Hello Everyone. I am so green here that you really couldn't even classify me as new to Arduino. I need to implement a system that is only a rough idea in my head, so the first thing I would like to do is explain roughly what I want to do to see if you think it is even feasible. The electricity bill at my church is absolutely ridiculous because of demand charges. What I need to do is to design a system that allows only one HAVC system to run at any given single time. Once a unit comes on, the others are prohibited to turn on for a set amount of time in order to let the working unit run some. Once the allotted time for that unit expires, it will be cut off. Then, after a short pause, another unit will come on based on priority that I would like to determine with temperature sensors around the church. I am an electronic hardware guy, so the wiring and the hardware is not an issue for me. However, I suffered a lot in my electronics career by not knowing how to code. I have friends who are software developers, and I realize there are learning tools out there, and hopefully a "cookbook" of code samples I could draw from. I just need someone here with experience to tell me "Yeah, that's a good idea", or "You're wasting your time". My plan would be to use an Arduino board with plenty of inputs and a relay module that would basically intercept the heating and cooling enabling wires from the thermostats. I would like to be able to communicate with the Arduino without having to climb up in the attic where the hardware will reside. If you feel like this is worth pursuing, I would welcome suggestions on specific hardware to purchase, and the best place to stick my toe into learning how to code it up.
Thanks much,
Brian
