Hi everyone, hopefully I am improving with my ability to post....not so much on the coding but I'm trying,,,,
It seems like it should be pretty simple to push a button and make a motor turn but it's not working and I'm a bit stuck. would appreciate a point in the right direction....here is the sketch:
//////arduino nano with L298n
//////2 push button with 2 motor
//////push for on, release for off
//////potentiameter speed control
////push button A pin d6
////push button B pin d5
////motor 1 enable pin d10
////motor 1 int 1 pin d7
////motor 1 int 2 pin d8
////motor 2 enable pin d9
////motor 2 int 3 pin d2
////motor 2 int 4 pin d4
//potentiometer pin a1
#define enA 10
#define in1 7
#define in2 8
#define buttonA 6
#define enB 9
#define in3 2
#define in4 4
#define buttonB 5
// Speed control potentiometers
int SpeedControl1 = A1;
int SpeedControl2 = A1;
// Motor Speed Values - Start at zero
int MotorSpeed1 = 0;
int MotorSpeed2 = 0;
pinMode(enA, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(buttonA, INPUT);
pinMode(enB, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
pinMode(buttonB, INPUT);
// Set Motor A forward
digitalWrite(in1, LOW);
digitalWrite(in2, LOW);
// If button is pressed - turn motor on
if (buttonA == true) {
digitalWrite(in1, HIGH);
delay(20);
// Set Motor B forward
digitalWrite(in3, LOW);
digitalWrite(in4, LOW);
if (buttonB == true) {
delay(20);
// Read the values from the potentiometers
MotorSpeed1 = analogRead(SpeedControl1);
MotorSpeed2 = analogRead(SpeedControl2);
// Convert to range of 0-255
MotorSpeed1 = map(MotorSpeed1, 0, 1023, 0, 255);
MotorSpeed2 = map(MotorSpeed2, 0, 1023, 0, 255);
// Adjust to prevent "buzzing" at very low speed
if (MotorSpeed1 < 8)MotorSpeed1 = 0;
if (MotorSpeed2 < 8)MotorSpeed2 = 0;
// Set the motor speeds
analogWrite(enA, MotorSpeed1);
analogWrite(enB, MotorSpeed2);
