I will preface this post by highlighting that I understand that a stepper motor is not ideal for running continuously, but it is the current use case and what I have available for a conveyor system I am trying to run.
Below is a breakdown of the hardware I am currently using:
Arduino Mega 2560 Rev3
Pololu DRV8834 Low-Voltage Stepper Motor Driver
ST5918M2008-A – STEPPER MOTOR – NEMA 23 (Bipolar Series Winding)
https://us.nanotec.com/fileadmin/files/Datenblaetter/Schrittmotoren/ST5918/M/ST5918M2008-A.pdf -
K7803-2000R3 - DC DC CONVERTER 3.3V 6.6W
digikey.com/en/products/detail/mornsun-america-llc/K7803-2000R3/13168200
My current issue is that I cannot continuously run the stepper motor, regardless of the various stepper motor libraries available (i.e. AccelStepper, ContinousStepper, BasicStepperDriver)
Below is a further explanation of my current approach to the problem:
Based on the schematic above, I am supplying approximately 3.1V (Measured) to VMOT with the 100uf capacitor in parallel with VMOT and GND. The motor power supply is a 24VDC 5A (Output) power supply, but converted down to 3.3V by the K7803-2000R3.
As mentioned above the stepper motor has 8 windings but with bipolar serial connections.
I am able to get the motor to run for a quarter to half rotation but with the command of rotating 360. I also used the following code to try and run continuously using the AccelStepper library example. This also causes the motor to run a few steps and jitter.
#include <AccelStepper.h>
AccelStepper myStepper(AccelStepper::DRIVER, stepPin, dirPin); // works for a4988 (Bipolar, constant current, step/direction driver)
myStepper.setMaxSpeed(200); // this limits the value of setSpeed(). Raise it if you like.
myStepper.setSpeed(-200); // runSpeed() will run the motor at this speed - set it to whatever you like.
myStepper.runSpeed(); // This will run the motor forever.
My current guess is that it is an issue with the current draw causing the overcurrent protection in the DRV8834 to kick in at 2A. Originally the stepper was wired for a parallel connection but changed to series to help with this issue. I would appreciate any guidance in this and would be happy to share more information where needed.
