Newbie! please help
hi there i am new to using arduino .i tried downloading my progam but i got this erore message
Arduino: 1.8.18 (Windows 10), Board: "Arduino Uno"
Sketch uses 2770 bytes (8%) of program storage space. Maximum is 32256 bytes.
Global variables use 50 bytes (2%) of dynamic memory, leaving 1998 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x64
Problem uploading to board. See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x64
option enabled in File -> Preferences.
Welcome, lots of others have had the same problem. It appears you have the wrong board selected. Go into tools menu and select the appropriate board. Also if it is a Nano and you get this error after selecting it change it to old bootloader. Good Luck!
I really hope selecting the correct board helped.
I faced a similar error, except the I got resp=0x44.
In my case, I actually had a broken Arduino.
It could have maybe been fixed by flashing the bootloader, but this is advanced stuff and requires a second Arduino, which I didn't have at that time.
The shop replaced it and the replacement is working fine.
Good luck!
Thanks for letting us know. Enjoy you have a lot of fun hours ahead of you!
