Hi. I'm using a Nextion with a ESP32. I have a simple sketch that catches the event button, it works fine when I connect to Serial2 from my board, but when I change Serial, the button event stops working and I can only send data to the screen. I have also tried with different pins. From the editor, I send the Component ID.
#include <Nextion.h>
NexButton btn = NexButton(0, 1, "b0");
NexTouch *nex_listen_list[] =
&btn,
NULL
Serial1.begin(9600, SERIAL_8N1, 26, 27); //Nextion
//When I use Serial2, everything works.
//Serial2.begin(9600);
btn.attachPush(b0PushCallback, &btn); // Press event. Only works with Serial2
btn.attachPop(b0PopCallback, &btn); // Press event. Only works with Serial2
printDisplay("t0.txt=\"Hello\""); // Send data works with any Serial
void b0PushCallback(void *ptr)
Serial.println("PushCallback");
printDisplay("t0.txt=\"Button pressed\"");
void b0PopCallback(void *ptr)
Serial.println("PopCallback");
nexLoop(nex_listen_list);
void printDisplay(String content) {
Serial1.print(content);
Serial1.write(0xff);
I have tried with 2 ESP32 and 2 different Nextion screens, and the same thing happens.
Am i missing something?
