#define RST_PIN 0
Servo myServo1;
Servo myServo2;
Servo myServo3;
Servo myServo4;
Servo myServo5;
int index;
// constants won't change. They're used here to set pin numbers:
const int BUTTON_PIN = 7;  // the number of the pushbutton pin
// Variables will change:
int lastState = LOW;  // the previous state from the input pin
int currentState;     // the current reading from the input pin
/************************* Parameters *********************************/
String id_allowed[] = { "4a88f980", "a7607cb4", "d4fadae9", "40b28d4d", "196a7be", "061854d" };
/********************* Global connection instances **************************/
MFRC522 rfid(SS_PIN, RST_PIN);
String ID_Card, op_name;
byte nuidPICC[4];
  myServo1.attach(5);   //servo1
  myServo2.attach(6);   //servo2
  myServo3.attach(9);   //servo3
  myServo4.attach(10);  //servo4
  myServo5.attach(11);  //servo5
  pinMode(BUTTON_PIN, INPUT_PULLUP);
  //init rfid
  SPI.begin();      // init SPI bus
  rfid.PCD_Init();  // init MFRC522
  Serial.println("Tap an RFID/NFC tag on the RFID-RC522 reader");
  myServo1.write(0);
  myServo2.write(0);
  myServo3.write(0);
  myServo4.write(0);
  myServo5.write(0);
  String idcard;
  uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 };  // Buffer to store the returned UID
                                            // Initialisé la boucle si aucun badge n'est présent
  if (!rfid.PICC_IsNewCardPresent())
    return;
  // Vérifier la présence d'un nouveau badge
  if (!rfid.PICC_ReadCardSerial())
    return;
  // Enregistrer l'ID du badge (4 octets)
  for (byte i = 0; i < 4; i++) {
    nuidPICC[i] = rfid.uid.uidByte[i];
  // Affichage de l'ID
  Serial.println("Un badge est détecté");
  Serial.println(" L'UID du tag est:");
  idcard = "";
    idcard += String(rfid.uid.uidByte[i], HEX);
  Serial.println(idcard);
  if (idcard == "a7607cb4") {
    index = "0";
    do {
      Serial.write(index);
    } while (Serial.read() != index);
  // Re-Init RFID
  rfid.PICC_HaltA();       // Halt PICC
  rfid.PCD_StopCrypto1();  // Stop encryption on PCD
  // read the state of the switch/button:
  currentState = digitalRead(BUTTON_PIN);
  if (lastState == LOW && currentState == HIGH) {
    for (int pos = 0; pos <= 90; pos += 1) {  // goes from 0 degrees to 90 degrees
      // in steps of 1 degree
      myServo1.write(pos);  // tell servo to go to position in variable 'pos'
      delay(15);            // waits 15ms for the servo to reach the position
      myServo2.write(pos);  // tell servo to go to position in variable 'pos'
      myServo3.write(pos);  // tell servo to go to position in variable 'pos'
      myServo4.write(pos);  // tell servo to go to position in variable 'pos'
      myServo5.write(pos);  // tell servo to go to position in variable 'pos'
    // save the last state
    lastState = currentState;
  if (lastState == HIGH && currentState == LOW) {
    for (int pos = 90; pos >= 0; pos -= 1) {  // goes from 90 degrees to 0 degrees
You will likely be posting code multiple times in this thread, so you may as well do it right.
Instead of pasting it straight into your message box, click on </> then paste into the correct place. Notice how nice the code looks! Next, go back to your IDE and press ctrl-T (Autoformat), then ctrl-shft-c (copy for forum), and paste in that version in instead. There, you've posted your first code correctly!
Read this, as well:
How to get the best from this forum
the above suggests there's a single servo the open/closes the box, but i see 6 servos that when the button is pressed sequentially drives each servo to 90 deg
and when released sequentially drives each servo back to 0 deg
i guess it makes sense to exit from loop() early if there is no PICC (rfid?) card present
as well as if it hasn't read anything
but i don't understand the loops that concatenate bytes from a card - are there really 6 RFID readers -- why aren't 6 different readers being checked?
these results are transmitted out thru the serial interface
don't understand why a card would be halted
there's also 6 IDs
but i only see one IDE being checked
don't understand what this read is attempting to do.
ask questions
There seem to be a couple of small errors in the code.
Pin 5 is used for the select pin of the RFID reader and also for one of the servos:
#define SS_PIN 5
MFRC522 rfid
(SS_PIN, RST_PIN);
Not sure exactly what is going on here, but assigning "0" to an int is a bit unusual, and will show a warning in the compiler. Looks like it would be printing out a string of zeros until the ascii character for zero is received, which would require something to be sending to the serial port.
    index = "0";
    do {
Whoever wrote this apparently has never heard of arrays.
Thank you for the information camsysca, looks much better.
