Hello I am relatively new to the Arduino community and this is my first post.
I am building a drone with a clone Elegoo Arduino nano as the flight controller with a CH340 chip. I have been building it with sensors such as a Barometer(BMP180), Magnetometer(QMC5883L), and Acc/Gyro(MPU6050) with I2C connections.
These sensors and flight controller are all built with Multiwii 2.4 software and they are all communicating well together and the correct results are given.
Everything was going well until I tried to connect my GPS module. The last sensor I would want to add is my NEO-6M Ublox gps module rated for 3.3-5V with 9600 BAUD. I tested the module with my computer before connecting it to the nano and it works and is able to grab a fix no problem and transmit the NMEA sentences with U-Center. However I try to connect this last module with the serial port of the Arduino Nano.
GPS => Nano
TX => RX (Port 0)
RX => TX (Port 1)
I have this code in config.h to define the module in Multiwii 2.4:
/*********************** GPS **************************/
/* ENable this for using GPS simulator (NMEA only)*/
//#define GPS_SIMULATOR
/* GPS using a SERIAL port
if enabled, define here the Arduino Serial port number and the UART speed
note: only the RX PIN is used in case of NMEA mode, the GPS is not configured by multiwii
in NMEA mode the GPS must be configured to output GGA and RMC NMEA sentences (which is generally the default conf for most GPS devices)
at least 5Hz update rate. uncomment the first line to select the GPS serial port of the arduino */
#define GPS_SERIAL 0 // should be 2 for flyduino v2. It's the serial port number on arduino MEGA
// must be 0 for PRO_MINI (ex GPS_PRO_MINI)
// note: Now a GPS can share MSP on the same port. The only constrain is to not use it simultaneously, and use the same port speed.
// avoid using 115200 baud because with 16MHz arduino the 115200 baudrate have more than 2% speed error (57600 have 0.8% error)
#define GPS_BAUD 9600 // GPS_BAUD will override SERIALx_COM_SPEED for the selected port
/* GPS protocol
NMEA - Standard NMEA protocol GGA, GSA and RMC sentences are needed
UBLOX - U-Blox binary protocol, use the ublox config file (u-blox-config.ublox.txt) from the source tree
MTK_BINARY16 and MTK_BINARY19 - MTK3329 chipset based GPS with DIYDrones binary firmware (v1.6 or v1.9)
With UBLOX and MTK_BINARY you don't have to use GPS_FILTERING in multiwii code !!! */
#define NMEA
//#define UBLOX
//#define MTK_BINARY16
//#define MTK_BINARY19
//#define INIT_MTK_GPS // initialize MTK GPS for using selected speed, 5Hz update rate and GGA & RMC sentence or binary settings
/* I2C GPS device made with an independant arduino + GPS device
including some navigation functions
contribution from EOSBandi http://code.google.com/p/i2c-gps-nav/
You have to use at least I2CGpsNav code r33 */
/* all functionnalities allowed by SERIAL_GPS are now available for I2C_GPS: all relevant navigation computations are gathered in the main FC */
//#define I2C_GPS
// If your I2C GPS board has Sonar support enabled
//#define I2C_GPS_SONAR
/* indicate a valid GPS fix with at least 5 satellites by flashing the LED - Modified by MIS - Using stable LED (YELLOW on CRIUS AIO) led work as sat number indicator
- No GPS FIX -> LED blink at speed of incoming GPS frames
- Fix and sat no. bellow 5 -> LED off
- Fix and sat no. >= 5 -> LED blinks, one blink for 5 sat, two blinks for 6 sat, three for 7 ... */
#define GPS_LED_INDICATOR
//Enables the MSP_WP command set , which is used by WinGUI for displaying an setting up navigation
//#define USE_MSP_WP
// HOME position is reset at every arm, uncomment it to prohibit it (you can set home position with GyroCalibration)
//#define DONT_RESET_HOME_AT_ARM
/* GPS navigation can control the heading */
// copter faces toward the navigation point, maghold must be enabled for it
#define NAV_CONTROLS_HEADING 1 //(**)
// true - copter comes in with tail first
#define NAV_TAIL_FIRST 0 //(**)
// true - when copter arrives to home position it rotates it's head to takeoff direction
#define NAV_SET_TAKEOFF_HEADING 1 //(**)
/* Get your magnetic declination from here : http://magnetic-declination.com/
Convert the degree+minutes into decimal degree by ==> degree+minutes*(1/60)
Note the sign on declination it could be negative or positive (WEST or EAST)
Also note, that maqgnetic declination changes with time, so recheck your value every 3-6 months */
#define MAG_DECLINATION 4.02f //(**)
// Adds a forward predictive filterig to compensate gps lag. Code based on Jason Short's lead filter implementation
#define GPS_LEAD_FILTER //(**)
// add a 5 element moving average filter to GPS coordinates, helps eliminate gps noise but adds latency comment out to disable
// use it with NMEA gps only
//#define GPS_FILTERING //(**)
// if we are within this distance to a waypoint then we consider it reached (distance is in cm)
#define GPS_WP_RADIUS 100 //(**)
// Safe WP distance, do not start mission if the first wp distance is larger than this number (in meters)
// Also aborts mission if the next waypoint distance is more than this number
#define SAFE_WP_DISTANCE 500 //(**)
//Maximu allowable navigation altitude (in meters) automatic altitude control will not go above this height
#define MAX_NAV_ALTITUDE 100 //(**)
// minimum speed when approach waypoint
#define NAV_SPEED_MIN 100 // cm/sec //(**)
// maximum speed to reach between waypoints
#define NAV_SPEED_MAX 400 // cm/sec //(**)
// Slow down to zero when reaching waypoint (same as NAV_SPEED_MIN = 0)
#define NAV_SLOW_NAV 0 //(**)
// Weight factor of the crosstrack error in navigation calculations (do not touch)
#define CROSSTRACK_GAIN .4 //(**)
// Maximum allowable banking than navigation outputs
#define NAV_BANK_MAX 3000 //(**)
//Defines the RTH altitude. 0 means keep current alt during RTH (in meters)
#define RTH_ALTITUDE 15 //(**)
//Wait to reach RTH alt before start moving to home (0-no, 1-yes)
#define WAIT_FOR_RTH_ALT 1 //(**)
//Navigation engine will takeover BARO mode control
#define NAV_TAKEOVER_BARO 1 //(**)
//Throttle stick input will be ignored (only in BARO)
#define IGNORE_THROTTLE 1 //(**)
//If FENCE DISTANCE is larger than 0 then copter will switch to RTH when it farther from home
//than the defined number in meters
#define FENCE_DISTANCE 600
//This governs the descent speed during landing. 100 is equals approc 50cm/sec
#define LAND_SPEED 100
//#define ONLY_ALLOW_ARM_WITH_GPS_3DFIX // Only allow FC arming if GPS has a 3D fix.
When I power on the whole thing the arduino has the Power LED on as well as the RX LED flashing.
However when I try to see results in Multiwii GUI I suddenly get no information coming through when before it would easily recognize all the previous sensors just fine and show output. It shows me the image that is attached to this post
When I disconnect the GPS the flight controller and GUI go back to functioning normally.
I am stuck and would be grateful for any help on the issue as I do not understand what is blocking me.
Thanks in advance!
