thank you for the reply.
yes, that is the version 2. the version 3 is like version 2 cut in half.. the seller told me that the manual for version 3 is on process, so that's why i don't know the details of it.. and i dont have the manual for version 3,, the seller just said that its like the version two. the picture of v3 is attached.
i just followed the sketch in version two. here it is
This code is show how Arduino Wave Module works with Arduino.
Code is not optimized. Any improving work on it is encouraged.
int RST = 3;
int CLK = 9;
int DAT = 8;
pinMode(RST, OUTPUT);
pinMode(CLK, OUTPUT);
pinMode(DAT, OUTPUT);
digitalWrite(RST, HIGH);
digitalWrite(CLK, HIGH);
digitalWrite(DAT, HIGH);
digitalWrite(RST, LOW);
delay(5);
delay(300);
send(0x0000);//play file 0000
delay(10000);//delay 10 seconds
send(0x0001);//play file 0001
send(0x0002);//play file 0002
send(0xfff0);//set voice volumn to 0 (turn off)
delay(3000);
send(0xfff4);//set voice volumn to 4
delay(3000);
send(0xfff7);//set voice volumn to 7
delay(3000);
send(0xfffe);// pause
delay(5000);
send(0xfffe);//play
while(1);
void send(int data)
digitalWrite(CLK, LOW);
delay(2);
for (int i=15; i>=0; i--)
delayMicroseconds(50);
if((data>>i)&0x0001 >0)
//Serial.print(1);
digitalWrite(DAT, LOW);
// Serial.print(0);
if(i>0)
if(i>0)
delay(20);
that code plays the wave shield right. it can play, pause, previous and next the sounds.
then for the piezo sensor, yes, i used 1M resistor parallel to it and also i tried to sense it and have tried some of the codes i saw on the net. here it is..
int ledPin = 13;
int knockSensor = 0;
byte val = 0;
int statePin = LOW;
int THRESHOLD = 10;
pinMode(ledPin, OUTPUT);
val = analogRead(knockSensor);
if (val >= THRESHOLD) {
statePin = !statePin;
digitalWrite(ledPin, statePin);
Serial.println("Knock!");
delay(100); // we have to make a delay to avoid overloading the serial port
then this one is my latest code for piezo sensor that i want to put into the codes of the wave shield for triggering it to play the sound when it reach a certain threshold..
int sensePin = 0;
int ledPin = 13;
analogReference(DEFAULT);
int val = analogRead(sensePin);
if(val >30) digitalWrite(ledPin, HIGH);
else digitalWrite(ledPin, LOW);
my problem is, i don't know where to put the codes of piezo to the codes of wave shield for it to be the trigger for playing the sound,, i tried inserting this one to the void loop of wave shield but it doesn't make any changes.
if(val <30) { send(0x0000);
delay(10000);
send(0xfff2);
delay(3000);
send(0xfffe);
delay(5000); }
of course i have done int sensePin=1 in the first part of the sketch..
please help?
