I'm running into an issue where after upgrading the ESP32 package from 2.0.17 to 3.0.x, Neopixel sketches with an LED count of 76 or more get into a crash loop.
Adafruit NeoPixel v1.12.2
Arduino IDE Version: 2.3.2 (Date: 2024-02-20T10:04:35.814Z / CLI Version: 0.35.3)
Board: Adafruit ESP32 Feather (Huzzah32, https://learn.adafruit.com/adafruit-huzzah32-esp32-feather)
Board package: esp32 by Espressif Systems, version 3.0.0 (same behavior with 3.0.1)
Minimal sketch:
// with esp32 v2.0.17: LED_COUNT 75 works, LED_COUNT 76 (and higher) works
// with esp32 v3.0.0: LED_COUNT 75 works, LED_COUNT 76 crashes
#define LED_COUNT 50
#define LED_PIN 14
Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_RGB + NEO_KHZ800);
Serial.printf("Testing with %d pixels...\n", LED_COUNT);
strip.begin();
strip.show();
void loop() {};
Note that for the purpose of this test (and this reproduction), one does need any LEDs physically and actually connected (and therefore also rules out power supply issues etc).. I can reproduce this on a bare Huzzah32 board without any additional hardware attached.
Works with ESP32 package 2.0.17
As said in the comments in the sketch, when using ESP32 package 2.0.17:
- Compiling and running sketch with LED_COUNT=75 works,
- Compiling and running sketch with LED_COUNT=76 works (and higher - tested up to 200 at least; I could swear I've also used longer in the past).
Errors with ESP32 package 3.0.x and LED_COUNT > 75
With ESP32, the above sketch works up to, and including, LED_COUNT 75.
With a higher LED count, the sketch puts the ESP32 into a crash loop, albeit with different symptoms depending on the count.
WIth LED_COUNT 76:
Rebooting...
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:1288
load:0x40078000,len:13872
load:0x40080400,len:4
ho 8 tail 4 room 4
load:0x40080404,len:3048
entry 0x40080590
Testing with 76 pixels...
Guru Meditation Error: Core 1 panic'ed (Unhandled debug exception).
Debug exception reason: Stack canary watchpoint triggered (loopTask)
Core 1 register dump:
PC : 0x4008a8ea PS : 0x00060636 A0 : 0x8008c55c A1 : 0x3ffb0320
A2 : 0x3ffb0300 A3 : 0xffffffff A4 : 0x00060623 A5 : 0x3f406dac
A6 : 0xb33fffff A7 : 0xb33fffff A8 : 0x800842d1 A9 : 0x3ffb0420
A10 : 0x00000001 A11 : 0x00060020 A12 : 0x00000004 A13 : 0x00060023
A14 : 0xb33fffff A15 : 0xb33fffff SAR : 0x0000001f EXCCAUSE: 0x00000001
EXCVADDR: 0x00000000 LBEG : 0x40086208 LEND : 0x4008621e LCOUNT : 0xffffffff
Backtrace: 0x4008a8e7:0x3ffb0320 0x4008c559:0x3ffb0350 0x4008c6bd:0x3ffb0370 0x4008376e:0x3ffb0390 0x40083781:0x3ffb03c0 0x4008afd8:0x3ffb03e0 0x40087fc9:0x3ffb0400 0x400881dc:0x3ffb0420 0x400842ce:0x3ffb0440 0x40084316:0x3ffb0460 0x40084461:0x3ffb04a0 0x400d487b:0x3ffb04c0 0x400d59a4:0x3ffb04e0 0x400d2173:0x3ffb0540 0x400d1751:0x3ffb0590 0x400d16b3:0x3ffb2250 0x400d1584:0x3ffb2270 0x400d224e:0x3ffb2290
Stack trace decode:
0x4008a8e7: xPortEnterCriticalTimeout at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/FreeRTOS-Kernel/portable/xtensa/include/freertos\portmacro.h:560
0x4008c559: multi_heap_internal_lock at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/FreeRTOS-Kernel/portable/xtensa/include/freertos\portmacro.h:575
0x4008c6bd: multi_heap_malloc at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/heap\multi_heap_poisoning.c:250
0x4008376e: heap_caps_malloc_base at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/heap\heap_caps.c:176
0x40083781: heap_caps_malloc at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/heap\heap_caps.c:197
0x4008afd8: pvPortMalloc at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos\heap_idf.c:83
0x40087fc9: xQueueGenericCreate at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/FreeRTOS-Kernel\queue.c:501
0x400881dc: xQueueCreateMutex at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/FreeRTOS-Kernel\queue.c:619
0x400842ce: lock_init_generic at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/newlib\locks.c:64
0x40084316: lock_acquire_generic at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/newlib\locks.c:118
0x40084461: _lock_acquire at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/newlib\locks.c:154
0x400d487b: rmt_acquire_group_handle at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/driver/rmt\rmt_common.c:40
0x400d59a4: rmt_new_tx_channel at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/driver/rmt\rmt_tx.c:108
0x400d2173: rmtInit at C:\Users\carst\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.0\cores\esp32\esp32-hal-rmt.c:534
0x400d1751: espShow at C:\Users\carst\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel\esp.c:40
