Neopixels to NeoMatrix & Generic ESP to Wemos D1
hi, need help to resolve this code that i get from other..
he using the Adafruit Neopixel Led library with generic ESP8266, id just want to use his code for Wemos D1 R1 with Adafruit NeoMatrix Library..
where am i wrong for the change ?
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
#include <Adafruit_NeoMatrix.h>
#include "font5x7.h"
#define PIN_BUTTON   0
#define PIN_LED     D5
#define NUM_LEDS    64
int width = 8;
int height = 8;
String scrolltext = " Hello World!";
uint16_t scrollwait = 75;
uint32_t scrollcolor = 0x002000;
byte scrollindex = 0; // scroll character index
// Neopixel object
// Adafruit_NeoPixel leds = Adafruit_NeoPixel(NUM_LEDS, PIN_LED, NEO_GRB + NEO_KHZ800);
 // Matrix Settings
Adafruit_NeoMatrix matrix = Adafruit_NeoMatrix(width, height, PIN_LED,
  NEO_MATRIX_BOTTOM    + NEO_MATRIX_RIGHT +
  NEO_MATRIX_COLUMNS + NEO_MATRIX_ZIGZAG,
byte demo_index = 0;
byte brightness = 48;       // default brightness: 48
uint32_t pixels[NUM_LEDS];  // pixel buffer. this buffer allows you to set arbitrary
                            // brightness without destroying the original color values
ESP8266WebServer server(80);  // create web server at HTTP port 80
// Forward declare functions
//String get_ap_name();
void button_handler();
void on_status();
void on_change_color();
void on_homepage();
void show_matrix();
void demo_wipe();
void demo_rainbow();
void demo_scrolltext();
void show_matrix() {
  uint32_t r, g, b;
  uint32_t c;
  for(byte i=0;i<NUM_LEDS;i++) {
    r = (pixels[i]>>16)&0xFF;
    g = (pixels[i]>>8)&0xFF;
    b = (pixels[i])&0xFF;
    r = r*brightness/255;
    g = g*brightness/255;
    b = b*brightness/255;
    c = (r<<16) + (g<<8) + b;
    matrix.setPixelColor(i, c);
  matrix.show();
  // Set pin mode
  pinMode(PIN_BUTTON, INPUT);
  pinMode(PIN_LED,    OUTPUT);
  // Initialize matrix
  matrix.begin();
  matrix.show();
  // Set WiFi SSID
//  String ap_name = get_ap_name();
//  WiFi.persistent(false);
//  WiFi.softAP(ap_name.c_str());
//  WiFi.mode(WIFI_AP);
  WiFi.mode(WIFI_AP);
  WiFi.softAP("ESP8266", "12345");
  IPAddress myIP = WiFi.softAPIP();
  Serial.print("AP IP address: ");
  Serial.println(myIP);
  // Set server callback functions
  server.on("/",   on_homepage);
  server.on("/js", on_status);
  server.on("/cc", on_change_color);
  server.begin();
  // Set button handler
  attachInterrupt(PIN_BUTTON, button_handler, FALLING);
// The variable below is modified by interrupt service routine
// so declare it as volatile
volatile boolean button_clicked = false;
  switch(demo_index) {
  case 0:
    demo_wipe();
  case 1:
    demo_rainbow();
  default:
    server.handleClient();
    if(scrolltext.length() > 0) {
      demo_scrolltext();
  if(button_clicked) {
    demo_index ++;  // upon button click, proceed to the next demo
 * Color Wipe Demo
void wipe(uint32_t c, byte wait) {  // wipe with a given color
  for(byte i=0; i<NUM_LEDS; i++) {
    matrix.show();
    delay(wait);
void demo_wipe() {
  static byte idx = 0;
  switch(idx) {
    case 0:
      wipe(0x200000, 30);
      delay(100);
    case 1:
      wipe(0x002000, 30);
      delay(100);
    case 2:
      wipe(0x000020, 30);
      delay(100);
  idx=(idx+1)%3;
 *   Rainbox Demo
uint32_t wheel(byte WheelPos) {
  WheelPos = 255 - WheelPos;
  if(WheelPos < 85) {
    return matrix.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  if(WheelPos < 170) {
    WheelPos -= 85;
    return matrix.Color(0, WheelPos * 3, 255 - WheelPos * 3);
  WheelPos -= 170;
  return matrix.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
void demo_rainbow() {
    pixels[i] = wheel((i+idx)&0xFF);
  show_matrix();
  delay(10);
  idx++;
 * Scroll Text Demo
void drawCol(char c, int i){
  if(i >= 0 && i < 5){
    for(int j = 0; j < 7; j++){
        if(c & 0x1){
          matrix.setPixelColor(i*7+j, scrollcolor);
          matrix.setPixelColor(i*7+j, 0);
        c >>= 1;
void drawChar(char c, int offset){
  char col;
  for(int i = 0; i < 5; i++){
    if(i - offset >= 0 && i - offset < 5){
      col = pgm_read_byte(font+(c*5)+i);
      drawCol(col,i - offset);
void demo_scrolltext() {
  for(byte j = 0; j < 6; j++){
    for(byte k = 0; k < 2; k++){
      drawChar(scrolltext.charAt(scrollindex+k),j - k*6);
      drawCol(0,5-j+k*6);
    delay(scrollwait);
    matrix.show();
  scrollindex = (scrollindex+1)%scrolltext.length();
 *  WebServer Demo
#include "html.h"
void on_homepage() {
  String html = FPSTR(index_html);
  server.send(200, "text/html", html);
// this returns device variables in JSON, e.g.
