NEO-6M Module not working
I have this code:
#include <SoftwareSerial.h>
// Define the GPS module connections
#define GPS_TX_PIN 10
#define GPS_RX_PIN 11
// Create a software serial object to communicate with the GPS module
SoftwareSerial gpsSerial(GPS_TX_PIN, GPS_RX_PIN);
  // Initialize the serial communication
  gpsSerial.begin(9600);
  // Debugging
  Serial.println("GPS Module Initialized");
  // Check if data is available from the GPS module
  if (gpsSerial.available()) {
    // Read the data from the GPS module
    char c = gpsSerial.read();
    // Check if the received character is the start of a GPS sentence
    if (c == '$') {
      String sentence = gpsSerial.readStringUntil('\n');
      // Debugging: Print raw GPS data
      Serial.println(sentence);
      // Check if the sentence is a GGA sentence
      if (sentence.startsWith("$GPGGA")) {
        // Split the sentence into individual parts using commas as separators
        int commaIndex = sentence.indexOf(',');
        int i = 1;
        while (commaIndex != -1) {
          commaIndex = sentence.indexOf(',', commaIndex + 1);
          if (commaIndex != -1) {
            i++;
        // Extract the latitude and longitude from the GGA sentence
        String latitude = getValue(sentence, ',', i + 1);
        String longitude = getValue(sentence, ',', i + 3);
        // Print the coordinates to the serial monitor
        Serial.print("Latitude: ");
        Serial.println(latitude);
        Serial.print("Longitude: ");
        Serial.println(longitude);
// Helper function to extract a value from a comma-separated string
String getValue(String data, char separator, int index) {
  int found = 0;
  int strIndex[] = { 0, -1 };
  int maxIndex = data.length() - 1;
  for (int i = 0; i <= maxIndex && found <= index; i++) {
    if (data.charAt(i) == separator || i == maxIndex) {
      found++;
      strIndex[0] = strIndex[1] + 1;
      strIndex[1] = (i == maxIndex) ? i + 1 : i;
  return found > index ? data.substring(strIndex[0], strIndex[1]) : "";
It is connected to an Arduino Mega2560 clone. VCC is connected to 5v (actually 4.81v), GND to GND, RX to pin 11, TX to pin 10.
The LED on the module does not power on.
The Serial monitor returns this:
GPRMC,,V,,,,,,,,,,N*53
GPVTG,,,,,,,,,N*30
GPGGA,,,,,,0,00,99.99,,,,,,*48
GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99*30
GPGSV,1,1,00*79
GPGLL,,,,,,V,N*64
It loops, returning slightly different numbers every time.
I have taken it to a wide cloud free sky and it still doesn't work, doesn't work indoors either.
This is my module:
It is brand new, this is the first time it has been used.
Does anyone have any ideas?
If the printout to serial monitor stays like the text shown for more than say 45 seconds when outdoors with a good view of the sky, then either the GPS or its antenna is faulty.
Incidently, no need to use Software serial on a Mega, its got 3 spare hardware serial ports.
I've had it on in open sky for about half an hour with no real change....
Second, is it repairable, or is it destined for the dirt bin?
Ok....
Been doing some research, looks like I should get one with a SMA antenna connection.
Dumb question....
What antenna do I use, haven't found one that comes with an antenna for SMA?
Try another antenna of the same type.
I'm kinda interested in getting a more durable module. Do you have any suggestions? I'm building a GPS tracker that has SMS location, so a SIM800L will also be connected, after I have confirmed that the GPS is working. It will be in the dash of my car.
I had a look at the NEO-M8N as it has a SMA connector on board. Is that a good option?
Is one of these antennas good?
The NMEA $GPGSV sentence tells you the number of Satellites in View.
My GPS receiver currently reports 25 satellites in view. It shows a maximum of 4 satellites per line, so it reports it like:
$GPGSV,7,1,25,01,13,137,,02,,,27,03,,,26,04,,,264E
$GPGSV,7,2,25,05,,,26,06,43,011,26,07,23,043,26,09,,,27
76
$GPGSV,7,3,25,10,,,26,11,09,342,26,12,,,26,13,39,271,2779
$GPGSV,7,4,25,14,40,143,26,15,12,250,,16,,,26,17,61,186,43
$GPGSV,7,5,25,18,,,26,19,68,242,26,20,,,27,25,,,26
43
$GPGSV,7,6,25,27,,,26,29,,,26,30,57,050,26,31,,,26
47
$GPGSV,7,7,25,50,63,318,30*47
You are receiving no satellites:
GPGSV,1,1,00*79`
Is that because the antenna is kaput?
Yes, it could be.
It's worth checking whether the connector is mated correctly.
The LED flashes only when the module gets the location, meanwhile it is off.
You can test the operation with the U-center application from U-blox by connecting it to the PC with a USB-TTL converter.
