bsaka
                    August 14, 2021,  3:16pm
                  1
              This is the code:
 const unsigned long eventInterval1 = 3000;
  const unsigned long eventInterval2 = 6000;
  const unsigned long eventInterval3 = 9000;
  unsigned long previousTime = 0;
  #include <LiquidCrystal.h> //Dołączenie bilbioteki
LiquidCrystal lcd(7, 8, 9, 10, 11, 12); //Informacja o podłączeniu nowego wyświetlacza
#define PIN_YELLOW 6
  #define PIN_GREEN 5
  #define PIN_BLUE 4
  #define PIN_PURPLE 3
  #define PIN_BROWN 2
  lcd.begin(16, 2); //Deklaracja typu
    pinMode(PIN_YELLOW, INPUT_PULLUP);
    pinMode(PIN_GREEN, INPUT_PULLUP);
    pinMode(PIN_BLUE, INPUT_PULLUP);
    pinMode(PIN_PURPLE, INPUT_PULLUP);
    pinMode(PIN_BROWN, INPUT_PULLUP);
    delay(200);
  unsigned long currentTime = millis();
  lcd.setCursor(0, 0); //Ustawienie kursora
  if (digitalRead(6) == LOW) {
    lcd.print("     STREAM");
    lcd.setCursor(0, 1);
    lcd.print("    STARTING");
    delay(10000);
    lcd.clear();
  if(digitalRead(5) == LOW) {
    lcd.print("    CHATTING ");
    lcd.print("     CAMERA");
    delay(10000);
    lcd.clear();
 if(digitalRead(4) == LOW) {
    lcd.print("    BE RIGHT");
    lcd.print("      BACK");
    delay(10000);
    lcd.clear();
 if(digitalRead(3) == LOW) {
    lcd.print("     ENDING");
    delay(10000);
    lcd.clear();
   if(digitalRead(2) == LOW) {
    lcd.print("     DISPLAY");
    lcd.print("     SHARING");
    delay(10000);
    lcd.clear();
    if(currentTime - previousTime = eventInterval1){
  lcd.print("1.STARTING"); //Wyświetlenie tekstu
  lcd.setCursor(0, 1); //Ustawienie kursora
  lcd.print("2.CAMERA"); //Wyświetlenie tekstu
    if(currentTime - previousTime = eventInterval2){
  lcd.clear(); //Ustawienie kursora
  lcd.print("3.BRB"); //Wyświetlenie tekstu
  lcd.print("4.ENDING"); //Wyświetlenie tekstu
  if(currentTime - previousTime = eventInterval3){
  lcd.print("5.DISPLAY"); //Wyświetlenie tekstu
  lcd.print("6.CONCERT"); //Wyświetlenie tekstu
previousTime = currentTime
And this is the error:
\Desktop\wy_wietlacz\wy_wietlacz.ino: In function 'void loop()':
wy_wietlacz:66:37: error: lvalue required as left operand of assignment
wy_wietlacz:71:37: error: lvalue required as left operand of assignment
wy_wietlacz:77:35: error: lvalue required as left operand of assignment
wy_wietlacz:84:1: error: expected ';' before '}' token
exit status 1
What could be wrong with this? For people wondering trying to help me, I am trying to make it display three different messages on each interval (3000, 6000, 9000) but I am trying to use milis so that the arduino reacts if I press a button.
              Use ">=" not "="
At worst, use "==", but never, as you have found out, use "="
                bsaka
                    August 14, 2021,  3:26pm
                  3
              But then all three actions would run at the same time right? And I don't want that. I want the first one to turn on at 3000 and turn off when the other one starts. If You know what i am saying
Wrong.
What happened when you tried?
