New Nano Not Working. Can't Install Bootloader
I've just bought a cheap Chinese Nano. I tried uploading a Sketch and got the following stk500 errors:
Arduino: 1.8.9 (Linux), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
Build options changed, rebuilding all
Sketch uses 4402 bytes (14%) of program storage space. Maximum is 30720 bytes.
Global variables use 482 bytes (23%) of dynamic memory, leaving 1566 bytes for local variables. Maximum is 2048 bytes.
/home/john/bin/arduino-1.8.9/hardware/tools/avr/bin/avrdude -C/home/john/bin/arduino-1.8.9/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/ttyUSB0 -b57600 -D -Uflash:w:/tmp/arduino_build_944291/ArduinoISP.ino.hex:i
avrdude: Version 6.3-20171130
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/home/john/bin/arduino-1.8.9/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/home/john/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/ttyUSB0
         Using Programmer              : arduino
         Overriding Baud Rate          : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done.  Thank you.
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
The onboard LED doesn't flash when reset is pressed, which I understand suggests the bootloader is missing. I've followed the instructions from here, and double checked everything from other sources, but it doesn't work. I've used a cheap Uno as the programmer, using pins 10-13 on the Uno.
/home/john/bin/arduino-1.8.9/hardware/tools/avr/bin/avrdude -C/home/john/bin/arduino-1.8.9/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/ttyUSB0 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xFF:m
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x14
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x02
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x10
         Hardware Version: 4238814
         Firmware Version: 21521776.0
         Topcard         : STK502
         Vtarget         : 1.8 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: stk500_initialize(): (b) protocol error, expect=0x10, resp=0x01
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x10
Error while burning bootloader.
Tx and Rx flash on the Uno while trying to install the Bootloader, but not on the Nano, although the LED on the Nano is flashing.
I've recheck and redone the wiring several times, and everything seems OK.
Is there anything else I can try, or does it look as though I have a faulty Nano?
Connect a 10uF capacitor between Reset and GND on the UNO.
kprims:
Thanks. I'd read about doing that, but wasn't clear if I needed to with this setup. Anyway, I've tried it and I'm now getting "Invalid device signature".
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x000000 (retrying)
avrdude: Yikes!  Invalid device signature.
         this check.
I've done a continuity check on the wires I used, and they're all OK.
Nano Power Led on? Around 5V on VCC and Reset leads ?
avrdude: Device signature = 0x000000 usually means wiring problem or clock/crystal not running.
kprims:
Nice bright power LED on the Nano. I haven't tested the voltage on VCC and Reset. It's all been disconnected now to test the wires, so I'll have to check later.
Is it likely that's it's just faulty, and is there any simple way to check this? It came from a genuine UK supplier (not a Chinese one shipping from a UK warehouse) who I've used before, and who seem to be a good company.
If your connections are correct, it is pointing to a defective unit.
I don't know of an easy way to determine .
Not being able to load a sketch and not being able to use a programmer on it points to some major problems.
A tried a different make of Uno, and it still doesn't work, so I think the next step is to report it to the seller, and see what they say. Unless anyone has any other suggestions.
What marking is on the chip? How is the soldering?
CrossRoads:
The markings are so faint that I can't read most of it. What I assume is a CH340 doesn't seem to have any markings at all. I can't see anything wrong with the soldering.