0x400d16b3: Adafruit_NeoPixel::show() at C:\Users\carst\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp:3008
0x400d1584: setup() at C:\Users\carst\OneDrive\Documents\Arduino\debugtest\debugtest.ino:12
0x400d224e: loopTask(void*) at C:\Users\carst\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.0\cores\esp32\main.cpp:58
Sometimes I see a slight variation of that:
ho 8 tail 4 room 4
entry 0x40080590
PC : 0x4008d186 PS : 0x00060836 A0 : 0x8008d0f8 A1 : 0x3ffb0330
A2 : 0x3ffb8da8 A3 : 0x00000000 A4 : 0x00000001 A5 : 0x00000000
A6 : 0x3ffb8cf4 A7 : 0x00000000 A8 : 0x3ffb8dfc A9 : 0xbaad5678
A10 : 0x3ffb8000 A11 : 0x3ffb8da0 A12 : 0xfffffffe A13 : 0xfffffffd
A14 : 0xb33fffff A15 : 0xb33fffff SAR : 0x0000001c EXCCAUSE: 0x00000001
EXCVADDR: 0x00000000 LBEG : 0x400862c8 LEND : 0x400862de LCOUNT : 0xffffffff
Backtrace: 0x4008d183:0x3ffb0330 0x4008d0f5:0x3ffb0360 0x4008382e:0x3ffb0380 0x40083841:0x3ffb03b0 0x4008ba00:0x3ffb03d0 0x400889f1:0x3ffb03f0 0x40088c04:0x3ffb0410 0x4008438e:0x3ffb0430 0x400843d6:0x3ffb0450 0x40084521:0x3ffb0490 0x400d5203:0x3ffb04b0 0x400d632c:0x3ffb04d0 0x400d2a9b:0x3ffb0530 0x400d1829:0x3ffb0580 0x400d178b:0x3ffb2240 0x400d165f:0x3ffb2260 0x400d3bbe:0x3ffb2290
0x4008d183: poison_allocated_region at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/heap\multi_heap_poisoning.c:77
0x4008d0f5: multi_heap_malloc at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/heap\multi_heap_poisoning.c:254
0x4008382e: heap_caps_malloc_base at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/heap\heap_caps.c:176
0x40083841: heap_caps_malloc at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/heap\heap_caps.c:197
0x4008ba00: pvPortMalloc at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos\heap_idf.c:83
0x400889f1: xQueueGenericCreate at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/FreeRTOS-Kernel\queue.c:501
0x40088c04: xQueueCreateMutex at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/FreeRTOS-Kernel\queue.c:619
0x4008438e: lock_init_generic at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/newlib\locks.c:64
0x400843d6: lock_acquire_generic at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/newlib\locks.c:118
0x40084521: _lock_acquire at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/newlib\locks.c:154
0x400d5203: rmt_acquire_group_handle at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/driver/rmt\rmt_common.c:40
0x400d632c: rmt_new_tx_channel at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/driver/rmt\rmt_tx.c:108
0x400d2a9b: rmtInit at C:\Users\carst\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.0\cores\esp32\esp32-hal-rmt.c:534
0x400d1829: espShow at C:\Users\carst\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel\esp.c:40
0x400d178b: Adafruit_NeoPixel::show() at C:\Users\carst\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp:3008
0x400d165f: setup() at C:\Users\carst\OneDrive\Documents\Arduino\debugtest\debugtest.ino:14
0x400d3bbe: loopTask(void*) at C:\Users\carst\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.0\cores\esp32\main.cpp:58
With LED-COUNT 100 (don't know where the exact cutoff is; I've just tried different numbers in increments), the crash signature changes:
ho 8 tail 4 room 4
entry 0x40080590
Testing with 100 pixels...
***ERROR*** A stack overflow in task loopTask has been detected.
Backtrace: 0x4008285d:0x3ffafa20 0x4008874d:0x3ffafa40 0x4008b4f9:0x3ffafa60 0x400899ea:0x3ffafae0 0x4008b6b0:0x3ffafb10 0x4008b660:0x3ffafb30 0x400843d6:0x00000001 |<-CORRUPTED
Decode:
Decoding stack results
0x4008285d: panic_abort at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/esp_system\panic.c:466
0x4008874d: esp_system_abort at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/esp_system/port\esp_system_chip.c:84
0x4008b4f9: vApplicationStackOverflowHook at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/FreeRTOS-Kernel/portable/xtensa\port.c:581
0x400899ea: vTaskSwitchContext at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/xtensa/include\xt_utils.h:40
and with LED_COUNT 200, I see yet another signature - in this case it is just a TG1WDT_SYS_RESET.
rst:0x8 (TG1WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
ho 8 tail 4 room 4
entry 0x40080590
Testing with 200 pixels...
ho 8 tail 4 room 4
entry 0x40080590
I see that in other scenarios, TG1WDT_SYS_RESET was read as an indication of power supply issues(?), but again, I can reproduce this with or without any actual NeoPixel attached.
Behavior with ESP32 package 3.0.1 seems identical to that with 3.0.0.
Downgrading to 2.0.17, and all is working again.
Any help would be much appreciated ![]()
