Greetings, all
I need your help programming my project using a large NEMA 34 stepper motor and a DQ860MA driver with 8A drive current for Controlling Pan-Tilt Broadcast Camera using RC Transmitter. The DQ860MA is powered by a 10A 24VDC power source.
Greetings, all
http://www.catb.org/~esr/faqs/smart-questions.html
Is the 7.8A (3.9A/phase for 2 phases?) that the driver can deliver enough for you large NEMA 34 stepper motor? Are you using 2 axes? what arduino are you using? Does it work with your transmitter & receiver? Did you try some example scripts with your hardware? If so, what works and what doesn't?
Datasheets? How will you control the cam, joystick or...?
