I want to develop a small project, and I want you guys to tell me if its possible to do it in arduino.
Basicly, I would like to know if its possible to connect a usb webcam to the arduino and make it process the image(photo) and then do something(for instance, controll some led's)
If that is possible to implement with the arduino, is it possible to run it with out beeing connected to the PC.
Just want to know if its possible, so I can start to digg on it
You can process what is coming from an optical mouse sensor, and it's fairly "easy" and fast, maybe a camera is possible, but I don't think it'll be at 30fps ^^
I just unscrewed my Logitech webcam, to see if I can find the chip behind the ccd & it's datasheet, check if there's some kind of I2C or whatever, but all I can find was the CCD, a bunch of SMD resitors & caps et a crystal. I took the lens off and it seems that the CCD & the microcontroller are embedded in the same chip, and no markings.
My advice : try to find the cheapest webcam possible, maybe you'll be able to find the chip & learn a bit more about it, don't buy any thing with Logitech or Microsoft written on it ^^
No way!
Just imagine a webcam that delivers an image at a really bad resolution and not even color only b/w.
This image will still have 76800 pixels so you would need to have at least RAM enough for 9600 byte just to store the image somewhere, no processing yet or anything else. But the arduino has only 1024 of RAM, so obviously it can't be done.
You will need a bit more processing power and RAM for any kind of image processing.
Eberhard
No way!
Eberhard
That was my first thought, too, but what if you add 256kB memory (static RAM or something like that), to hold the image?
You could eventually poll the CCD regularly and retrieve the data for one full frame via I2C or whatever, store those datas on an external EEPROM or SDcard ... then take your time for processing the data. Once you finished processing, restart the procedure.
You'll have a loosy framerate, and you still have to find the right webcam with the good chip, but may be done eventually, don't you think?
The question is why? It's like saying that you might be able to weld a joint with a lighter. It might be doable eventually, but the right tool exists for the job, so why not use that? If you want to be doing embedded image processing, use a microcontroller that can handle it (e.g. XMegas, 32-bit ARMs, etc), or get a camera that does most of the image processing for you.
You would need 18 IO-Pins from the arduino simply to select the address of a 256kb static RAM and another 8 IO-Pins to read or write the value to/from RAM that counts up to 26.
Arduino only has 20 IO-Lines? Too bad doesn't seem to work
Seriously : Forget it!
Get yourself a mini-itx-board and a linux that runs on it. That will work, and is probably the cheapest solution around.
Eberhard
Oh, please. Parallel has a degenerate cousin. His name is Serial. Check him out.
You can do it with one I/O line (http://www.microchip.com/UNIO).
It's pretty obvious why this guy would like to go about it the way he's thinking about. You can get a USB webcam for $5, whereas you'd be very lucky to find a sensor+lens+interface "designed" for this less than $50. The economies of scale are so incredibly appealing for repurposing a mass-market widget that as a hobbyist, you'd be a moron to not at least consider trying to gut something packaged to start with. Great example, $20 for a Wii Nunchuck or $35-40 for a breakout board from Sparkfun, the former which many people can use immediately for $0 additional cost by whacking off the connector.
I'm not saying that you'll be totally successful in what you're looking to do, but there's a chance you can get at least something working if you're lucky enough to find the right item to hack. It should also be obvious that you're not going to be able to get very fancy with just an Arduino, though, too.
If you want a sample datapoint, check out the CMUCam. It does some pretty cool (but not astounding) stuff -- in the $200 price range. But it'll give you an idea about how quickly vision processing gets complicated/expensive. It's something that you can learn a ton from. Good luck.
Here's a project that used a image processing chip controlled by an AtMega32 as a security camera. It doesn't do any image processing, but it does show how one might capture images with a microcontroller.
I was just searching for a similar solution, came across this thread and also this youtube video - control de estados flash+arduino+webcam - YouTube (can't post a hyperlink till I've done my first post, which this is...).
I'm guessing that the camera is actually connected to the PC with flash doing the processing, it's sufficient for what I wanted so I thought I'd put it on for anyone else looking for similar.
