This is my first project with my arduino and have raninto a problem already!
I am running win 7 pro with a Sunfounder Arduino Uno.
My project is the is the sunfounder "Lesson 1 controlling LED by button".
I have checked to see that the IDE is the using the proper board and am running current drivers.
Below is the code i wrote and error i received. Any help would be greatly appreciated.
Thanks
Kent
const int keyPin = 12; //the number of the key pin
const int ledPin = 13;//the number of the led pin
pinMode(keyPin,INPUT);//initialize the key pin as input
pinMode(ledPin,OUTPUT);//initialize the led pin as output
//read the state of the key value
//and check if the kye is pressed
//if it is,the state is HIGH
if(digitalRead(keyPin) ==HIGH )
digitalWrite(ledPin,HIGH);//turn on the led
digitalWrite(ledPin,LOW);//turn off the led
Problem uploading to board
aArduino: 1.8.2 (Windows 7), Board: "Arduino/Genuino Uno"
Sketch uses 902 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x36
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x36
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x36
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x36
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x36
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x36
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x36
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x36
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x36
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x36
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