              = assigns value
== is a comparator
                bsaka
                    August 14, 2021,  3:30pm
                  6
              ohhh. That's why ok. I'll try now
                bsaka
                    August 14, 2021,  3:32pm
                  7
              nothing showed up. As if it was updating constantly. I'll try the == now
Still the same
              Add some flags so the first two intervals only trigger once each:
#define PIN_GREEN 5
#define PIN_BLUE 4
#define PIN_BROWN 2
bool triggered1 = false;
bool triggered2 = false;
  delay(200);
    delay(10000);
    lcd.clear();
  if (digitalRead(5) == LOW)
    delay(10000);
    lcd.clear();
  if (digitalRead(4) == LOW)
    lcd.print("      BACK");
    delay(10000);
    lcd.clear();
  if (digitalRead(3) == LOW)
    delay(10000);
    lcd.clear();
  if (digitalRead(2) == LOW)
    delay(10000);
    lcd.clear();
  if (!triggered1 && currentTime - previousTime >= eventInterval1)
    triggered1 = true;
  if (!triggered2 && currentTime - previousTime >= eventInterval2)
    triggered2 = true;
  if (currentTime - previousTime >= eventInterval3)
    triggered1 = false;
    triggered2 = false;
    previousTime = currentTime;
              Why do you have  lcd.begin(16, 2);
                bsaka
                    August 14, 2021,  3:44pm
                  10
              that is a good question. Deleted it now cause it was in setup too. Probably somehow copied it by mistake
                bsaka
                    August 14, 2021,  3:47pm
                  11
 johnwasser:
#define PIN_GREEN 5
#define PIN_BLUE 4
#define PIN_BROWN 2
  delay(200);
    delay(10000);
    lcd.clear();
    delay(10000);
    lcd.clear();
    lcd.print("      BACK");
    delay(10000);
    lcd.clear();
    delay(10000);
    lcd.clear();
    delay(10000);
    lcd.clear();
    triggered1 = true;
    triggered2 = true;
    triggered1 = false;
    triggered2 = false;
Now we have nothing showing up. After deleting the lcd.begin in the loop it understandably stopped flickering but nothing is showing up until i press a button. The buttons work though
it suddenly started working. Thanks everybody
              Maybe adding more screen clearing and cursor setting will help.
Note: I added a "return;" at the end of each button press.  This is to go right to the next iteration of loop() to update currentTime.  Without that the timing code would see the time jump forward 10 seconds and everything would trigger all at once.
#define PIN_GREEN 5
#define PIN_BLUE 4
#define PIN_BROWN 2
  delay(200);
  if (digitalRead(PIN_YELLOW) == LOW)
    lcd.clear();
    delay(10000);
    lcd.clear();
    return;
  if (digitalRead(PIN_GREEN) == LOW)
    lcd.clear();
    delay(10000);
    lcd.clear();
    return;
  if (digitalRead(PIN_BLUE) == LOW)
    lcd.clear();
    lcd.print("      BACK");
    delay(10000);
    lcd.clear();
    return;
  if (digitalRead(PIN_PURPLE) == LOW)
    lcd.clear();
    delay(10000);
    lcd.clear();
    return;
  if (digitalRead(PIN_BROWN) == LOW)
    lcd.clear();
    delay(10000);
    lcd.clear();
    return;
    triggered1 = true;
    lcd.clear();
    triggered2 = true;
    lcd.clear();
    lcd.clear();
    triggered1 = false;
    triggered2 = false;
                bsaka
                    October 27, 2021,  4:39pm
                  13
              Hi again. I decided to continue with the project, since it was meant to be for arruino Micro in order to communicate with the pc, sending keyboard shortcuts whenever I press a button. I bought the whole set, but when I wanted to check the buttons, and I wrote the code like in every tutorial, to check whether everything was working with the buttons, it started printing the text (the one to be pressed after a press of a button) but without me doing anything. I could even unplug everything and it would still keep on printing the text. Is there anything I could try ex: code to fix this?
                bsaka
                    October 27, 2021,  5:43pm
                  15
              int button = 2;
              Do you have a pull-down on pin 2?
Please remember to use code tags when posting code.
 bsaka:
As in a digital pin?
No, as in a physical resistor between pin 2 and ground.
              I don't want to play "non sequitur".
