Newbie - i2c Multiplexer for OLED and DAC - U8glib
Hello everyone!
I am a complete newbie to Arduino coding, my current project needs to use the SDA/SCL signal for an OLED display and a DAC (MCP4725). I assume the TCA9548A would get the job done to multiply the SDA/SCL signals.
I am, for the time being just trying to get the U8glib- Hello World code to display on my OLED, through the multiplexer. If, someone could then give me some coding information to use the MCP4725 in the same multiplexer that would be awesome!
I have scoured over several tutorials for both chips, but nothing seems to be working inconjuction with each other.
I have to use U8glib, seems to be the only one I can get to work with the screen.
I am essentially creating a custom guitar pedal. Using a Arduino Mega 2560, an OLED display, and adding a DAC converter to create a true analog output.
When I run the i2c scanner, it recognizes the TCA9548A at 0X70
When I run a different i2c scanner it finds an ADDR at 112. I'm not sure how to interpret this lol.
Code is below.
  HelloWorld.pde
  "Hello World!" example code.
  >>> Before compiling: Please remove comment from the constructor of the
  >>> connected graphics display (see below).
  Universal 8bit Graphics Library, https://github.com/olikraus/u8glib/
  Copyright (c) 2012, olikraus@gmail.com
  All rights reserved.
  Redistribution and use in source and binary forms, with or without modification,
  are permitted provided that the following conditions are met:
  * Redistributions of source code must retain the above copyright notice, this list
    of conditions and the following disclaimer.
  * Redistributions in binary form must reproduce the above copyright notice, this
    list of conditions and the following disclaimer in the documentation and/or other
    materials provided with the distribution.
  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
  CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES,
  INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
  MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
  CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
  NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
  LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
  STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
  ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
  ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <Wire.h>
#include "U8glib.h"
#define MUX_Address 0x70 // TCA9548A Encoders address
char tmp_string[8];  // Temp string to convert numeric values to string before print to OLED display
U8GLIB_SH1106_128X64 u8g(U8G_I2C_OPT_NO_ACK);	// Display which does not send ACK
// Initialize I2C buses using TCA9548A I2C Multiplexer
void tcaselect(uint8_t i2c_bus) {
    if (i2c_bus > 7) return;
    Wire.beginTransmission(MUX_Address);
    Wire.write(1 << i2c_bus);
    Wire.endTransmission();
void draw(void) {
  // graphic commands to redraw the complete screen should be placed here
  u8g.setFont(u8g_font_unifont);
  //u8g.setFont(u8g_font_osb21);
  u8g.drawStr( 0, 22, "Hello World!");
void setup(){
	  DisplayInit(); // Initialize the displays
    Wire.begin();
void DisplayInit(){
    for (int i = 0; i < 7; i++) {
      tcaselect(0);   // Loop through each connected displays on the I2C buses
  		u8g.firstPage();
  		do {
  			u8g.begin();  // Initialize display
  		 } while( u8g.nextPage() );
  // assign default color value
  if ( u8g.getMode() == U8G_MODE_R3G3B2 ) {
    u8g.setColorIndex(255);     // white
  else if ( u8g.getMode() == U8G_MODE_GRAY2BIT ) {
    u8g.setColorIndex(3);         // max intensity
  else if ( u8g.getMode() == U8G_MODE_BW ) {
    u8g.setColorIndex(1);         // pixel on
  else if ( u8g.getMode() == U8G_MODE_HICOLOR ) {
    u8g.setHiColorByRGB(255,255,255);
  pinMode(8, OUTPUT);
void loop(void) {
      tcaselect(0);
      u8g.begin();
  	  u8g.firstPage();
  do {
    draw();
  // rebuild the picture after some delay
  delay(50);
Address 0x70 and 112 are the same.
0x70 is the hex version and 112 is the decimal version.
Either can be can be used, it is just different output from the different i2c scanners.
Where does it see the DAC?
If the I2C addresses are different, they can both be on the same I2C bus, which is the hole point of a bus orientated connection scheme.
a7
Doesn’t seem to be recognizing the OLED address or the DAC address.
Are you placing one item at a time on the bus and scanning for it?
So two scans, each of which should tell you where the thing that is the thing on the bus is at address wise.
If a single item doesn't scan, you've wired it wrong, you have n issue with pull-ups or lead dress or you have broken parts…
a7