// {"pixels":xxxx,"blink":1}
void on_status() {
  String html = "";
  html += "{\"brightness\":";
  html += brightness;
  html += "}";
void on_change_color() {
  uint16_t i;
  if(server.hasArg("pixels")) {
    String val = server.arg("pixels");
    for(i=0;i<NUM_LEDS;i++) {
      // every pixel color is 6 bytes storing the hex value
      // pixels are specified in row-major order
      // here we need to flip it to column-major order to
      // match the physical connection of the matrix
      byte r=i/5, c=i%5;
      pixels[c*7+r] = strtol(val.substring(i*6, i*6+6).c_str(), NULL, 16);
    scrolltext = "";
  if(server.hasArg("clear")) {
      pixels[i] = 0;
    scrolltext = "";
  if(server.hasArg("brightness")) {
    brightness = server.arg("brightness").toInt();
    scrolltext = "";
  if(server.hasArg("scrolltext")) {
    scrolltext = server.arg("scrolltext");
    scrolltext = " "+scrolltext;
    scrollindex = 0;
    if(server.hasArg("wait")) {
      scrollwait = server.arg("wait").toInt();
      if(scrollwait<5) scrollwait=5;
    if(server.hasArg("color")) {
      scrollcolor = strtol(server.arg("color").c_str(), NULL, 16);
  if(scrolltext.length() == 0)
    show_matrix();
  server.send(200, "text/html", "{\"result\":1}");
char dec2hex(byte dec) {
  if(dec<10) return '0'+dec;
  else return 'A'+(dec-10);
// AP name is ESP_ following by
// the last 6 bytes of MAC address
//String get_ap_name() {
//  static String ap_name = "";
//  if(!ap_name.length()) {
//    byte mac[6];
//    WiFi.macAddress(mac);
//    ap_name = "ESP_";
//    for(byte i=3;i<6;i++) {
//      ap_name += dec2hex((mac[i]>>4)&0x0F);
//      ap_name += dec2hex(mac[i]&0x0F);
//  return ap_name;
void button_handler() {
  button_clicked = true;
Why did you believe you needed to change the code for Wemos mini?
What did you change?
What is the problem with the code now? What happens and what did you expect to happen?
Hi PaulRB,
im not sure what i did... but the original code using // Adafruit_NeoPixel leds = Adafruit_NeoPixel(NUM_LEDS, PIN_LED, NEO_GRB + NEO_KHZ800);
but i do have 8x8 Neopixels Matrix.. i do check other code that it use the NeoMatrix library.
as for Wemos / ESP3288 code... i have no idea what when wrong or what to change to suite the lastest code.
I will try to help after you have answered my questions.
to be honest... im clueless too..
Doctor:
"What seems to be the problem?"
Patient:
"I don't know, I'm not a doctor"
Doctor:
"Well, what hurts?"
Patient:
"I have no idea"
Doctor:
"Get out of my office, I have sick people to attend to"
I'm sorry if that sounds cruel. I don't really compare myself to a real doctor. But can you see the problem here?
im ok... haha, i think id already commented out the previous code... & put new code below it.. it didnt work.
:man_shrugging: :man_shrugging: :man_shrugging:
